Short circuit bar
jc1
3 Jan 2013
Is there ever any circumstances when a short circuit bar can't be used?
ComUtoR
13 Dec 2013
Sounds suspiciously like a 'rules' question. Look at those yellow kickboards; they might give you a clue :)
tsr
15 Nov 2011
Between the parallel lines
Areas with a fourth rail (mostly...)
Areas with conductor rail guard boards / yellow guard plates (these are actually printed with “Do Not Use Short-Circuit Bar” on them)
bb21
Emeritus Moderator
4 Feb 2010
Are you perhaps getting confused with the four circumstances where you should apply one?
There are four where SCB may be used, and four where they should not be used.
I've got the four when they can be used but not the four when they can't
What have you got so far?
jc1
3 Jan 2013
When there is a guard board
When there is a yellow plastic shroud
bb21
Emeritus Moderator
4 Feb 2010
Someone above has already given you the answer to the third. (Hint: Gunnersbury, Kew Gardens, etc)
The last one is where dangerous goods are involved. (Just consider what applying SCBs would produce.)
jc1
3 Jan 2013
Do you mean a non electrified line?
bb21
Emeritus Moderator
4 Feb 2010
No, they are fourth-rail land. The official answer is "on London Underground lines except East Putney to Wimbledon".
jc1
3 Jan 2013
Ok thanks but why is East Putney to Wimbledon different?
*guess alert*
Is this where it is not 4th rail?
It is fourth rail, but the overall installation along there including substations follows normal Network Rail design standards and rules, despite the ownership change at privatisation. Elsewhere the mainline stock is running on a “system” that follows LU engineering standards and their rules.
Bigfoot
2 Dec 2013
But it's not really 4th rail. As its bonded to the running rails. Which is why it's safe to use track circuit operating clips.
robbeech
11 Nov 2015
Ah. Yes this is what I meant but worded it badly. 630v and 0v
Dstock7080
17 Feb 2010
West London
LU staff are told not to use track circuit operating clips on any 4-rail system, including East Putney-Wimbledon
