Chris172
- Joined
- 3 Feb 2018
- Messages
- 120
Do you think CrossCountry will get 800s in the new franchise in bi mode as I would love to see a class 800 coming through birmingham
Last I remember this topic coming up the sticking point is that XC operate primarily away from wires. Whereas GW are the other way round. And the 800 is designed more for under wire use and not extended periods of high speed running under diesel.
Could Hitachi modify the design if wanted? Probably. But would XC pay for it over some other design? Dunno. And then you'd have to deal with the procedure/hardware for doing the switchovers as it sounds like to do the switchovers at speed the catanery needs special tensioning.
Most Cross Country routes probably operate more under the wires than the 800`s doing Paddington - Penzance will !
The exception is Leeds - Plymouth but Edinburgh/Newcastle - Plymouth has a reasonable amount of under the wires running.
But what if that couldn't be achieved due to power supply constraints?if class 800/802s are ordered for XC, what length do you make them? There's been plenty of talk on forums about the performance away from the wires, but I haven't seen anything about what could be achieved. Given that the end vehicles contain the driving cab, the pantograph, transformer and electrical switchgear, these don't contain traction equipment. A 5-car set has 2 of these and 3 powered vehicles; a 9 car set has 5 powered vehicles in addition to the 2 driving/pantograph/transformer cars and 2 dead-weight trailers. Now if these 2 were to be equipped with traction gear, for an extra couple of tonnes of engine and traction gear you'd have an additional 1880 BHP available on diesel. Attractive? You bet!
Those two criteria would certainly require a step change in thinking by whomever is chosen to operate the next Crosscountry franchise!I don't like the largely airline seating layout of the GWR units, but a future build could have mainly facing seats at full size tables.
I don't like so-called intercity trains without a buffet, but future cross country units could have a buffet.
There's issues with trains longer than 9x23 metres calling at selected stations served by Crosscountry network, though it would depend on which routes AT-300 series trains were deployed on, and I suspect that lengthening works for the GWR IEP programme might also reduce some such limitations.Any future order for cross country should in my view consist entirely of 9 car units, so as be mechanically identical to the GWR trains, no development costs, simply build some more identical to the existing fleet (apart from internal fit out)
I suppose how many trains might be ordered will depend on how big the cheque book will be for the "Cinderella" of intercity franchises, with a different revenue and demand profile to the London-centric operators. Though recent franchise awards have proffered some pleasant surprises.i would replace the voyagers with 800s to improve the passenger experience for a start. Then voyagers can be shifted onto longer distance DMU routes replacing 158s etc.
We need to be stringing the wires up, really. I get why we don’t want to be running DMUs under the wires, but bi-modes are both under-powered DMUs and overweight EMUs; which means you’re always carting around more weight than ideal so you use more fuel/electricity to shift it and is less “track friendly”.I'm not sure 9x26m is necessary for XC. I would support 7x26m with the option for a follow on order to extend to 8 in case it proves that there is substantial suppressed demand caused by overcrowding.
Certainly I support the use of bi-modes - XC is going to be operating on non-electrified routes for the foreseeable future, and we do need to stop running DMUs under the wires.
I'd wholeheartedly agree with that.I'm not sure 9x26m is necessary for XC. I would support 7x26m with the option for a follow on order to extend to 8 in case it proves that there is substantial suppressed demand caused by overcrowding.
It's entirely plausible that it might be no better to have 5 powered vehicles than 7, if the weight to power ratio is the same for both.
maybe even 6 but the option to extend to 7/8 or more needs retaining if the demand calls for it. Are we talking here of ending the practice of running sets in pairs during peaks? This would impact greatly on platform lengths required, and as a consequence where pairs could run.
Probably as easy as it is to have shoe gear on the 395s, also members of the AT300 family.How feasible would it be to bolt shoegear onto a class 800 for the 3rd rail sections?
Agreed. Only one route, (once Guildford dropped), about an hour or so average running time from Basingstoke to Southampton 2 tph or Bournemouth 1 tph.I suspect, however, it won't be seen as worth doing for the relatively few 3rd rail routes that XC run.
Im going to be unpopular and suggest that the easiest, and chepeast way to solve the capacity issues is 2+5 HSTs
No way! 2 + 8 HSTs please, for the busiest runs and free up Voyagers for strengthen other trains.Im going to be unpopular and suggest that the easiest, and chepeast way to solve the capacity issues is 2+5 HSTs
Besides, I think the 800/801 number range was only for units ordered as part of the Intercity Express Programme.Dare I mention Bombardier's eVoyager proposal? Would provide one new carriage per unit at least...
In answer to the question: bi-modes for XC? Yes. 800s for XC? No, but maybe 802s or some other bi-mode (see above).
2+6 perhaps? That would give the increase in seats that XC desperately needs, without overly impinging on the capacity and timetable. I'm sure a few TFs could be converted into TSs if needs be.2+8 will never keep up with the existing timetable, and a total recast again is going to cause all sorts of problems.
2+5 HSTs are available in large numbers and could displace the entire 4 car 220 fleet with ease.
The eVoyager programme could work if the will to install jigs for the Voyagers & Meridians at Litchurch Lane is large enough. Remember - they were built in Bruges, not Derby, and the jigs have since been removed from Bruges.
