Signals on the network
Gathursty
31 May 2011
Wigan
How far apart are they spaced? In particular how quick would you pass from one to the next on a Pendo/Voyager service on the WCML?
michael769
9 Oct 2005
Depends!
Typically the higher the line speed the wider the spacing - indeed in many cases it is the signal spacing that dictates the line speed.
But the type of signalling also has an impact - 4 aspect signals are usually closer together than 2 aspect ones.
The goal is that a driver on a train travelling at full linespeed should, upon seeing a caution aspect be able to stop his train before passing the signal at danger without having to apply emergency braking.
This seems to be the latest standard for signal spacing
It's a somewhat complex calculation to say the least.
Green to Green aspects (ie: a technical headway) can be as low as 75-80 seconds on parts of the southern WCML.
Rwhunited
10 Jul 2011
Lancashire
The signals are spaced differently dependant upon linespeed, minimal is the braking distance of the worst braking train to stop at max linespeed, then if you add a double yellow into the mix then its 2 signals apart
jopsuk
13 May 2008
on the London Underground, who run quite different principles for their signalling, signals on approach to a station can be much less than a train length apart.
Meanwhile, out in the wild worlds of rural lines, semaphore signals especially can be quite some distance apart
Indeed, stand to be corrected but I think Carnforth to Settle Jn is one of, if not the longest block sections. I know we plan it as AB. That has to be 25 miles long.
TDK
19 Apr 2008
Crewe
Not many signals are the same distance apart as there are many factors considering signal spacing.
1. Line Speed
2. Gradients
3. Sighting
4. Number of aspects
5. Braking distances (related to all the above)
I would say the most governing factors are line speed and gradients - some signals can be more than half the distance apart on an up gradient opposed to a down.
notadriver
1 Oct 2010
Surely the braking distance from full line speed is calculated based a train braking at a yellow signal to the red signal, not on sighting the yellow?
notadriver
1 Oct 2010
t
Apparently tube driving is very different in that they drive 'on sight'. No cautionary aspects. It's either green or red.
I would have expected it to be off the sighting distance otherwise where would the driver reaction time come into it ?
ralphchadkirk
20 Oct 2008
Essex
No, they have repeaters. It's standard two aspect signalling IIRC.
Sent from my iPhone 4 using Tapatalk
TDK
19 Apr 2008
Crewe
Sighting does come into the factor, if a signal is going to be a very poorly sighted signal it will be placed in a more suitable place
notadriver
1 Oct 2010
The 'drive on sight' comment comes from someone I know who has ridden in the cab of tube and NR trains but who isn't a driver. He said that a train could be driving at full line speed on green signals and still be able to stop if the next one was red.
jopsuk
13 May 2008
Perhaps mixing up "being able to see the train in front all the time" with "drive on sight"? Drive on Sight is what Trams do on on-road sections, where they follow much the same rules as cars...
Cherry_Picker
18 Apr 2011
I think you should take that with a pinch of salt. I cant speak for the entire underground as different systems exist on different lines, but I sign the fast lines of the Met between Harrow and Amersham, and I can assure you that it is clearly not true. Yes, there are parts where the line speed is < 40mph and you can almost certainly stop before a red after running on greens and there are sections where you will be looking at the tail lamps of the train in front of you (this also happens a lot on the busier sections of the National Rail network too)but the signalling system cannot rely on working like that. The parts of the Underground I know well have a very similar to heavy rail two, three our four aspect signalling system.
Surreytraveller
21 Oct 2009
But sighting distance would vary depending on the weather. The train would still take as long to stop if it was foggy as it would if the weather was clear, so therefore the stopping distance would be from the signal, not from where it is sighted.
There's a signal box part-way at Wennington, don't know if it is operational though.
Railsigns
15 Feb 2010
The longest I know of is Blair Atholl to Dalwhinnie which is 23 miles.
Yes, but there are two sets of I.B. signals in between, so it's not a case of this being a 23 mile stretch of railway without any signals.
Metroland
20 Jul 2005
Midlands
Indeed, it's all to do with sighting distances. My understanding is on some sections where the line speed is very slow, and you can clearly see the stop signal ahead there is no repeater - unless it's a fog repeater. But generally the underground does have warning signals in much the same way as Network Rail.
http://www.trainweb.org/tubeprune/signalling3.htm
Anonywave
19 Sep 2010
although, of course, they do have those banner (repeater) signals (whatever they call them)
