mike57
Not sure if this is the right place...
Take the following scenario:
Traveling from Seamer to Manchester Airport mid morning, there are no through trains at this time of day, so you need to change. There are 4 possible places where you can change, York, Leeds, Huddersfield or Manchester Piccadilly. Of these Huddersfield is the easiest, just wait on the same platform. York and Manchester Pic are potentially the worst, long walk, with stairs/lift to negotiate and people wanting to see your ticket at Man Pic. Leeds is usually OK, same platform but with a small chance of a walk/stairs if things are disrupted.
When booking advance tickets for this journey it is not possible to force the booking engine to give you a change at Huddersfield, it will always default to York. You can split the journey but it doesn't save any money and increases your problems in the event of late running.
Why isnt 'ease of change' information included in the booking engine so that those of us with (too much!) luggage or those with mobility problems can choose the easiest change. Or at least have the option to choose the change station where there are a number of options.
There are other journeys where this type of situation applies so I would have thought it would be relatively easy to add this sort of info
Obviously if you are traveling on an open ticket this isn't a problem, but on this journey that can add £30 to a return journey.
