Southern DOO: ASLEF reject second agreement
Discussion in 'UK Railway Discussion' started by hornbyfan99, 1 Apr 2016.
  1. Barn
    Barn Established Member
    1,169
    3 Sep 2008
    This is a good point, and one which we should all remember, including sceptics of the strikes like me.
    It's easy to rationalise that, on one level, if a lack of guard cancels a train, a disabled person would not have been able to board it anyway, whereas with the OBS model at least the train can continue in normal service and reduce congestion.
    But I entirely appreciate that the uncertainty must be a real source of stress, anxiety and frustration, to the extent that it might reduce disabled travellers' confidence to take a job in London.
    Similar uncertainty has, after all, been the major cause of stress, anxiety and frustration in all commuters on the GTR network during the travails there and it would clearly be wrong to wish that on disabled travellers on a permanent basis.
    I think my only qualification to the above is that we should be happy to investigate all methods of dealing with the issue, including technological changes (automatic ramps, etc) and greater use of station staff.
  2. Fincra5
    Fincra5 Established Member
    1,579
    6 Jun 2009
    Well its a bit different staying near the cab.. to having to walk 3 coaches away to load a passenger. Drivers can't leave the cab active and walk away down the platform. Unfortunately you never know what kind of person might just gain access to the cab (etc etc).
    I also don't write the rulebook so can't answer why the German Operation on U-bahn is different to GB Rail.
  3. coppercapped
    coppercapped Established Member
    1,264
    13 Sep 2015
    Reading
    Or the Munich S-Bahn?
  4. Dave1987
    Dave1987 Established Member
    3,697
    20 Oct 2012
    Ok so let's say that all trains are changed so there is a wheelchair area behind the driver at both ends with an accessible toilet, so you have two wheelchair areas and two accessible toilets, one at either end of the unit. What happens where drivers are required to change ends mid journey? How do you factor in the addition dwell times of the driver getting out of their cab, accessing the ramp etc and then getting back in their cab? What about platforms that tapper at the ends so there isn't the room to get a wheelchair off?
  5. 313103
    313103 Established Member
    1,532
    13 May 2006
    You are trying to compare one underground system in one German city against the whole national network in the UK, surely the comparison your looking for is one national network ie Germany against one national network ie UK.
  6. AlterEgo
    AlterEgo Established Member
    8,385
    Well, why not explain why, if the disabled area was placed behind the driver, that the driver couldn't perform that assistance 99% of the time on the GB national network?
    Of course, the driver currently has to secure his cab, etc, but on several Western European systems we've read now, that is not deemed necessary. It seems to be a mix of culture and risk appetite. Trains which have a large window into the cab from the passenger saloon don't exist on the GB network, but do elsewhere in Europe, which I have often ascribed to cultural differences.
  7. D1009
    D1009 Established Member
    2,701
    22 Feb 2012
    Stoke Gifford
    It's a hypothetical question. The disabled area isn't placed behind the driver on most British trains, and no-one is seriously suggesting that train drivers should regularly provide assistance to wheelchair users as far as I know.
    Is it beyond the power of man to design a wheelchair which can be easily moved on and off a train by the user without assistance, or alternatively fit trains with retractable ramps which could be monitored from the cab by CCTV?
  8. AlterEgo
    8,385
    Who knows?
    I wasn't seriously suggesting this was feasible in the next 10 years or so, but it's interesting to observe the cultural differences as well as the perception of the role of a driver.
  9. 455driver
    455driver Veteran Member
    11,332
    10 May 2010
    Where were the 'Guards' when this was going on?
    What line are you on?
  10. 455driver
    11,332
    10 May 2010
    So where is the money saving if Southern are keep the OBS on the trains?
  11. SprinterMan
    SprinterMan Established Member
    2,318
    20 Sep 2010
    Hertford
    Fewer delay or cancellation fines from having to cancel trains if no guards are available.
  12. 455driver
    11,332
    10 May 2010
    What are the current costs of all the trains currently cancelled because no guard is available?
    Why isnt there a guard available in the first place?
  13. WombatDeath
    WombatDeath Member
    67
    12 Jul 2013
    Could be they're on strike, or an incident somewhere has left staff in the wrong place. On the former point, I'd expect that reducing the ability of the RMT to shut down the network is one of the motivations for DOO.
  14. 455driver
    11,332
    10 May 2010
    Apart from the ongoing dispute on Southern when was the last strike?
    You lot make it sound as if its a weekly occurrence! :roll:
    Its more likely to be because the company have not kept up with recruitment as guards have moved on or retired which I dont see as a valid reason to get rid of the grade, unlike some on here.
  15. infobleep
    infobleep Established Member
    6,631
    27 Feb 2011
    Lots of things are different in Europe. I Holland coffee shops allow people to buy and smoke certain substances. Do that here and you might get arrested. So the world is full of cultural differences.
    Just because it's culturally acceptable in one country doesn't mean it is in another or people even want it to be.
  16. 313103
    1,532
    13 May 2006
    London Overground had up to August 2013 and from its inception in 2007 a total of 'ZERO' days lost to ANY industrial action on its network, even though on one other occasion we nearly did but that didnt occur.
    Even people on here get the impression the RMT is on strike every other day so they need their tails cutting, i had took two days strike action in 7 years at London Overground and since i have been with ATW i have had none. Yet the perception exists that we are a strike happy union, if that was the case i would be on strike on average once every other week over some trivial matter.
  17. infobleep
    6,631
    27 Feb 2011
    What about the cancellation costs due to lack of drivers? That affected both the Uckfield and Milton Keynes lines today.
  18. Chrisgr31
    Chrisgr31 Established Member
    1,354
    2 Aug 2011
    I believe they are the same drivers! Uckfield line and Marsh Line also suffering from a significant number of unit failures.
  19. IKB
    IKB Member
    286
    15 Nov 2013
    And cause you to miss your connection at Redhill? Perish the thought.....
  20. redbutton
    redbutton Member
    447
    5 Sep 2013
    It's interesting you would mention that. I recently had someone hold the doors because a wheelchair passenger wanted to get off. When I reported it to Control, they sent BTP to meet the train.
    Of course, by then I had already went and found platform staff myself. They assisted the passengers and I carried on with the journey. The responding officers didn't catch up with me until we reached the terminus anyway, at which point they and I shook our heads in disbelief.
    To be fair to Control, I'm not sure the reason for the door-holding was clear to them and they probably thought it was youths horsing around as they often do in that area, but I don't know for sure.
Share This Page
