SC141 - CRAIGENDORAN JN TO FORT WILLIAM
CRIANLARICH TEP
Joining and splitting of trains - The following arrangements apply :-
Joining - The first train to enter the platform must be brought to a stand at the far end of the station and return the token.
The second train will be issued with a 'Loop Occupied' token at Fillan or Lower Crianlarich, as the case may be, and the driver reminded, when being given permission to proceed, that the loop line is occupied. In the event of a failure of all cab equipment in the second train, a special authority card may be used provided Clause (a) on the special authority card is endorsed 'Loop Occ'.
Splitting - Before uncoupling is carried out, the radio number of the rear train must be entered in the system.
After the first train has passed clear of the loop line, the rear train may draw forward to the combined stop board / points set indicator provided station duties have been completed, all is in order for the train to commence the movement and the conductor has sent the bell / buzzer code 6, to the driver. Before requesting a token to proceed, the driver must advise the signaller that he is at a stand at the stop board.
If only one radio is operational on the train, it may be split but the portion with the working radio must proceed to Oban. If all radios are non-operational but the radio / signalling system is still in working order in the Crianlarich area, the train must not be split but proceed to Fort William in accordance with Instruction 6, clause 6.2. of the instructions Single Lines Worked by Radio Electronic Token Block - Instructions to Traincrews, Persons carrying out Engineering Work and Others Concerned.
If splitting requires to take place during the period of a failure of the radio / signalling system affecting all trains in the Crianlarich area prior to the introduction of RETB Working by Pilotman, each portion may be allowed to proceed from Crianlarich in accordance with Instruction 6, clause 6.2. of the instructions Single Lines Worked by Radio Electronic Token Block - Instructions to Traincrews, Persons carrying out Engineering Work and Others Concerned. 'Loop Occupied' tokens - The Up direction 'Loop Occupied' tokens available for issue at Fillan and Lower Crianlarich must only be used for booked joining and splitting of Sprinter trains at Crianlarich and for providing assistance to a train which has failed in the Up loop at Crianlarich.
Junction and North end loop points - The hydraulic spring-controlled North end crossing loop points are train-operated in accordance with the standard arrangements for RETB crossing loops. The junction points are power operated clamp lock points, and are plunger operated for Down direction movements and track circuit operated for Up direction movements.
Two pairs of plungers are provided at the North end of the station at the bottom of the platform ramp, one pair in association with the Down loop 'Points Set' indicator, and one pair in association with the Up loop 'Points Set' indicator. These plungers must be operated only under the instructions of the signaller at Banavie signalling centre. Pressing the left-hand plunger of a pair of plungers sets the junction points for the Oban branch. Pressing the right-hand plunger of a pair of plungers sets the points for the main West Highland line for Upper Tyndrum. The illumination of the appropriate 'Points Set' indicator together with the correct route indication - 'B' for the branch or 'M' for the main line - after the operation of a plunger, prove that the junction points are correctly set and locked for the route chosen. Only the pair of plungers at the 'Points Set' indicator at which the train is standing can be used.
a) Down direction trains - When the driver of a Down direction train has been issued with a token and is ready to proceed, the signaller will authorise the driver to select the correct route at the same time as permission to proceed is given.
If either of these indications fail to illuminate when a plunger is operated, or if the indications illuminate but extinguish before the train can proceed past the 'Points Set' indicator, then the driver must communicate with the signaller and act in accordance with his instructions.
b) Up direction trains - If the driver of an Up direction train on the main or branch line finds that the 'Points Set' indicator on the approach to Crianlarich is displaying a single red flashing aspect or is not illuminated, he must immediately inform the signaller at Banavie signalling centre who will instruct him to unlock the lockfast box beside the indicator post and report the indications displayed inside. The driver must then act in accordance with the instructions of the signaller, and must not proceed past the indicator without the verbal permission of the signaller. Instruction 8 of the Single Lines Worked by Radio Electronic Token Block - Instructions to Traincrews, Persons carrying out Engineering Work and Others Concerned, is modified accordingly. When such verbal permission is given, the driver must not proceed until he has relocked the box and confirmed to the signaller that this has been done.
c) Failure of North end loop points - When the 'Points Set' indicator displays a single red flashing aspect or is not illuminated, the driver of an Up direction train is instructed by the signaller at Banavie signalling centre to manually operate the North end loop points, he must operate the points to the required position and clamp and scotch them in that position. An assurance must be given to the signaller at Banavie signalling centre when this has been done. The driver must not pass the 'Points Set' indicator unless the signaller at Banavie signalling centre has given permission to do so and the lockfast box at the 'Points Set' indicator has been relocked. When the train has passed clear of the points, the clamp and scotch must be removed, returned to the receptacle provided and an assurance to this effect given to the signaller at Banavie signalling centre when this has been done.
d) Override switch for junction points - The override switch for the junction points is located in the lockfast box adjacent to these points. This override switch normally lies in the centre position. Switching it to the left sets the points for the main line. Switching it to the right sets the points for the Oban branch. When operated to a position, the switch will remain in this position until it is again operated. This switch must only be operated under the instructions of the signaller at Banavie signalling centre.
If instructed by the signaller to operate this switch, the driver, or other person concerned, must carry out the following procedure :-
1. if the points are already in the correct position for the route required, the driver, or person concerned, must operate the switch for the other route, check that the points have moved to the other route, and then operate the switch to the route required and check that the points have moved to the route required.
2. if the points are not already in the correct position for the route required, the driver, or person concerned, must operate the switch for the route required and check that the points have moved to this position. He must then operate the switch for the other route, check that the points have moved to this position, and then operate the switch for the required route again, and check that the points are in the correct position for the route required.
If the override switch fails to move the points to the required position, the driver, or person concerned must report this to the signaller, who will send for the person appointed to manually operate the junction points. The driver must not pass the 'Points Set' indicator until he receives the verbal permission of the signaller.
If the points have been operated to the required position, the driver must confirm this to the signaller. The driver of a Down direction train must operate the appropriate plunger again, when so instructed by the signaller. If the correct route indication can still not be obtained, in certain failure conditions, the driver must then be instructed to proceed to the lockfast box at either the up branch or the up main Points Set Indicator (which ever is relevant to his intended direction of travel) and report the indications on display therein. If both Junction Points and Loop Points indications are confirmed by the driver to be illuminated then the relevant down train may be authorised to proceed over the junction points. The driver must also be instructed to restore the junction points to the main position and the override switch to the centre position and confirm this has been done before continuing. The driver must also confirm that he has also relocked the relevant lockfast box at the Up Main or Up Branch Points Set Indicator.
The driver of an Up direction train must report to the signaller whether the 'Points Set' indicator is now illuminated, and must then act on the instructions of the signaller. He must not pass the 'Points Set' indicator without the verbal permission of the signaller. When such permission is given, before proceeding, the driver must relock the lockfast box beside the indicator post and confirm to the signaller that this has been done.
When the driver of an Up or Down direction train has proceeded over the junction points after the operation of the override switch, and the train is clear of both the loop points and the junction points, he must return the override switch to the centre position, relock the box and confirm to the signaller when this has been done.
a) Engineers' machines - An engineer's machine which cannot be relied upon to actuate track circuits must not proceed over the junction points to / from Tyndrum Lower until the override switch has been operated under the instructions of the signaller at Banavie signalling centre.
Drivers of Down direction machines will be instructed to operate the override switch before operating the appropriate plunger.
Drivers of Up direction machines must stop at the 'Points Set' indicator on the approach to Crianlarich, even if it is illuminated, and act under the instructions of the signaller. The override switch must be operated in accordance with the previous instructions under the heading Override switch for junction points.
Engineering Possessions - If an engineering possession is required between the two single sided Station Limits boards between Crianlarich and Tyndrum Lower, the engineer must be in possession of both the Crianlarich to Tyndrum Lower 'Engineering' token and also the Crianlarich 'Shunt' token. Before the signaller issues the 'Shunt' token, the engineer must set the junction points for the branch under the instructions of the signaller, and in accordance with the instructions under the heading Override switch for junction points. When the 'Shunt' token is returned, the engineer must confirm to the signaller that the override switch has been returned to the centre position, and the box relocked.
RETB Working by Pilotman - If it is necessary to divide a Down direction passenger train or combine Up direction passenger trains at Crianlarich, two Pilotmen must be appointed to the following sections simultaneously -
Pilotman A - Ardlui (or south thereof) and Upper Tyndrum.
Pilotman B - Crianlarich Lower GF and Dalmally (or west thereof).
Down trains to be divided - Down trains must be accompanied by Pilotman A between Ardlui (or south thereof) and Crianlarich. After the train has been divided, providing Pilotman B is present and permission for the train to occupy the Crianlarich / Tyndrum Lower section has been obtained, Pilotman A may authorise the train to proceed. After Pilotman A has checked visually that the first portion has passed the Down branch 'loop clear' marker at Crianlarich, he may then obtain permission for the second portion to proceed towards Upper Tyndrum and then authorise it to proceed.
Up trains to be combined at Crianlarich - Up trains from Upper Tyndrum must be accompanied by Pilotman A between Upper Tyndrum and Crianlarich. On arrival at Crianlarich, Pilotman A must proceed on foot or by road to Crianlarich Lower GF. Up trains from Oban must be accompanied by Pilotman B as far as Crianlarich Lower GF where he must detrain. Pilotman A must then, with the authority of the signaller, conduct the train from Crianlarich Lower GF on to the rear of the front portion at Crianlarich. After both portions have been coupled together, Pilotman A must then obtain permission from the signaller and then authorise the combined trains to proceed to Ardlui (or south thereof).
Dividing and combining trains - In each case, Pilotman A must issue a separate Pilotman's Written Authority to Proceed form to (a) allow the train to proceed as far as Crianlarich and (b) allow the train to proceed beyond Crianlarich. The signaller must record the time at which each train enters or leaves the section as shown in clause 4.1 of the RETB Working by Pilotman instructions for each written authority.
Dated: 30/01/16
