BicBasher, since you regularly post misleading information, can you post the excerpts from that document so that we can take a look?
Why are you jumping on everything he said? It's clear your havent got anything to back your view up expect your opition where Bic has.
You do realise that cutting the Inner SLL is due to Thameslink works at London Bridge not anything to do with the ELLX don't you?
Hardly support what you've previous said.
Enough of your name calling as clearly you're saying that because you're unable to debate the issue properly when challenged. Trolling doesn't apply to me.
I'm sure the planners are fully aware about the SLL issues. There's a difference between optimum service and disregard for South Londoners. I suspect the latter.
That map is based on the Jacobs report for the DfT. it's now semi offical map as it was sent to the TOC's and sent up on thier website. It recommended that Thameslink and Southern be merged for cost saving reasons and low and behold it was.
Considering you say your not a troll, you seem to insult anyone who doesn't share your view over the future of the SLL rudely. Have you been keeping up with the work over the SLL? It's been looked into a lot but end of the day it's fairly lightly used on some very busy tracks outside of the peaks.
I remember seeing a Thameslink 2019 document which suggests that they'll replace services from Caterham (and poss Tattenham Corner) which currently use the terminating platforms, although it'd raise concerns about stopping services on the Sydenham slow to East Croydon.
Any document is out of date now as part of the new Thameslink franchise bid was to suggest what the service pattern post 2017 will be. However by 2020 when new replacement franchises come in for Thameslink/Southern and Southeastern we may see some massive changes yet.
The currently open consultation on Thameslink new franchise may provide some new information but the announcement on the first set of routes from the expanded Thameslink services will be announced in summer 2013. (Informed law at work here)
Note as well that the idea has been that the destinations served by the 'Thameslink' Core trains is supposed to be flexible to allow changes in the future to help balance services out more and go where people truely want it to.
