Southeastern - Greenwich Line - Extending the platforms or not?
Discussion in 'Infrastructure & Stations' started by blakey1152, 27 Nov 2011.
Thread Status:
  1. blakey1152
    blakey1152 Member
    313
    5 Sep 2011
    Noticed today that Southeastern looks to be extending the platforms at some of the stations on the Greenwich line.
    I noticed what looks like rows of breeze blocks at the end of Slade Green, Erith and Plumstead stations
    Does anyone know if it is to definately extend the platforms or some other reason and if there are any other Southeastern stations where this is also being done?
    Chris
    Rail Forums
  3. MidnightFlyer
    MidnightFlyer Veteran Member
    12,827
    16 May 2010
    They are all 10-car as things stand, so I assume they are being taken up to 12. If this is the case then Charlton, Woolwich Dockyard (good luck!), Woolwich Arsenal and Abbey Wood would also logically be extended. Belvedere is already 12-car.
    (All info taken from Nov 2008 Quail Map.)
    EDIT - Plus Deptford, Greenwich, Maze Hill and Westcombe Park too!
    EDIT 2 - And to finish off the three Dartford lines: Bkackheath, Eltham and Mottingham, as well as Dartford itself.
  4. OxtedL
    OxtedL Established Member Quizmaster
    2,319
    23 Mar 2011
    Looking at Route A (2011 version) of this, the relevant bit is:
    So given that June 2012 implementation date, it probably is platform extension work, yes.
  5. burneside
    burneside Member
    212
    12 Sep 2011
    Isle of Dogs, London
    Given the number of shortformed trains that Southeastern are running at the moment I'd be very surprised to see a 12 car train on that line.
  6. OxtedL
    2,319
    23 Mar 2011
    At least the thought is there. :D They're essentially just finishing off a job that was started a while ago.
    Hopefully when this is done they'll reform/extend the 378s 376s.
  7. jopsuk
    jopsuk Veteran Member
    11,895
    13 May 2008
    376s, surely? For 12 car they'd either have to be lengthened to 6 car- surely reform and rebuild into 4 car would be even more work? To 6 car they could perhaps get a second TSO?
  8. WatcherZero
    WatcherZero Established Member
    9,067
    25 Feb 2010
    When 12 car multiple operaration is rolled out all around London, what next? They are already boosting frequency to approaching maximum feasible, are we 10-15 years down the line going to see them planning for 15 car or more trains?
  9. Rational Plan
    Rational Plan Member
    228
    3 Aug 2011
    Well, that's the thing. I think 12 car is the max any line can go to before things get really expensive.
  10. OxtedL
    2,319
    23 Mar 2011
    This is the conclusion Network Rail have reached in their RUSes as well. Beyond 12-car and re-signalling to force more trains through, they only suggest making a break for double decker trains or creating massive tunnels under South London to free up metro capacity.
  11. callumbb
    callumbb Member
    16
    19 Nov 2011
    Will moving to double decker trains be prohibitively expensive at all? They seem to work pretty well in Sydney/New South Wales.
  12. jopsuk
    11,895
    13 May 2008
    Every single bridge or other structure would have to be modified to alllow DD stock with significantly higher capacity and with low dwell times. Ideally the platforms would also have to be further from the rails, and the rails further apart, to allow wider as well as taller, trains.
    There may well come a time when this is the only financially viable option.
  13. DVD
    DVD Member
    59
    23 Jul 2009
    Sidcup
    Mottingham platform extensions have been under construction for a month or two - although work seems to have stopped in the past two weeks. I understand that New Cross can only take 10 coach trains so should be in line for extensions, but work here may be more complex and involve track and signal reconfiguration.
    Main driver for platform extension to cope with 12 car stock on the Dartford lines (mooted in early Networker days, late 80s & early 90s) is supposed to be the London Bridge rebuilding which will cut capacity through London Bridge and mean that the main way to enable peak hour passenger levels to be maintained is to run fewer but longer trains.
    Incidentally a few months ago I bought some ancient copies of rail mags (1950s) and was fascinated to note that there was talk of the need to run 10 car trains on what is now South Eastern lines. Over 50 years later and still the average SE train is 8 cars in peak hours, with only a handful of 10 car services.
  14. 150222
    150222 Member
    1,002
    9 Jul 2011
    Yes let's not take ideas from the 4-DD. ;)
  15. jopsuk
    11,895
    13 May 2008
    Well yes. the 4dd was too cramped, had very poor dwell times and didn't offer significant capacity improvements. THere's lessons to be learned there, for sure...
Thread Status:
Share This Page
