As the bidders are going for Hitachi (Govia and Abellio) or Alstom (Stagecoach) I think not...I see them using the class 701
Where do I find this info? Can i find this info for other franchises also?As the bidders are going for Hitachi (Govia and Abellio) or Alstom (Stagecoach) I think not...
Hitachi Rail has bid to build new metro trains with Abellio and Govia.
In their joint letter to the minister at The Department of Transport, the MPs said: "Hitachi’s engagement with Govia has been positive and their re-securing the contract is the train manufacturer’s best opportunity to supply new trains.
"We believe Hitachi’s price to build the new metro trains is competitive - meaning they can deliver value for money without compromising on performance."
The pair said Hitachi would build the majority of the 800 metro trains in the UK at Newton Aycliffe, producing 32 vehicles per month and could safeguard jobs at the site until 2022.
Not really unless one of their bid team or advisers happens to be around...is there a way to find out what stock MTR wanted to use if they won the wales and borders?
I really hope stagecoach doesn't win, alstom make the most unreliable trains, take juniper and coradia as an example.Not really unless one of their bid team or advisers happens to be around...
Some was certainly the same as the winning bid but in general the other bids were less adventurous in terms of new stock.
Bit selective there, both those fleets are over 15 years old. Pendolinos are probably one of the most reliable fleets in the UK.I really hope stagecoach doesn't win, alstom make the most unreliable trains, take juniper and coradia as an example.
The tender includes a partnership for stock, signalling and depot/ stabling. Stagecoach went with Alstom, the others with Hitachi.If Stagecoach wins then is it a guarantee that Alstom will build their units or is the tender for the rolling stock separate from the franchise ?
Yep. Particularly at Platform 4 (Down to Blackheath) in the evening peak.On some trains at Lewisham you get as many coming off as getting on (connecting with the DLR) so that dwell time is definitely needed!
I believe they were pretty much convinced back then that the air con tech available would not cope with regular door opening on metro routes. Obviously hindsight is wonderful.I don't understand why the 376 was built in the early 2000s and does not have air conditioning such a mistake.
Realistically you could keep the 465/0 and 465/1 fleet as there are some 8 car only routes on Metro; but with a decent bit of work done to them. The Metro Cammell ones need to go, mind.
The 376s don’t fit on the 12 car Railway; so you would need to find at least 90 new 4 car units (or perhaps 30 12 car fixed length ones). The 377/375 hash up wants sorting; work out which routes need to keep the 375s and the 375/9s stuck on a particular section; and then have an add-on order of some 12 car stock from the Metro that just does people movement at peak. Would need First Class mind which adds to the complexity...!
Stupid question but why haven’t the 376’s ever been operated on the Orpington-Penge-Victoria or Catford Loop routes (back when SE still operated the line of course) on a regular basis?
Surely this would have freed up some Networker stock at the time for longer distanced route,
I recall during the winter of 2010/2011 one did pull into Sydenham Hill, the only time I ever seen the 376’s in this neck of the woods.
I would hazard a guess that its because they are 5-Cars. On an 8-Car maximum route, running 5s is inefficient. There was also an infrastructure issue iirc. You also create problems with permissive working too. 8 Car platforms, 5 Car berthed and your then screw your platform for additional stock. Same if you ran a 10 into a 12 car platform. You waste permissive working/berthing space.
Due to the lack of toilets you are limited to how long you can run a 376 for.
They have been in and out of Vic a few times. Not regular and very randomly. I've seen them in Blackfriars, Vic and Tonbridge.
This is fake news. I know the guys checking the compliances and they're still working on it. Plus, it's not even true that all three bids had many timetable non-compliances first time round.Still many non-compliances with all three bids still, so I hear. October announcement is a definite no. The DfT need to decide what they are willing to compromise on, knowing full well the wrong compromise can bring the whole house of franchising down.
