blakey1152
- Joined
- 5 Sep 2011
- Messages
- 450
Thought I would mention this.
Next weekend (22nd/23rd August) Southeastern are doing some engineering works on the Greenwich line so there are no trains between Dartford and Plumstead.
Usually the replacement buses serve Slade Green station by using a couple of bus stops on the London bound side in Howbury Lane/Whitehall Lane in Slade Green however as there is bridge works going on until early September buses are unable to use this road.
I sent a tweet to Southeastern asking them where the replacement buses will stop in this instance - initially being told they would still serve the same stops as usual - so I pointed out that this wouldn't be possible because of the bridge works.
I honestly believed that they would use Bus Stop A - Which is on the Dartford bound side and directly outside the station but I was amazed by the response....
The replacement buses are going to stop I'd say about 7 minutes walk away from the station and across a dual carriageway in Thames Road!
I can understand that buses from Dartford towards Plumstead would have to take a bit of a detour to get to stop A but it wouldn't be too difficult for buses travelling towards Dartford to stop at the station.
I personally don't think the new stopping points are particularly suitable and have sent another tweet asking Southeastern why they couldn't choose a more suitable location for the replacement buses.
I am starting to think its a cost cutting exercise as when they did engineering works on the Sidcup line they had a shuttle bus between Albany Park and Sidcup and last time they did works this shuttle didn't run. They had the normal bus stop on a random road quite a distance from Albany Park.
Even a shuttle bus between Slade Green and Erith would be good - or even the ability to use local buses between the two stations using a train ticket would be good - not what they've come up with instead!
Blakey
Blakey
