Signal Passed at Danger (SPAD) and near miss at Sileby Junction 05/05/2021
DerekC
26 Oct 2015
Hampshire (nearly a Hog)
RAIB is investigating a SPAD and near miss at Sileby Junction:
https://www.gov.uk/government/news/...ae71-4ea8-9a8f-8a0cd3b01f3a&utm_content=daily
At around 05:29 hrs on 5 May 2021, a train made up of machines used for reprofiling (grinding) rails, travelling on the down slow line near Sileby, passed signal LR477 at danger by about 350 metres. The signal was at danger because a train of empty coaches, travelling in the opposite direction, was crossing the down slow line ahead to move from the up fast to the up slow line.
The rail grinding train came to a stop fouling the junction over which the train of empty coaches had passed, less than ten seconds earlier.
RAIB’s preliminary examination has found that there were no technical faults in the trains or the signalling equipment. The brakes of the rail grinding train were applied by its driver and by intervention of the train protection and warning system (TPWS), but this intervention did not stop the train within the safe overrun distance, and allowed it to reach the conflict point at the junction.
Our investigation will seek to identify the sequence of events which led to the incident. It will also consider:
  • The management of the grinding train driver’s competence and fitness
  • The design of the signalling on the Leicester to Loughborough section of line
  • The effectiveness of TPWS in circumstances where train braking rates are lower than those used in calculations relating to the design of the system
  • Any relevant underlying factors, including the rail industry’s response to RAIB’s recommendations made in previous reports involving train driver fatigue management
Our investigation is independent of any investigation by the railway industry or by the industry’s regulator, the Office of Rail and Road.
We will publish our findings, including any recommendations to improve safety, at the conclusion of our investigation. This report will be available on our website
Trackman
28 Feb 2013
Lewisham
I read about this, certainly a very close call.
I wonder if the driver saw the ECS train?
MarkyT
20 May 2012
Torbay
This part of the initial statement from the RAIB is interesting:
Suggests they are already aware of a problem with the braking rate of some train types and formations.
Efini92
14 Dec 2016
The signal protecting the movement left very little margin for error. Even the best braked trains would’ve ended up in the conflict point if they’d passed the signal.
The report into the nearby near-miss at Barrow-on-Soar cited excessive speed by a train with less than normal braking.
Is there any particular reason a train like this can't achieve the normal braking performance?
Or is just longstanding practice that they don't need to?
4F89
17 Aug 2018
Because they have high weight and **** brake force
LAX54
15 Jan 2008
Reduce the maximum permitted speed from 60 mph to 45.
Back in the day they were always 7Z02 or 7Z09 if not guaranteed to occupy track circuits, there were very few class 6's, but they were a pain to get from A to B in general traffic.
Nottingham59
10 Dec 2019
You'd have thought that a rail grinding train would be a perfect candidate for friction track brakes, wouldn't you?
For emergency use only, of course.
trainmania100
8 Nov 2015
Newhaven
350m is quite an overrun, I'm assuming there would have been at least one caution aspect beforehand giving enough time to slow down? Very unusual if the driver signed the route and knew where the signals were. Even if the driver didn't know where the red signal was, the caution aspects should have given more than enough warning - will be interesting to see the outcome
GB
16 Nov 2008
Somewhere
Trains are driven by humans and its entirely possible to see the cautionary aspect and not react to it or the red....it does happen. Add the less then optimum braking characteristics, potential issues with TPWS calculations and the fact the fouling point is apparently not that far away then it all adds up to potential problems.
24Grange
7 Jan 2021
Baldock
Do you get disciplined for a SPAD ( if it proves to be your fault) or fired or some other sanction - retraining?
GB
16 Nov 2008
Somewhere
Depends on the circumstances and drivers previous record but none of the above is off the table.
