45669
It has just been announced on the BBC that a criminal investigation has been opened.
Ah yes.
The problem on a single line, of course, is that the *other* train is proceeding *not* on sight.
That approach only works safely on a unidirectional line, where the worst case is a stationary train, not one proceeding towards you at 100km/h.
I'm interested in the two intermediate block signals in the middle of the single line section. These are clearly for trains to be able to follow each other closely in the same direction usually, but it's possible that under certain conditions interlocking might allow trains to approach these two signals from opposing directions, say for instance two engineering vehicles entering the single line from both ends for different tasks. They'd still be fully protected from one another by the intermediate signals being at red and there being an appropriate protection distance between them. Imagine if this facility had been used incorrectly to allow two passenger trains into the section. If this happened, normally it would be inconvenient but safe nevertheless as neither movement could proceed beyond the appropriate intermediate signal at red. One of the trains would have to back out to let the other pass. Now factor in a SPAD at the intermediate signal for one of those trains. It might even have been a ding-ding-away from signal 313 if that train had stopped at the Kurpark station. Now the question returns to the Indusi. That should have intervened with an immediate trainstop on passing 313s magnet but could it have been left in a disabled state after an authorised pass at danger from the previous signal when first entering the single line (with an ersatz signal say?). I would have expected an override to function for one pass only then revert to normal operation for subsequent magnets.
It's these Ersatzsignale I really don't like the idea of on anything other than a unidirectional line. It strikes me that anything that makes it easier to instruct a driver to pass a signal onto a single line at danger is a massive, massive risk.
Much as, as a passenger, I would find it rather inconvenient if I had to wait say two hours for someone to turn up in a van and act as pilotman, I'd rather that than be signalled onto a single line with no absolute certainty that there was no other train there.
Drive on sight is fine if (a) everyone is driving on sight, or (b) there can't be anything going towards you. If one of those things is not provably true, and proven by more than one person, I'd rather wait.
But making it easier to get authority to pass one at danger is not a safe solution.
It's fine if everyone is driving on sight, but if the other train isn't....
So to clarify a bit as I don't think anyone answered above.
Absent these new signals, what is the current procedure to authorise a UK driver to pass a signal onto a single line section at danger? Assume track circuited so no token or train staff.
I feel I need to be clearer on this as your missing the point. The safety is not compromised at any point. The PoSA is a replacement for the conversation that takes place and speeds up the movement of trains through the section as you don't stop and caution. The PoSA is set by the Signaller so whether they talk to you specifically or they signal you past the red makes little to no difference. All their actions and mine are the same.
Since Abermule in 1921, as far as I know, there has only been one single track head on collision in the UK caused by human error.
Neil does have a valid point here.
As people have mentioned further up the thread, if a procedure that bypasses the normal safeguards takes a bit of time to apply, it's less likely that the people concerned will immediately adopt that procedure.
And if they do jump to the conclusion that the equipment is at fault when it's actually a train somewhere that they have temporarily forgotten, then it's more likely they will realise their error before they do something irrevocable.
The use of a PoSA aspect potentially carries the same risk. In principle there exists the temptation to get the train moving quickly by hitting the button that activates the PoSA, whereas a conversation with the driver takes longer and also introduces a second person who might question the first one.
One mitigation of the risk at a PoSA signal is the "line of sight" requirement, that a driver obeying a PoSA must drive slowly enough to stop short of any obstruction that comes into view ahead.
However this might not be sufficient if the "obstruction" is another train moving in the opposite direction, even if both drivers brake immediately. So on a bi-directional line PoSA carries a greater likelihood of collision, albeit at fairly low speed.
I'm not familiar with the technical details of PoSA or the operational rules surrounding its use
But it does illustrate a principle that may be relevant to the circumstances of this accident.
I'm not saying his point isn't valid. Just that he is overstating the risk.
It is not bypassing the normal safeguards.
I feel it is important to stress that the introduction of PoSA's still keeps the railway safe and are not compromising safety. Up until recently you could pass a signal on your own authority and that was (and still is) considered safe. The PoSA is authority from the Signaller.
As someone who goes past PoSA's on an almost daily basis I feel it is important to reassure people that we are still safe when we go through them to state they are unsafe is hearsay and unfounded. It is not something any passenger should believe. I hope that a Signaller can also give that same reassurance from their perspective and professional knowledge.
This is how I thought it was, and is much more reassuring than that a signaller could, without being forced to involve someone else, press a button to clear a signal onto a single line where another train could be proceeding at linespeed with no knowledge of the issue.
The number of head-on collisions in this list of German railway accidents, even in recent times, is quite surprising.Since Abermule in 1921, as far as I know, there has only been one single track head on collision in the UK caused by human error.
One thing that I haven't grasped about the PoSA procedure is how the signalman communicates the authority to pass the stop signal to the driver.
Based on a quick trawl of Railways Arcive there are at least two:
- Fishguard 1951 (http://www.railwaysarchive.co.uk/docsummary.php?docID=941)
- Cowden 1994 (http://www.railwaysarchive.co.uk/eventsummary.php?eventID=151)
That is the purpose of the POSA aspect, which is two diagonal white lights like a subsidiary signal but flashes.
Thanks. I wasn't aware of the first one. Still goes to show how effective Victorian single line signalling was, Tyers first tablet instrument having being introduced in 1878!
