Specific train not shown on booking engines
soup6
I want to but an advance from Ashford (Kent) to Manchester tomorrow(Monday) using HS1 and then travelling on the 12:20 from Euston. I've tried a couple of booking engines but none offer this train with Advance tickets (as it is never the fastest with the standard connection times) but I wish travel specifically on the 12:20. Is there a tweak (forcing a longer connection time in London, for instance) which would show this train? My only other option is to buy separate tickets for each leg but this considerably more expensive.
Yes.
In the via field enter via: CHX
This will give you a reservation on the 1220 as you wish, and recommend the 1003 as the suggested service, however the normal rules of appropriate connecting services still apply, and there is nothing marked on the ticket nor in the T&Cs to say you should take the 1003, it's still valid to travel via HS1 into St Pancras.
Searle
4 May 2012
Ladbroke Grove
I managed to find this on NRE by specifying 'via Charing cross', which is an advance on the 12:20. As SouthEastern are all unreservable, you should be able to get any train to Euston (ie. on HS1), but I'll let someone else confirm that.
Edit: looks like it was confirmed while I was writing this post!
soup6
Thanks everybody. If I follow your advice I will be in the unusual position of picking up my tickets (from a machine) after the recommended train has departed from Ashford. Is this likely to cause a problem?
No. You can collect tickets after the departure of your selected train, and even from a different station.
Edited to add an example: I once was heading to Birmingham on the Sleeper from Scotland, but couldn't collect my tickets because the Scotrail network went down. I was able to collect my ticket at Crewe at 5AM the following morning - a different station, on a different day. So you shouldn't have any problem.
