Severn tunnel diversions in September via Glos
paulfoel
6 Jan 2014
I travel daily between Newport and Glos. Not sure if this is going to be better or worse for this short time.
I understand Bristol will be bus replacement but trains for Swindon onwards will run via Glos. So, I guess this will be more trains. BUT will they stop at Glos additionally or go straight throught to Swindon?
Captain Chaos
31 Jan 2011
Not sure but during the recent diversions nearly all of then stopped at Gloucester I believe.
alb1
13 Apr 2015
Yes, I did Swindon to Swansea on the bank holiday Monday and we did stop at Gloucester.
Given that I wasn't in a hurry I thought it was a lovely diversion and thoroughly enjoyed seeing a bit more of the country.
greaterwest
23 Nov 2014
Indeed as far as I am aware, almost all diversions stop at Gloucester.
ValleyLines142
25 Jul 2011
Gloucester
As others have said, it'll be actually be better for you as you can get the Paddington train, in addition to the Cheltenham and Nottingham services.
As for me, who regularly commutes between Cardiff and Bristol, I'm either going to have to stick with the rail replacement coaches (which really are a nightmare), or instead use the X7 bus.
paulfoel
6 Jan 2014
Yep. Pretty good service to Gloucester anyway between ATW and CC theres pretty much one every 30 mins. The ATW one can be a bit slower with additional stops.
I tend to catch the CC most of the time - trains are a bit nicer as well. And AC (in theory!).
Be good to have the extra London train too. Assuming it wont stop at Chepstow or Lydney it could be a very quick journey (< 35mins).
Dont fancy the bus replacement to Bristol..... Never a fan of those.
Got stuck on the last train to Ebbw Vale from Cardiff the other week. Bus replacement. No toilets of course. Not clever on the last train when 90% of the passengers were going home from a night out in Cardiff.
Severn Valley line is nice. After 18 months of every day though I've seen it enough!
paulfoel
6 Jan 2014
So is the Severn estuary;)
If there's a river running through it, its a valley in wales! :)
Although I always tell work colleagues that the valleys they claim to have in Gloucestershire are pretty poor.
And also when does a valley become an estuary?
D1009
22 Feb 2012
Stoke Gifford
http://www.dictionary.com/browse/estuary?s=t
noun, plural estuaries.
1.
that part of the mouth or lower course of a river in which the river's current meets the sea's tide.
2.
an arm or inlet of the sea at the lower end of a river.
Also I thought the Severn Valley line was somewhere entirely different.
paulfoel
6 Jan 2014
1.
2.
Ha ha I stand corrected.... :)
The diversions are in the eNRT and generally run non stop from Newport to Swindon and v.v.
So no Gloucester stop? :(
I guess it just adds a few more minutes to an already delayed journey for people travelling east.
G136GREYHOUND
29 Mar 2014
Why the heck didn't they Govt insist that when the French were allowed to build their rip off toll bridge that as part of the deal to fleece the local economy and population, that they also had to build a parallel or underslung RAIL bridge ???
louis97
14 May 2008
Derby
Gloucester stops are less common now the line between Kemble and Swindon is double track - normal service can run in addition to the diversions.
Harbornite
7 May 2016
I know this has been mentioned before and it's me being pedantic, but the Severn valley line usually refers to the the old line from Hartlebury/Kidderminster to Shrewsbury. Either way, it's the same river!
EbbwJunction1
25 Mar 2010
These are extracts from the GWR website pages dealing with the closure of the Severn Tunnel:
Severn Tunnel Modernisation - September/ October 2016
From Monday 12 September to Friday 21 October 2016, the Severn Tunnel will be closed. This means no trains will run between Patchway and the Severn Tunnel Junction; with London services diverted and replacement buses between Newport and Bristol Parkway.
Weekdays
Between London Paddington and South Wales
High Speed services from London Paddington to South Wales will be diverted between Swindon and Newport; increasing journey times by approximately 30 minutes. Trains will still run between London Paddington and Bristol Parkway.
Between Cardiff Central and Portsmouth Harbour
Trains will run between Bristol Parkway and Portsmouth Harbour
Between Cardiff Central and Taunton
Trains will run between Bristol Parkway and Taunton.
Replacement buses
Replacement buses will run between Severn Tunnel Junction and Bristol Parkway, and between Bristol Parkway and Newport.
Any additional routes will be confirmed nearer to the time.
Weekends
17 to 18 September and 15 to 16 October
The railway from Bristol Parkway through to Cardiff Central will be closed and replacement buses will be in operation between these stations.
Trains will run normally between London Paddington and Bristol Parkway; with a shuttle train service operating between Cardiff Central and Swansea.
24 to 25 September, 1 to 2 October and 8 to 9 October
In addition to the Severn Tunnel closure, trains won’t run between Swindon and Bristol Parkway. This won’t affect South Wales services as they are being diverted away from this section. Replacement buses will run between Swindon and Bristol Parkway.
Further works affecting services into South Wales
3 to 4 and 10 to 11 September
Trains will be diverted between Cardiff Central and Bridgend increasing journey times by approximately 30 minutes.
Sunday 11 September
The railway between Bath Spa and Westbury will be closed. Trains between Cardiff Central and Portsmouth Harbour will be diverted via Swindon; increasing journey times by approximately 35 minutes. Replacement buses will be available between Westbury and Bath Spa.
22 to 23 and 29 to 30 October; 5 to 6 and 12 to 13 November
The railway between Didcot Parkway and Swindon will be closed all weekend (extending to Bristol Parkway on Sundays). Trains to South Wales will be diverted increasing journey times by approximately 45 minutes.
Revised timetables
The best way to find details of train times and replacement services is to use our online journey planner.
Or, if you prefer you can download our PDF timetables:
London to South Wales
Cardiff to the South Coast
Here's a link to this page: https://www.gwr.com/travel-updates/planned-engineering/severn-tunnel
On a quick check over a period of about four or five hours between London and Cardiff, it looks as if the diverted trains will not call at Gloucester.
Envoy
29 Aug 2014
It looks like massive travel delays will occur - especially with the M4 being often jammed at Newport due to the choke point at the 2 lane tunnel. The sooner they get on and start building the 3 lane each way black route south of Newport the better. (Most Labour and Conservative Welsh Assembly members favour the ‘Black Route’. Plaid Cymru, UKIP and the sole Liberal Democrat - Kirsty Williams - are against it and favour ‘cheapskate’ solutions
such as improving the Southern Distributor road to create a continuous 2 lane each way highway. It will never work as that is the problem now - only 2 lanes at the tunnel).
Flybe are operating flights between Cardiff & London City Airport during the rail closure.
http://www.flybe.com/timetableClassic/timetable.jsp?selDep=CWL&selDest=LCY
You could not make this up BUT the Welsh Government have authorised major work at the Brynglass (Newport) tunnels starring in June 2016 & lasting for 20 months. Although this will mainly take place at night, you would have thought that everything possible would have been done to ensure that the M4 is clear drink the Severn Tunnel closure.
http://www.walesonline.co.uk/business/business-news/m4-motorists-face-disruption-20-11450620
QUOTE:> 'One of the UK's busiest motorways the M4 will see a key section closed at night as maintenance work is carried out on the Brynglas Tunnels at Newport for 20 months.
The Welsh Government has confirmed that the necessary work on the two-lane tunnels, which are often the cause of congestion on the key transport route into South Wales, particularly at rush hour, will start on Monday, June 20th'. QUOTE END.
PHILIPE
14 Nov 2011
Caerphilly
UKIP not in favour, only Neil Hamilton himself. His statement was contradicted by other members
paulfoel
6 Jan 2014
Weekdays
Replacement buses
Weekends
Sunday 11 September
Revised timetables
Pity. There goes my dream of a fast train for a few weeks at least :(
Yes I think there will a big problem on the roads during this time. As you said the BrynGlas tunnels are always a big problem.
