Colwich junction is a major bottleneck on the WCML, since the down fast towards Stoke crosses the up fast on the flat as it comes from Stafford. The arrival of HS2 Phase 1 at Handsacre will exacerbate this with more intercity trains per hour scheduled in addition to existing freight and local stopping services.
With Phase 2 unlikely to go ahead in the foreseeable future, would it be feasible to reconfigure the lines between Handsacre and Colwich so that the lines are paired by use rather than direction? This would reduce conflict between HS2 and classic line trains, albeit with some new challenges to consider:
- Trains coming off HS2 at Handsacre would only be able to access the line to Stoke, therefore any trains going to destinations other than Manchester would need to be routed via Alsager (with that line double tracked).
- You could mitigate the above by providing a crossover to allow HS2 trains to run direct to Stafford, but this would cause conflicts with down fast (HS2) and up slow (freight and classic) trains.
- Alternatively, making the above grade separated would mitigate this but at considerable extra cost. If you changed the spec of HS2 to have the chord at Huddlesford (near Lichfield) instead of Handsacre, the HS2 tracks would end up on the south side of the WCML, making it easier for those trains to access Stafford direct.
- Rugeley Trent Valley station would need to be rebuilt to take into account the new track pairings. Alternatively, the existing platforms could remain, but would be served by completely different services in each direction (which would be absolutely ludicrous).
