Southeastern employee apologises for their crappy ticket barriers
Discussion in 'UK Railway Discussion' started by talldave, 20 May 2015.
Thread Status:
  1. talldave
    talldave Established Member
    1,373
    24 Jan 2013
    As my ticket was once again rejected by Southeastern's HS1 ticket barriers at St Pancras yesterday morning, I decided to enquire why....
    "Is my ticket valid?"
    "Yes!"
    "So why do your ticket barriers reject it?"
    "I apologise for the crappy ticket barriers..... we have so many tickets to upload, we're busy uploading..."
    I don't believe that final statement - I suspect they just don't give a ****.
    I continued on my journey and the Underground barriers accepted my ticket without any problem at all.
    On my return journey (actually another single, going the other way), the St Pancras barriers rejected it, as did the barriers at Stratford International where I broke my journey. The suggestion at Stratford was that the starting station wasn't a Southeastern station so that was probably why the barriers were rejecting it. Finally, back at Gravesend, I had the satisfaction of seeing the ticket open its first barrier of the day!
    A tedious experience to say the least, although slightly compensated for by my technique of buying a ticket to somewhere I'm not going saving me money.
    So, if anyone from Southeastern is reading - sort your crappy barriers out, because it even winds up your own staff.
    Rail Forums
  3. Blindtraveler
    Blindtraveler Established Member
    7,691
    28 Feb 2011
    I needed a laugh so thank you Sir! I assume both STP and Stratford barriers have both been there for a while so it cant just be teathing problems with new equipment? Still seams a poor show though
  4. Seaeagle
    Seaeagle Member
    57
    30 Jun 2013
    Chatham
    I have similar issues at both St Pancras and Stratford. Arriving at both stations, the barriers accept my ticket no problem, but neither will accept my ticket on the return journey.
  5. collism
    collism Member
    6
    20 May 2015
    I'm pretty sure the Southeastern St Pancras barriers only let through tickets with the PLUS HIGH SPEED routing, everytime I have been travelling through London with the ANY PERMITTED routing, the ticket never goes through the barrier and has to be manually checked.
  6. PHILIPE
    PHILIPE Established Member
    8,409
    14 Nov 2011
    Caerphilly
    Has he had the sack yet for being honest ? I sincerely hope not.
  7. ComUtoR
    ComUtoR Established Member
    4,183
    13 Dec 2013
    I thought he was lying. After all I suspect they just don't give a ****. I have no idea about how barriers work or if there is any truth that tickets need to be uploaded into a database so that the barrier software can recognize and validate the tickets. But it certainly sounded plausible and honest to me.
    Are the barriers owned by SE and is it their software that runs the barriers ? Who is responsible for the ticket database ?
  8. thebigcheese
    thebigcheese Member
    142
    2 Jan 2012
    They do certainly seem over protective on that gateline. I can't remember the last time one of my tickets went through without a hitch - and most of my tickets are routed '+AP'
  9. swt_passenger
    swt_passenger Veteran Member
    16,827
    It has previously been posted in this forum (apparently by someone who works in the relevant field) that the default situation on installation is that a gateline only understands its own location, and no breaks of journey are programmed at all. Any other station availability has to be manually added, there is no automated process to do this.
  10. HilversumNS
    HilversumNS Member
    232
    30 Apr 2015
    Refreshing change, some simple honesty.
  11. DarloRich
    DarloRich Veteran Member
    17,933
    Work - Fenny Stratford(MK) Home - Darlington
    Obviously "a man at the barriers" is an official spokesman for Southeastern :roll:
  12. Ediswan
    Ediswan Member
    301
    15 Nov 2012
    Stevenage
    Stevenage barriers do (or at least did) reject all advances on departure (as I was informed by staff) and some of the local off-peak tickets which are valid during the evening peak on arrival. The staff are well aware of the behaviour of their barriers. Once you know you are going to rejected by the machine, go directly to the human.
    Side note: The evening peak restrictions on local trains look complicated. Thameslink have reworded and made them easier to follow than FCC did. I believe they could be simplified to "Off peak tickets are not valid for journeys from zone B to zone D". http://www.thameslinkrailway.com/tickets-and-fares/off-peak/ Every other pair of zones appears to be covered by one of the exceptions.
  13. Tracky
    Tracky Member
    483
    18 Jul 2011
    I understand barriers have a limited capacity for storing ticket information. I'm assuming they are not "online" and so each one has a solid state memory in effect. The gates at Chester seem to reject TPE advances up to Leeds and Newcastle and treat all off peak tickets as before 9am even the ones valid from 8.30.
  14. WillPS
    WillPS Established Member
    2,320
    18 Nov 2008
    Sheffield
    Good work on giving a frontline member of staff with no power to change the situation a hard time. Bravo.
    I'm off now to have a go at whichever assistant is unlucky enough to serve me at Sainsbury's local about a team of people they have likely never met and never will who've decided to halve the amount of Nectar points I get for shopping there. Wish me luck!
  15. FlippyFF
    FlippyFF Member
    149
    5 Jan 2014
    Ashford, Kent
    So, could it be that the barriers read the ticket and detected that it hadn't been through a barrier at the station you didn't start your journey from but had bought the ticket to start from?
  16. crehld
    crehld Established Member Senior Fares Advisor
    1,980
    1 Nov 2014
    Between Crewe & Hellifield
    If the "man at the barriers" is on Southeastern's payroll, is wearing a Southeastern uniform and carrying out duties on Southeastern's behalf then yes, for all intents and purposes, he is an official representative and spokesman of the company. How could it be interpreted otherwise?
    Unless I'm missing something (which is quite likely) there is nothing in the OP which appears to me as having a go at a frontline member of staff... rather it's just a report of a conversation and in particular that a member of Southeastern's own staff though their barriers were crappy. If anything it seems to highlight the member of staff's frankness and honesty.
  17. talldave
    1,373
    24 Jan 2013
    Not on the outward journey, but the barriers were open at Gravesend so I didn't have to put the ticket through. As suggested by another poster, St Pancras barriers are presumably set to reject any ticket not routed PLUS HIGH SPEED. This would be acceptable if those were the only valid tickets, but they're not. Anyway, I don't believe ticket barriers reject tickets based on which barriers they've been through. And if train companies didn't sell tickets to further afield destinations for less than closer destinations I wouldn't be buying them.
  18. TEW
    TEW Established Member
    4,774
    16 May 2008
    Ticket barriers may reject tickets based on which barriers they've been through, but not on the basis of which barriers they have not been through. A ticket may be rejected due to a 'passback' rule or because it has been encoded as previously having gone through a barrier, suggesting the ticket has already been used.
  19. talldave
    1,373
    24 Jan 2013
    Indeed, I wasn't having a go, and was impressed by the honest reply. If staff higher up the chain expressed similar views we might see changes that would make the lives of passengers easier.
  20. ComUtoR
    4,183
    13 Dec 2013
    Really ? Then why say this.
  21. talldave
    1,373
    24 Jan 2013
    Because the guy I was talking to obviously has no control over the uploading of ticket validities into the barrier. That's done (or not done) by someone else, in the non customer facing "don't give a ****" department.
    Why my scepticism? Well, Southeastern is part of the same group as Southern, so I guess it's ultimately run by more of the same incompetent people I've suffered for the last few years as a Southern customer.
    Full credit to this Southeastern barrier guy though, he seemed as frustrated as his customers and wasn't ashamed to show it.
  22. Greenback
    Greenback Emeritus Moderator
    15,337
    9 Aug 2009
    Llanelli
    The barrier person could have been honest and sincere, while the company itself doesn't care. Front line employees probably find the barriers just as frustrating to work with as someone who's ticket is rejected.
    I'm sure I once had a through ticket marked with the appropriate 'Valid via HS1' wording, that was still rejected. The man at the barrier was very nice, but I got the distinct impression he was a bit fed up with having perfectly valid tickets churned back out necessitating him to open the gates manually for so many people
  23. Mojo
    Mojo Administrator Staff Member Administrator
    16,189
    7 Aug 2005
    0035
    I'm not so sure this is the case; I've had East Coast & Connections and +Any Permitted tickets accepted by the gateline to the Southeastern platforms at St Pancras
  24. Cletus
    Cletus Established Member
    1,541
    11 Dec 2010
    Dover
    Yes, I used a Dover Priory - Coventry (+vtwc @connections) ticket that worked the barriers ok today. Although in the past this hasn't always been the case.
    Also had an advance ticket to Devon earlier this week that worked the barriers ok.
    Also I find "any permitted" tickets also work when going to Potters Bar for instance, but not "south" to East Croydon for instance.
  25. Deety
    Deety Member
    12
    22 Dec 2014
    While slightly deviating from the topic, I thought I had better post something sometime... Hello everyone!
    I have an annual AP season from Brighton to London Terminals, and at the East Croydon bridge exit my ticket lets me out, but not back in.
    I can understand at Lewes where the ticket won't work the barriers at all despite being valid, but having one customer interaction point with different outcomes seems a bit odd. And the one gateline staff member has enough to do without me waving a ticket at him...:lol:
  26. jon0844
    jon0844 Veteran Member
    22,382
    1 Feb 2009
    I've had two people at St Pancras apologise for the machines rejecting valid tickets, maybe one of them was the same person here? This was over a year ago mind. The funny thing is that I was also told the gate software would be updated even then!
    So I'd agree that gateline staff want things fixed and SET as a whole doesn't give a stuff. I'm sure nobody wants to be manually letting people through with valid tickets who are going to be tutting and moaning, and been in some cases potentially missing a train if they're cutting it fine and now have to wait for staff to become available after dealing with others.
  27. talldave
    1,373
    24 Jan 2013
    It does seem unnecessarily frustrating for ticket barriers to cause a backlog of "valid" customers. When I broke my journey at Stratford, the single member of gateline staff was helping another customer with a timetable/platform number issue and I had to loiter by the barriers for a minute or two until that issue was resolved. It doesn't make for a very high speed experience.
    At the risk of taking my own thread off topic, the High Speed experience has got slower since the 17th May - the morning train I sometimes catch is now a minute slower - what's that all about?
    So, a minute added to the journey, a minute or two waiting to get through the barriers, and suddenly the High Speed experience has a 15% increase in journey time.
  28. FlippyFF
    FlippyFF Member
    149
    5 Jan 2014
    Ashford, Kent
    I've noticed the journey between St Pancras and Ashford taking a minute or two longer for no obvious reason - temporary speed restriction perhaps? A bit frustrating when you've only got a minute to make your bus connection.
  29. 185143
    185143 Established Member
    2,758
    3 Mar 2013
    I tried to use the High Speed from Stratford International to St. Pancras today using a travel card, which I now know isn't valid, but as its my first TC bash (!) I didn't know previously. I had an outboundary travelcard and my friend had a Euston-Zones 1-6 one. My travelcard opened the gates yet my friends didn't.
    My travelcard definitely wasn't valid, as I instantly queried whether mine was valid, given what happened to my friend.
    Any guesses as to where the travelcard was from and which route? Its so ludicrous its unbelievable!!
    Just to clarify, I did not travel and was let back through the barriers when the gateline attendant saw my ticket and managed to pop his eyes back into his head:D
    If I had arrived at St. Pancras, what would have happened if it hadn't worked the barriers there?
  30. jon0844
    22,382
    1 Feb 2009
    When I had a Z1-6 travelcard season, and wanted to try out a 395 to Ashford and back, I got a BZ6 to Ashford ticket and paid the HS1 supplement.
    I can't remember how I got through the gateline, but I got on the train and everything was fine until the TM said it was invalid as you can't use Travelcards (even with a supplement) and charged me an excess. The excess wasn't that much, mind.
    To me it's mad that you can have a station (or two) outside the zonal system and a line where Travelcards aren't accepted at all.
  31. 185143
    2,758
    3 Mar 2013
    my travelcard was a Crewe to London Z1-6, Route: LM ONLY!!
Thread Status:
Share This Page
