Should the class 60 be fully restored to frontline service?
aaronoxford77
22 May 2015
Do the "Tugs" have a place on today's railways? I think they should be fully reinstated. Massively powerful and given the right treatment could be around for years to come.
RichmondCommu
23 Feb 2010
Richmond, London
How would you find work for all of them? If I recall correctly Brush built 100 class 60's and yet I don't suppose that any more than 50% are in use at the moment. The reality is the only growth area of freight is Intermodal and I would have thought that class 66's are far more suited to that kind of traffic.
D365
29 Jun 2012
Should be restored, yes, it's a right shame to see a decent and useful locomotive class wasting away.
Will be restored; I'm not sure they will find enough work/demand.
61653 HTAFC
18 Dec 2012
Another planet...
They have had something of a revival in the last 18-24 months, I imagine it's possible that a few more could be revived. But all 100? Not a chance, sadly*.
*=unless the mythological 75mph upgrade has legs! ;)
aaronoxford77
22 May 2015
Having spoken to a DB driver, he seems to think that the 1st scrappings could well start this year. It is a shame but many have been o.o.u for years now. The 66's are fine but some of the traffic that they are expected to haul are simply beyond their abilities. A point that was witnessed last year when a 66 was on the iron ore train and it went bang. There is plenty of work for them, if not all 100 more should be reactivated.
CosherB
23 Feb 2007
Northwich
If DBS didn't own 90 of them (with Colas fortunately getting their dabs on 10) then I'm sure more would be in front line service. I daresay that DBS aren't going to offer them willy-nilly to the likes of Freightliner, GBRf and DRS ......
aaronoxford77
22 May 2015
It just seems so wrong that lines of them are rotting away while companies are short of traction.
Strathclyder
12 Jun 2013
Clydebank
Do you know the cost to repair these?
Taking an uneducated guess here, but it would be above £350k or more each, at least.
Plus, I don't think there would there be enough work/demand to justify bringing them all back....
As much as I'd like to see all of the 'Tugs' operational again, I honestly can't see it happening, sadly....
E: CosherB beat me to it.....
455driver
10 May 2010
The ones that have been done up didn't have extra holes in the side of the engine though so that is another cost to be added on with quite a few of them.
aaronoxford77
22 May 2015
Its expensive but not nearly as expensive as letting millions of pounds rot when others could use them.
66Yorks
17 Apr 2015
I agree it does seem wasteful that a decent loco is being left to ruin. I see them on steelwork trains and that's about it. Otherwise it's 66's where I live.
al.currie93
27 Jun 2013
You're right there, in fact I think it's even less in service (around 25, possibly a few more). The 66s, while people may dislike them, can haul the majority of freight trains to the majority of places without incident. The 60s only better them for super-heavy trains, which there aren't that many of these days. However, as has been highlighted, the 66s are often used on trains more suited to 60s...
I agree with this, it's wrong to see them rotting away, but as you and RichmondCommu have said, there probably wouldn't be enough work for them, definitely not all of them! Unless there's growth in super heavy freight train requirements, then it's a case of seeing the 60s rotting, or or using them in place of the more suitable 66s and seeing them rotting instead, sadly.
D365
29 Jun 2012
Unless there's growth in super heavy freight train requirements, then it's a case of seeing the 60s rotting, or or using them in place of the more suitable 66s and seeing them rotting instead, gladly.
I know what you're thinking really ;) I do agree that it's a shame to see any useful locomotive idling away because of over-provision, but seeing as the main victims have been the fleets inherited from BR...
Also this vast quantity means the 66s can double-head where a 60 or an electric locomotive might have been more economical. As I understand it this has been influenced by internal politics; the conditions on the lease for the GM imports and the minimal spending on upkeep of the ex-BR fleet.
NSEFAN
17 Jun 2007
Southampton
Welcome to accounting. Sometimes things seem like a waste until you look at the costing, and given DBS is a business you can be pretty sure that they've not let the class 60s rot just for the lulz. The class 60s have their place but there is in general a push to move away from slow freight because of the capacity it takes up. For example, Freightliner have purchased class 70s because they are 75mph locomotives with a higher tractive effort than class 60s. Why reduce capacity with an older slower locomotive when you can have a faster, more powerful and newer design instead?
If it turns out a fleet of trains is no longer required and cannot be repurposed, regardless of their condition, then the best option is to dispose of them (provided they are not needed later for new traffic flows). If the locomotives are relatively modern and/or in good condition they can be sold to other operators (see class 60s with Colas or class 87s in Bulgaria). Otherwise, you're perhaps better cutting your losses and selling them to make razor blades and baked bean cans!
DownSouth
10 Dec 2011
Is there any foreign FOC who could make use of some?
Not when there is such a plentiful supply (including spare parts) of GE Dash 8 and EMD JT26 or JT42 locos of roughly the same vintage.
There are even a number of companies around the world which buy up US domestic locos being disposed of by the Class I Railroads (Union Pacific, CSX etc) just for the powertrain, which they then reuse on new-build frames more suitable for places where the loading gauge is tighter than US standard.
Were I running a small freight company somewhere and in need of something like ten locomotives, buying Class 60 locos would be nowhere near as good a deal as, for example, the DL Class locos that Pacific National (Australian mainline intermodal and bulk freight operator) is rumoured to be disposing of in the next couple of years. While the DL Class is a very small fleet in its own right (only 15 built, two wrecked in crashes) it can be considered to be part of a much larger fleet than the Class 60 as it uses the EMD JT42 powertrain which was built in thousands (the Class 66 is one of many locos which are a JT42 under the body) and is still supported by Progress Rail today. I might even consider buying all 13 of the remaining DL Class to get better terms from Pacific National for taking the whole class and to get three locos I can gradually dismantle for spares.
SpacePhoenix
18 Mar 2014
Could the 60s realistically be rebuilt for either passenger work or for faster freight working?
Could we see any examples enter preservation at all (even if its only 60001 - if it still exists)?
Would they be any good for working on engineer's trains - maybe on the construction of HS2 - if that goes ahead and enough of them survive that long?
Boothby97
24 Apr 2011
Grimsby
60001 is alive and well, its actually operational
CosherB
23 Feb 2007
Northwich
1. No.
2. I'd have thought 60100 would be more deserving of preservation as the last UK built diesel loco.
3. Maybe, but all ifs, buts and maybes.
DarloRich
Fenny Stratford
to what purpose? Is there work for them?
I also think you have little grasp of economics! :roll:
It is a shame that such a useful (and nice to drive) engine like the 60 should be sitting idle. To be fair, the argument that 66's are more useful doesn't really stack up when all you are hauling is a class 6 train limited to 60mph. For a class 4 train then obviously it has to be a 66, but for a train limited to 60mph or less, then why not use a 60?
I was under the impression that 60s are good for getting going with heavy loads, but are a bit lacking getting up to speed, which is why then end up on the tank trains. On a load of around 2000 tonnes, what would be better at getting up to 60mph and staying there? the 66 or 60?
richieb1971
28 Jan 2013
I read from a google link that all the 60 fleet could be put back into service if the demand was there for it. Apparently a lot of the fleet have weathered better than expected.
It is sad that DBS have a hold on them. That leasing company in Leicester should be allowed to do them up to lease them out when required.
richieb1971
28 Jan 2013
I do not know the ins and outs of how DBS procured the 60's and what the contract actually entailed. But if a company procured these loco's on the basis of a bigger deal it should have been written in the small print that any loco laying dormant for a period of time should be sold of.
In the car market if you have a working car sitting idle you move it on whilst it has value. I don't know of any assets that are left to painfully deteriorate to nothingness. This is engineering cruelty at its finest.
Domh245
6 Apr 2013
nowhere
DBS inherited them from EWS, who inherited them from their purchasing of the pre-privatisation railfreight companies. They had been procured by BR for hauling heavy freight at 60mph, but EWS obtained lots of 66s as well, and they could start to run down the other classes of locos, eg 58s, 47s, 37s, etc. Being the outright owners of the 60s means that if they sit rusting away in sidings, it has no effect on DBS as they aren't short of locos, and aren't losing money through maintenance. If they sold them on, it would be to a competitor, which obviously isn't in their business interest.
LWB
31 Dec 2009
Are we not facing a problematic time due to our unique loading gauge and ever tightening emission directives from Europe? Where will our next freight class come from? Perhaps rebuilding offers a way to circumvent eco considerations.
