Sheffield/Rotherham Tram-Train update
Discussion in 'Other Public Transport' started by bladesman123, 18 Jun 2014.
  1. bladesman123
    bladesman123 Member
    89
    7 Jul 2009
    Sheffield
    Rail Forums
  3. MK Tom
    MK Tom Established Member
    2,341
    31 Aug 2011
    Milton Keynes
    Is there anywhere online the detailed plans can be viewed?
  4. DimTim
    DimTim Member
    146
    11 Aug 2013
  5. 34D
    34D Established Member
    6,031
    9 Feb 2011
    And the text:
  6. eastwestdivide
    eastwestdivide Established Member
    1,826
    17 Aug 2009
    Just to save a few clicks, that doc only covers the application to change the use of land near Parkgate.
    I tried searching for the ref no but their search system didn't show me any results.
  7. DimTim
    DimTim Member
    146
    11 Aug 2013
    Correct - the Rothbiz article refers to this planning application for the sub station.
    The flood report gives details of where the track is to be lowered. Nothing further is available as yet.
    After Rotherham station recent refurbishment surprised article refers to new access ramps. Also lowering track at College Road bridge will likely affect track height in platforms due to its proximity.
    New platforms? I understood Sheffield end of existing platforms were to be lowered to tram height.
  8. Xenophon PCDGS
    Xenophon PCDGS Veteran Member
    26,224
    17 Apr 2011
    Is the area where the line passes through in Rotherham one that would never be affected by the effects of the flooding that occurred in 2007 ?
  9. DimTim
    DimTim Member
    146
    11 Aug 2013
    Station is next to the canal with the river nearby. The deluge of 2007 was exceptional with Tesco car park 10/15 ft above normal river level under water however I seem to recall there has been other minor flooding on the line in the past.
    The line through to Parkgate is never far from the canal - weirs keep the water level under control. Flood control measures have been taken on the river but as you can see from the planning application the sub station will be built on stilts!
    Plans for a new school on the other side of the canal from Parkgate suggest it will be built at 1st floor level with very little on ground floor.
    Line as closed in both November & December 2013. Not at the station but nearer to where new tram terminus will be situated. Other side of Rawmarsh Road near canal boat turning area
  10. Bayum
    Bayum Established Member
    1,910
    21 Mar 2008
    Any information on the rolling stock to be used for such services?
  11. edwin_m
    edwin_m Veteran Member
    17,286
  12. eastwestdivide
    1,826
    17 Aug 2009
    Short answer - no, it's not an area that would never be affected (or doing away with the double negatives - the area could still be affected).
    It uses the line through Rotherham Central which was affected by those and other floods. However, they've done a certain amount of additional flood protection work through the town which might mean that it would take a really exceptional amount of water to cause problems.
    Worth bearing in mind that the line through Central was built partly on the route of the canal, which was diverted to accommodate it.
  13. talltim
    talltim Established Member
    2,246
    17 Jan 2010
    Having spoken in the past to the SYPTE project managers for the Rotherham Central Station rebuilt and the Tram-Train project, I understood that the platforms were to be extended at a lower height, but I've never directly asked so I could having been making an assumption
  14. Haydn1971
    Haydn1971 Established Member
    2,086
    11 Dec 2012
    Sheffield
    That is my understanding of the platform arrangements at Rotherham - I have directly asked as part of some work I was involved in for SYPTE
  15. snowball
    snowball Established Member
    4,706
    4 Mar 2013
    This article says there's been a further delay:
    http://www.railtechnologymagazine.com/Rail-News/sheffield-to-rotherham-tram-train-delayed
  16. ianhr
    ianhr Member
    505
    17 Sep 2013
    I wonder if the money being squandered on this daft scheme would have paid for double tracking the Holmes Junction-Rotherham Central line and the Dore curve + new platform at Dore, all of which would bring wider benefits. Alternatively spend the money on the existing Supertram system and build a new line to a part of the city not served by rail transport and where people actually live.
  17. Xenophon PCDGS
    26,224
    17 Apr 2011
    I suppose that "somewhere" had to be used for these trials and the existing area of the chosen site was one that already had a sizable tram service in its environs, where the local population were used to such a similar mode of transport.
  18. 61653 HTAFC
    61653 HTAFC Established Member
    10,879
    18 Dec 2012
    Another planet...
    Indeed. Much rather this than the preposterous earlier suggestion of using bi-mode tram-trains all the way to Huddersfield.
  19. starrymarkb
    starrymarkb Established Member
    5,986
    4 Aug 2009
    Exeter
    And if it's not a success then the trams can work happily on the Supertram network.
    DfT is paying for the Trial, if SYPTE want a new tram route they'd have to pay for it (which they don't have the money for at the moment). Either way they've got a few new trams for free out of this trial :)
  20. Greybeard33
    Greybeard33 Established Member
    2,527
    18 Feb 2012
    Greater Manchester
    New launch date now announced:
    http://www.railtechnologymagazine.com/rail-news/sheffield-tram-train-new-launch-date-set--january-2017
    This is a further slip of 8 months from the previous date of May 2016. Since the tram-train delivery schedule is unchanged, the vehicles will be used on the existing Supertram network before the NR line is ready:
    Supertram users are doing very nicely out of this project, having already had replacement tram tracks funded by the taxpayer!
  21. WatcherZero
    WatcherZero Established Member
    9,323
    25 Feb 2010
    To be fair the tracks needed renewing anyway and there wasn't any money set aside to do it, so might as well modify them while renewing.
  22. snowball
    4,706
    4 Mar 2013
    NR press release:
    http://www.networkrailmediacentre.c...-Tram-Train-operations-in-Sheffield-2268.aspx
    Map here:
    http://www.networkrailmediacentre.c...-location-of-proposed-Tinsley-chord-2225.aspx
  23. pro4600
    pro4600 Member
    54
    6 Nov 2011
    Has the location of the terminus at parkgate been identified yet?
  24. Xenophon PCDGS
    26,224
    17 Apr 2011
    So, January 2017 should see all ready to conduct the long-awaited tram/train trials to commence.....hopefully.
  25. eastwestdivide
    1,826
    17 Aug 2009
    Interesting - the map linked from post 21 shows the new chord further north from the Meadhowhall South tram stop than I'd been assuming. It would seem that Rotherham-bound tram-trains will now stop at Meadowhall South tram stop, then take the tram bridge over the Don and only then turn right under the M1. I'd assumed the junction would be broadly south of the tram stop, where the tram and train lines are close together.
    Time to get the camera out again this weekend.
  26. Haydn1971
    2,086
    11 Dec 2012
    Sheffield
    The alignment in post 21 is different to what I've seen before. There was a tender brief about a year ago to assess the station at Meadowhall South, at that time four platforms were been proposed - however the move of the chord now reduces costs by removing the need for two platforms and a new bridge across the River Don - that's a huge saving of perhaps £2-3M on the project.
  27. Greybeard33
    2,527
    18 Feb 2012
    Greater Manchester
    Interesting that the map appears to show that the Tinsley end of the shared alignment will consist of two segregated single lines, one for the tram-trains and the other for heavy rail. Does anyone know what length of track will actually be shared between light and heavy rail?
    Parallel tram and heavy rail single lines, separated only by the six-foot, are in daily use on Manchester Metrolink, so this part of the pilot scheme will not demonstrate anything new.
  28. edwin_m
    17,286
    It'll have to become a shared alignment where the Holmes Chord merges in and through Rotherham Central. I don't know whether the parallel single line extends that far or indeed exists at all - that doesn't look like the sort of plan to rely on for details of track layout.
  29. eastwestdivide
    1,826
    17 Aug 2009
    Well I went to the consultation on the new Tinsley Chord, which didn't add much to what was shown in the map linked above. They did say that putting the chord in had a few advantages over putting in a crossover at the Sheffield end of Meadowhall South/Tinsley tram stop: no need for new platforms, space for voltage change equipment on the chord if ever the rail line gets electrified at 25kV, and space on the chord to pause trams or turn them back (in either direction) in case of disruption on one or other network. By stopping them there, they wouldn't block either network.
    There's no need to build a bridge over the Don under either scheme - the earlier scheme would have used the rail bridge (to the right of my photo), while the current scheme uses the tram bridge.
    Anyway, attached is my photo showing roughly the area of the linked map, with scribblings to show the proposed chord etc.
    The far end of the chord (invisible in the photo) would be roughly where Tinsley East Junction was, which linked the GC's Rotherham-Sheffield line (the current freight line) to the GC line towards Barnsley, part of the trackbed of which is now occupied by the tram as it runs parallel to the M1 motorway viaduct.
  30. edwin_m
    17,286
    It also makes the signalling a good deal simpler. If there was just a crossover then whoever controlled it would need to ensure that the other end was free before operating it. This involves NR equipment detecting the presence of approachign Supertrams or vice versa. Assuming there is enough space to stop a tram-train at a signal on the double-track part of the chord, the two signalling systems can remain effectively independent with just an information link to advise the other system when a tram-train is approaching.
  31. eastwestdivide
    1,826
    17 Aug 2009
    Yes, I think the Network Rail chap at the consultation was saying something about the signalling handover issue (he was talking with someone else), but I didn't catch the gist of it.
Share This Page
