Southern's "the key" extended to London
Discussion in 'Fares Advice & Policy' started by cjohnson, 21 Oct 2013.
Thread Status:
  1. cjohnson
    cjohnson Member
    584
    3 Sep 2009
    From today, Annual, monthly and weekly seasons from most Southern stations to Victoria, East Croydon and Clapham Jct can be loaded onto 'the key'. (Also London Bridge-Gatwick only).
    They also say that from February 2014, it will be possible to load a travelcard onto it.
    Rail Forums
  3. Deerfold
    Deerfold Established Member
    10,288
    26 Nov 2009
    Details here:
    https://www.southernrailway.com/smart-card/
  4. andrewkeith5
    andrewkeith5 Member
    673
    2 Jun 2013
    West Sussex
    What's interesting is that I used to be able to do this from day 1 of 'not-season' fares being available on The Key, and did so with returns from Gatwick or Crawley fairly regularly...
    Except today when I go online to buy a ticket for my Key, all of the smart fares to london appear to have disappeared from the website...
  5. tsr
    tsr Established Member
    7,375
    15 Nov 2011
    Between the parallel lines
    Why is there a rather obvious attempt to ignore stations between Salfords & Merstham which already have access to the key for travel outside London? Every station which is already enabled for the system and located to the South of Gatwick Airport appears to be able to take advantage of smartcard season tickets to London - but nothing on this part of the Redhill route.
    See: https://www.southernrailway.com/smart-card/routemap_victoria
    I am sure there may be a logical reason, but it seems very odd indeed to miss out stations with a combined total of several million journeys per annum. Unlike what Southern sometimes seem to think, people do actually use trains via Redhill et al...
  6. ushawk
    ushawk Established Member
    1,965
    5 Nov 2010
    Eastbourne
    They arent being ignored, the roll-out is being phased.
    The same thing happened when it was extended to Gatwick, intermediate stations were left out until a month after.
  7. tsr
    7,375
    15 Nov 2011
    It's a bit of an odd way of phasing it. That's an awful lot of stations for the first rollout to Victoria and then they miss out a handful towards the North.
  8. 34D
    34D Established Member
    6,031
    9 Feb 2011
    Which I assume is intended to disallow the GoAhead 'key' medium on the trains branded Gatwick Express?
  9. radamfi
    radamfi Established Member
    8,767
    29 Oct 2009
    That would be pretty crazy, given that the main service between Victoria, Haywards Heath and Brighton in peak hours is the Gatwick Express, and season tickets between these stations are permitted on the Gatwick Express without paying any extra.
  10. 34D
    6,031
    9 Feb 2011
    I agree it would be crazy
  11. cjohnson
    cjohnson Member
    584
    3 Sep 2009
    Only seasons to London are available at the moment - a season ticket search shows the 'smart' fares.
  12. radamfi
    8,767
    29 Oct 2009
    I intend to convert my Crawley to Victoria season to the Key from next month and we'll see if I have any problems when I change at Gatwick on the Express! I actually normally travel from Three Bridges and only buy the ticket to Crawley because the fare is the same. The paper ticket is accepted at the Three Bridges barriers (and also at East Croydon and Redhill) so I wonder whether the Key season will work those barriers as well?
  13. Tom
    Tom Member
    313
    19 Jan 2008
    35,000ft
    Nope.
  14. ushawk
    1,965
    5 Nov 2010
    Eastbourne
    Not really. I mean why put Merstham on it now if that would be the furthest north you could currently go. Because it is now rolled out at the London stations, when further stations are added, they could go pretty much anywhere on the network.
  15. Tom
    Tom Member
    313
    19 Jan 2008
    35,000ft
    It is primarily down to a staged rollout - but there are also other issues such as the ITSO on Prestige at play still causing some holdups with rolling it out everywhere...
  16. andrewkeith5
    andrewkeith5 Member
    673
    2 Jun 2013
    West Sussex
    I don't understand, I've bought two Smart Off Peak Day Returns from Gatwick to Victoria and one or two from Crawley to Victoria...
    I distinctly remember it as I bought two from Gatwick and one was refunded... a Smart Off Peak Day Return was £9.55...
    I'd love to know, but I have a feeling that nobody has thought about programming the gates properly :( Half the time even paper tickets aren't properly accepted
  17. tsr
    7,375
    15 Nov 2011
    Merstham was already the furthest North you could officially be permitted to use the key, prior to yesterday's announcement and event. To now have key usage available to London, but to miss out a handful of stations on a busy line which were already fitted with equipment and which already worked as per the rest of the key area, seems slightly nonsensical.
    I don't believe that would affect a rollout to the Redhill area. The scheme (publicly) already stopped at Merstham, which is the last station before entering Zone 6 to the North. And indeed, for day tickets & seasons South of Merstham, it still does. There's always the hazard of people trying to use the key incorrectly to/from Coulsdon South and stations North of there, but then there are plenty of people travelling from Gatwick towards that station and the Purley area on stopping services, and many people also have to be assisted who make the mistake of trying to use Oyster via Redhill or towards Gatwick, so various manual procedures and personal explanations are often needed to rectify mistakes anyway!
  18. Tom
    Tom Member
    313
    19 Jan 2008
    35,000ft
    The Redhill area was a test location for a different version of the ITSO specification (on rail, at least) I believe, so that may explain it.
  19. Bidstonboy
    Bidstonboy Member
    29
    21 Aug 2012
    Is Redhill the black sheep of The Southern Network? I once stayed there for a couple of nights as The Travelodge is very handy for the station and was very perplexed to find out that none of Southern's £5 advance singles to Southampton/Eastbourne are available from Redhill yet are possible from London, Croydon and even East Grinstead!! I'd be a bit annoyed if I lived there. Therefore it doesn't surprise me that The Key isn't usable there yet.
  20. GodAtum
    GodAtum On Moderation
    2,337
    11 Dec 2009
    This looks good. Can i get a monthly East Croydon - London terminals 1st class on this?
  21. radamfi
    8,767
    29 Oct 2009
    I assumed any trip within the zones would be outside the scope of the Key, even though First Class tickets aren't available on Oyster. However, it looks like it is available if you try to order it on the website!
    The test will be offering First Class tickets on PAYG. Dutch Railways allow you to set your smartcard on a ticket machine to whether you get charged 1st or 2nd class when using PAYG.
  22. Deerfold
    10,288
    26 Nov 2009
    I assume it means you can't use the faster FCC trains as GX doesn't go to London Bridge. It's not clear if it's a cheaper Southern-only ticket or if the Key has less validity than the equivalent paper ticket
  23. cjohnson
    cjohnson Member
    584
    3 Sep 2009
    It's just a 'smart' version of the Southern only fare - http://www.brfares.com/#faredetail?orig=GTW&dest=LBG&rte=777&tkt=0AS
  24. GodAtum
    2,337
    11 Dec 2009
    So in Zones I should not use the key?
  25. radamfi
    8,767
    29 Oct 2009
    On the contrary, it looks like you can. It looks like some trips will be available by both the Key and Oyster.
  26. GodAtum
    2,337
    11 Dec 2009
    the reason i ask is that my 1st class season cannot be put on an Oyster. can 1st tickets be put on the key?
  27. radamfi
    8,767
    29 Oct 2009
    I don't see why not. You can buy First Class singles and returns as well, but not for East Croydon to Victoria.
  28. GodAtum
    2,337
    11 Dec 2009
    Ah Ok so i cannot get a season 1st class East Croydon to London terminals?
  29. radamfi
    8,767
    29 Oct 2009
    Season, yes. Single, no. Return, no.
  30. GodAtum
    2,337
    11 Dec 2009
    excellent, i will order my key now :D
  31. radamfi
    8,767
    29 Oct 2009
    Make sure you get one with a photo on it, as you need a photo if you want to put a season on the Key.
Thread Status:
Share This Page
