Speed limits on the Gloucester-Birmingham route
ntanswell
23 Mar 2006
Gloucestershire
Hi ya,
After making several trips on this route recently, it appears to me that some of the route is rather fast up until longbridge. Anyone know the max speed for the route and as a bonus, where trains achieve it? Also, whats the limit through Ashchurch station, as i notice there are several sidings and spurs there, also the limit over worcester south junction for trains to Bromsgrove, and finally whats the limit up (or down) the lickey?
Thanks in advance
Nathan
Mojo
7 Aug 2005
I know it slows down to 60mph, then to 40mph once the 2-track starts on the Cross City section.
A Voyager journey can be extremely painful too as they're TT'd to sit on yellows from Kings Norton once they follow a Cross City train.
devon_metro
11 Oct 2005
Too right. Was stopped at Bourneville before on a voy.
It's pretty fast down the Lickey.
ntanswell
23 Mar 2006
Gloucestershire
Hi,
Thanks for the info, the route from a passenger perspective seems quite straight, i remember reading somewhere about a virgin proposal to boost the route to 125mph operation, i assume the route is currently restricted to 100mph due to signalling, 3 aspect i believe?
Nathan
PS. A voyager with all engines working tackles the lickey with realtive ease, how did the HSTs and 47s handle with less power?
ChrisCooper
7 Sep 2005
Loughborough
If a line has a conventional 100mph speed limit (not just for certain types of trains, like HSTs), then the signal spacing won't be a problem as far as further upgrades are concerned as all trains capable of travelling in excess of 100mph (including the 110mph 87s and 90s) must be able to stop within 100mph braking distances (usually by using EP braking, rheostatic braking, or both, disk or clasp brakes isn't usually an issue, although clasp brakes arn't as good at high speeds, and arn't used as primary braking on any train capable of more than 100mph). The number of aspects isn't a problem either, 125mph running can be done with 3 or even 2 aspect (distant and stop) signalling, the more aspects just make the line run more efficiently. The single yellow or distant will be the same distance from the red as a double yellow, giving the same braking time.
It is very likely to be other issues effecting top speed, with automatic level crossings being a problem, aswell as sighting distance for various things. Efficiency is also a problem since increasing line speed costs money (not just dealing with the problems above, but also the increased wear and tear on track and rolling stock, and increased fuel costs), so journey time reductions have to make it worthwhile. Sections of higher speed running also have to be long enough so that trains arn't just hitting top speed intime to brake for a lower speed limit (even Voyagers will probably take about 5miles to get from 100mph to 125mph and back, and will use a lot of diesel in the process).
Sprog
6 Sep 2005
SPM
with much HELLFIRE involved....;) <D
