Thank you! Maybe kill two birds with one stone then.Yes it would count for Southern
I’ve got an assessment day for SWR next Thursday - I know they run it in-house and all the assessments are in one day, and assuming I pass all off those, will it count for Southern as well? It says in the email that they will accept passes from another TOC or GTR but I don’t think SWR use OPC... I’m anxious to email southern because they I’ve read here that they don’t look favourably upon applying to loads of different TOCs so... any insight into this?
SWR seem to have a same policy too on those applying for multiple TOCs. ‘If you pass with us we would like you to stay with us’ is what I was told. In addition you won’t do the MMI part with SWR on the one day so in effect you would have only completed part 1 of the assessment.
Your results at SWR are valid at Southern I did assessments with both, I was never told about they would like you to stay with them.
Thanks for this. That’s true, there’s no interviews at this stage. Assuming this works in reverse too, if I fail at this stage for SWR, I will need to let Southern know right?
How many stages are left now?Yes but sometimes they do MMI before DMI ( which is better)
Hi, have they actually rung you and booked in a date for your DMI ? I take it you have already passed the assessment centre etc..Just booked my DMI, some time in the next few months.
Many Thanks for the info.It was an automated email inviting me to select a date for the interview. As per the successful completion of the miniSCAAT email, they are sifting through those that have passed the assessments already, and I'm guessing will be sending assessment invites for those who haven't taken them already in due course. Keep an eye on your emails, things are slowly but surely moving along...
Sorry if I’m reading this wrong, but one cannot take the Psychometric assessments with TOC A, and then attend another assessment day for TOC B and take any other assessments (either stage one or stage two). If you have the results from TOC A, you can of course use these, but can’t overlap the assessment centres. This is in case you fail any part of the process, so it’s clear.SWR seem to have a same policy too on those applying for multiple TOCs. ‘If you pass with us we would like you to stay with us’ is what I was told. In addition you won’t do the MMI part with SWR on the one day so in effect you would have only completed part 1 of the assessment.
When you clicked on the ‘assessment’ link did it just book you in for an assessment day? Or was there an option to book interview sepereately?
I keep getting sent the assement day invite email, but I have just recently passed an assement day with another TOC. I have informed them of this, but no real response as of yet...
It told me to schedule it under the interview tab, nothing to do with assessments. If there is a contact address in the email, try chase them up again.
Hey Everyone, I have today received an email advising me to login to the careers website and select a date to attend the assessment centre using the 'assessment scheduling' tool. When I login to the website I can not find this anywhere, is it a test in itself Anyone else had the email and had any luck scheduling the assessment centre?
Thanks!
Thanks!
This happened to me the other day.
There are no spaces left, and therefore the tools to book will not show. The next day however, there was another email to inform me that there were more dates opening up. When I logged in then, I could see the assessment tab.
I'm sure there were about 8 to 10 dates when I logged in after getting the email. I wanted the last one at end of June and that clearly got booked up too quickly and missed out. I'm assuming on each date there'd probably be approx 10 candidates ? So that seems like loads going for the assessment. Even more so if they open up even more dates.
Reg, the dates were not in the email but after you have logged into the portal.
Yeah must be loads. After all, there were 3,600 applicants for this. It seems like we may not even start until next year, seeing as the last assement dates are around the end of June, and then DMI and MMI need to take place. I got the assessment invite in error so managed to see the dates. But I’m due for an interview in two weeks time!
Then most likely need to be wait for all the applicants to get to the same point.
Good luck with the interview. I now need to knuckle down and try and start preparing as best I can for the assessment tests. A little apprehensive but have to give it best shot and hope can pass it in the two chances we have
Good luck too! I was literally so anxious prior to the assessments, but honestly they weren’t as bad as it seems. Just remember to read all questions properly and listen to the assessor. I found the computer tests hard with the joystick and remembering the traffic scenes. But managed to make it through so must have done something right.
Some of the tests are literally things you can’t really practice for as it is really just your personal aptitude to be able to focus for long periods of time and being to memorise. But it doesn’t hurt familiarising yourself with what the assessment consists of.
If you have any questions let me know.
