Sidings Near Dartford Crossing Seen From HS1
TheJRB
14 Feb 2011
Ashford, Kent
Every time I travel on HS1, I always see a Freightliner 66 stopped in what appears to be a siding just beyond the Dartford Crossing near Purfleet. Consulting the Rail Atlas 12th Edition, Purfleet Thames Terminal (Deep Water Wharf) seems to be around the right place but from what I can tell it's DB Schenker that uses that. I must say I'm now rather confused. If anybody could assist, it would be much appreciated.
carriageline
11 Jan 2012
Is it possible FL have rented out the loco to DB? I know the same as you do! So could be "barking up the wrong tree", unless separate companies can stable locos there.
Never seen that siding though, although the one I have loved since I was younger is the big yard after the strood tunnels, think it is in Hoo. Remember always going through it on the way to Bromley south (god knows why that happened?) and the train always stopped to let a driver (I presume!) off the train!
Still love seeing it as you shoot theough
spurs4life
27 Apr 2011
Your got four sidings there's deep wharf siding, foster yeoman siding,la farge marine terminal siding and Moyer than likely the one you have seen is Thames matex siding.
