Sprinter gets its wires crossed at Blackburn
Ant158
5 Apr 2013
25o2d92
https://flic.kr/p/25o2d92
A friend messaged me this scene from Blackburn. Whilst working a Rochdale to Clitheroe Service this evening this Northern unit developed a fault and the service was cancelled at Blackburn. Anyone have any ideas as to why wires would be hanging out the side of this unit? Not sure which unit it is, probably a class 150.
https://flic.kr/p/2fZCVLZ
Llama
29 Apr 2014
That actually looks a bit like the rope from the emergency cupboard. There isn't a great deal of wiring around that area on a 150, mainly air system pipes.
Llama
29 Apr 2014
It's ICASR, not easy to see.
Air suspension reservoir isolation cock, for those uninitiated with traction. If an air suspension bellows bursts or there's a leak elsewhere on the air suspension system on a vehicle, isolating the air suspension res will stop the leak from emptying the entire air system on the unit. Once isolated, any residual air trapped in the air suspension system needs to be drained off (there are drain cocks on each surge tank) to make sure that the vehicle rides level. There are other considerations once this has been done, passengers will normally be removed from the affected vehicle if possible (if not possible then the train will run at reduced speed). Special considerations for braking and also coupling need to be made too.
Not all unit vehicles have separate air suspension reservoirs, some are fed directly from the main reservoir pipe, those usually have separate ASIC (air suspension isolation cocks) for each bogie.
ComUtoR
13 Dec 2013
Cheers. ASR I would have guessed as Suspension :)
Good to see fleet wide nomenclature
