I did promise to put something together a little while ago, so here goes. It's handy proof-reading of the wording of a couple of questions if nothing else . All questions refer to an Absolute Block in this case.
1. The Signalman at B has accepted a train under AB Reg 3.4 from box A. A shunt movement requires to occupy the clearing point at B - when can this movement next be allowed to do so? (4 possible answers)
2. The Signalman at B has obstructed the clearing point from box A with a shunt movement, sending (and receiving acknowledgement for) 'blocking back inside home signal' to A. Describe the actions of the Signalman at B, if the shunt movement is to be allowed to move outside the home signal.
3. With which bell signal would you acknowledge the 'obstruction danger' bell signal from the box in advance, if a train was closely approaching your section signal at speed?
4. A train, failed in section between A and B, has cleared the section by being assisted back to A. What position would the block indicator be at, and how would the next train be signalled?
5. A train, failed in section between A and B, has cleared the section by being assisted (from the rear) forward to A. What position would the block indicator be at, and how would the next train be signalled?
