Southern Services at Portsmouth Harbour
seaviewer
3 Aug 2018
Can anyone tell me, please, what's happening at Portsmouth Harbour. I see that southern trains cease to use it after about 1530.
This could muck up plans for a lunch meeting in November. As if having to use a class 313 to get there from Brighton isn't bad enough.
Seaviewer
Towers
30 Aug 2021
Where are SN services terminating instead? It's a journey of a few minutes or less from both Ports & S'sea or Fratton, with plenty of alternative services operated by SWR and GWR.
I13
26 Aug 2017
I couldn't tell you why, but a lot of Southern services have been terminating at Southsea in recent timetables. Only one stop along so hopefully not too disruptive for your plans, if a bit inconvenient.
TEW
16 May 2008
I believe the reason more terminate at Portsmouth & Southsea now is an effort to improve reliability, as most Southern services have short turnarounds at Portsmouth.
Kite159
27 Jan 2014
West of Andover
If the Southern is terminating at Portsmouth & Southsea then it's easier to change at Fratton where it will be the same platform change (or the other side of an island) whereas Portsmouth & Southsea low level to the high level platforms can be a bit of a walk, especially if the Southern service goes in on top of something else
seaviewer
3 Aug 2018
Thanks, everyone. I am not averse to a walk, but its not that short a distance. However, I see that there is a reasonable connection between a Waterloo train and the Brighton service in the up direction. Must check down
