Signaller Round 2 Assessment centre
MG65
18 Apr 2016
Worcestershire
Apologies if this has been discussed previously. I have been informed today that I have passed the SJT's and have been invited to an assessment centre to sit a number of tests for the role as a Grade 3 signaller. I have a copy of the recruitment information booklet that outlines the types of assessments I can expect.
Can anyone who has sat these assessments recently give me some tips or pointers on sitting the assessments. What to look out for etc. I am particularly nervous about the fault finding assessment
Secondly I assume that if i am successful and get called in for an interview , the interview will be on another day? or does it take place later the same day as the assessments?
Many thanks
mresh91
30 Aug 2013
Interview is on another day, usually a few months down the line even! From the assessments, X number of highest scoring candidates who passed get through to the interview stage. If you have ten candidates and they all pass, then only the five highest scoring will get interviews, something of that sort.
As for the test, they're relatively straightforward, if you're not sure be sure to ask them as they'd go through it and won't start unless everyone is clear and on the same page. The faultfinding test I done involved a train track, different lenghts of trains and the different signals which will apply to the trains involved. I can't explain it properly here, but it's by far the easiest fault finding test I've done.
As I said, go through the booklet and you'll be fine. On the day of the assessment, if you're unsure in the slightest, ask them. And the only one true advice I can give you is if you're doing a high/low tone counting exercise, USE your fingers if it helps you, I know it certainly did help me.
MG65
18 Apr 2016
Worcestershire
Thanks for the response mresh91-most helpful. I have been in the same job for 20 years so the whole new job interview process is a distant memory for me.
142094
7 Nov 2009
Newcastle
Might still be the case but the interview I had was done by the local Mobile Operations Manager for the signal box, and was a good few weeks after the assessment centre.
nom de guerre
24 Nov 2015
Usually, interviews are done by the LOM (Local Operations Manager) plus an HR person.
