Southeastern Assessment centre (Train driver)
TTracks
17 Jun 2021
Hello all,
I’ve recently applied to become a Trainee Train driver and have successfully passed the screening process. I have now been invited to attend the assessment centre which is in 2 weeks time.
I was wondering if anyone had any tips for the day? And what to expect.. also any practise material out there I could purchase and read up on?
Thanks in advance!:)
Gorlash1886
17 May 2018
Do a search at the top of the forum there is a massive chain about southeastern that should have all the info you need buddy, good luck with the assessment day, best advice I can give is ask if you are unsure of what is needed on the day.
TTracks
17 Jun 2021
Thanks for your reply!
JadeMClememts
30 Oct 2021
E1w 2qj
Hi I have also been invited to the assessment center but has been rescheduled. The information pack provided will give you a run down on what to expect to do on the day
tests of attention;
a trainability/memory test;
a test of vigilance;
a test of perception;
a test of hand co-ordination;
a written communication test;
a situational judgement exercise;
a structured interview.
Good luck
Applepie356
23 Sep 2019
Group Bourbon test: Look for the tool that is stickied to the top of the forum. It’s extremely helpful and I’d advise printing them out and timing yourself to see how many lines you can get done.
MMI: You will get asked 6 questions and they are the same but can be worded differently and in different order.
1) A time where you had to follow rules and procedures
2) A time where you done a role similar to train driver
3) A time where you handled an emergency situation
4) A time where you worked for long periods of time alone
5) A time where you have been on training course for 2 weeks+
6) A time where you have solved a difficult problem
Be aware that they will be worded differently, for example question 5 could be “A time where you had to persevere to achieve a goal” or something like that.
You should also get sent practice material at least 7 days before the test day. Some people find it helpful, although it’s important to note they will be a bit different to the actual test.
Above all, if you don’t understand always ask before the assessor starts.
