To each their own, you'll just have to find a way to store your "bog roll" tickets then as the tide is very much against pieces of orange cardboard.
Typical of today's railway to jettison anything that's actually well designed and works.
I'd rather they just gave me a proper train ticket.
The thing is, they don't work well. Look at all the issues that they cause by being unable to clearly store and/or display routeing, TOC and time of day restrictions, they cause no end of grief for carnet users, season tickets wear out before the end of validity, Rovers can't work barriers, magnetic strips get de-magnetised, they get stuck in TVM machines, it's a pain to make changes to advance purchase tickets...Typical of today's railway to jettison anything that's actually well designed and works.
one where you can't get treated like a criminal when the battery runs flatWhat century do you live in?
If that's your concern:one where you can't get treated like a criminal when the battery runs flat
Bring back Edmondson cards!
E-tickets and smart cards, properly implemented, avoid all of these issues.
That’s what I did last summer when I had the misfortune to be sold an Explore North Wales Rail Rover on one from the ticket office at Crewe.I don't like the bog roll tickets, but I just fold them in half and stick 'em in my wallet.
Simple.
Well, they would be preferable to the bog roll type.
I've had no trouble reading routing and restrictions etc on them.
Barriers that don't read rovers etc are that way because they haven't been programmed properly. This means that they still won't read rovers electronically if they haven't been programmed properly (in the same way that the barriers at Wakefield Westgate don't read my plastic zone 3 metrocard because - surprise surprise, no one can be bothered to programme them properly).
The only "pain" I have in making changes to AP tickets is the £10 admin fee !
However if your excess does get issued as a bog roll ticket and comes with a barcode on it, more often than not it will open up the gates!No changing advances is awful, you end up with 3 sets of tickets instead of one! Then the excess won't open any barriers, which is ahuge PiTA if you're in a hurry.
I had thinking of saying the same, as they would seem to best meet Yorksrob's needs.Bring back Edmondson cards!
No, it's because the ticket simply doesn't hold enough information.Barriers that don't read rovers etc are that way because they haven't been programmed properly.
Go on then, is a ticket with the routing restriction "NOT VIA LONDON" valid via London? In many cases, yes it is. Not confusing in the slightest.I've had no trouble reading routing and restrictions etc on them.
Even online purchases, after you've collected them and need to make a change the day before travel?The only "pain" I have in making changes to AP tickets is the £10 admin fee !
I think you'll find it's the other way around - the barrier at Manchester is simply more permissive.Nonsense.
The barrier at Leeds has never read my South Pennine Day Ranger whilst the one at Manchester Victoria always has. This is because the one at Vic has been programmed properly.
I don't deny that it's the routeing guide at fault. The question I'm asking is if you can honestly say that the current ticket format is the best possible way to display the complexity or if, perchance, a new format could explain it better?Not Via London, and the wonders of the routing guide, are not the fault of the existing ticket format. They are the fault of train companies continually trying to restrict routes that are reasonable.
It's a good job you can get ticket wallets designed for them then isn't it?.Even if you fold it, it's too wide for the wallet. And the more times you fold something, the less likelihood it will be readable.
Even traditional card tickets aren't immune to this issue, which is why we have ticket wallets in the first place.
The paper bog roll design just isn't suitable for tickets sold in advance.
My preferance would be for the 1990's frankly.
So does a PRT if you fold it....It is, but it helps that they are all pocket sized. If one didn't have a ticket wallet, an ordinary ticket would fit easily into a conventional wallet as well.
You won't mind till roll tickets then, surely, as that's all you got off a SPORTIS
The thing is, they don't work well. [...]season tickets wear out before the end of validity
I agree. Season tickets shouldn't be on card/paper at all. They should really be on smart card.It will not open the gate in the wallett and needs to be removed and refolded after use. After 2/3 days these tickets start to look shabby; there is no way I would want one for a season over a week.
