Stations which should close
6Gman
1 May 2012
A thread for suggestions of stations which should be closed, with reasons:
1. ARDWICK
Serves nowhere in particular, and trains calling there simply create potential delay for other services.
Bellwater
10 Jan 2010
on a 158
1. ARDWICK
Widnes, Causes me too much Grief.
Pumbaa
19 Feb 2008
Ha! Spat my tea out then!
I would support the closure of Ardwick. And propose the closure of Norton Bridge etc. Basically everywhere is sustained by a parliamentary service.
I would also build two extra platforms, well, a graded separated island on the west side of Wigan North Western and close Wallgate. Increased interchange and journey opportunities.
Related - I would close Warrington Bank Quay and Warrington Central... And open a new Warrington Interchange built with the high-level Liverpool - Manchester platforms in the same location as the low-level mainline platforms. Again, increased journey and interchange opportunities.
Ivo
8 Jan 2010
Bath (or Southend)
Dilton Marsh. The village is pretty small and its only other catchment is the western part of Westbury - which by frequency is far better served by, er, Westbury.
Eagle
20 Feb 2011
Leamingrad / Blanfrancisco
Although Dilton Marsh (station) is actually more central to Westbury than Westbury station.
Not that Westbury is a particularly big town anyway. (Its growth is stunted by Trowbridge and Warminster on either side of it.)
I've never seen the point in Holton Heath myself. It serves a caravan park, basically.
Ivo
8 Jan 2010
Bath (or Southend)
Having consulted my Wiltshire map I would suggest that Westbury is roughly 500m closer to the town centre. Either way though, one is a prominent junction and the other is a pair of platforms that are barely long enough to stage a triple jump competition (and a fairly long walk from the road).
stuartmoss
2 Feb 2010
Do they have to be closed? Can they not be made request stops? I wish that the network in general made more use of these.
6Gman
1 May 2012
A request stop can be as disruptive as a mandatory stop. And requires maintenance, administration etc.
MidnightFlyer
16 May 2010
I wouldn't say I support it, but I think generally things would be easier if Ardwick was closed, and the Stoke-Stafford stations either were closed or had an improved service.
I agree, however I think it would require a bit of trackwork on the WCML, specifically to fit in two side platforms and an island or two islands. That said it would also remove a station from near enough what is central Warrington.
Ivo
8 Jan 2010
Bath (or Southend)
Another one I would suggest is Coombe Junction. Why can't they straight-line that stretch? It wouldn't exactly cost a fortune, and it would save money on maintaining the token system in place.
There are no stations which should be closed.
A very "rose-tinted" perspective. Explain to me why something like the suggestions Pumbaa made - which would necessitate station closures - shouldn't work.
Otherwise, some stations are so poorly used and inconveniently located that the costs involved in ensuring they stay open surely exceed the benefits that would exist should they be closed.
bluenoxid
9 Feb 2008
So no stations that should be opened then. Pacers FOREVER.
A better alternative might be to mothball stations.
I have a few suggestions for the north
Pontefract Baghill with service diverted via Barnsley.
Teesside Airport
Personally, I think that an airport railway station should be a privilege, not a right and the current set just shows an airport that does not care about its railway customers. Pontefract would still see services to York but trains would now serve Barnsley and Wakefield too if Baghill was closed
tsr
15 Nov 2011
Between the parallel lines
Unfortunately, by the sort of logic we are at risk of developing, we'd reduce the Far North Line to about 3 stations, whereas this would be foolish as these stations can (or could) provide links that are invaluable to the community. Likewise the Exeter St Davids - Barnstaple line (which we discussed earlier this year, I believe).
WatcherZero
25 Feb 2010
It also I believe massivley suppresses potential demand. People dont like using deserted stations or an hourly service that might not stop.
SprinterMan
20 Sep 2010
Hertford
Bodorgan & Ty Croes on the North Wales Coast line should be closed, as they are very near Rhosneigr and if they are closed, it would allow Conwy, Penmaenmawr, Llanfairfechan, Llanfairpwll, Rhosneigr and Valley to be served hourly.
Buckenham in East Anglia is near enough completely pointless, and very close to Brundall anyway.
Doleham exists for apparently no reason also, as it serves only a farm (and is named after it); there is no settlement called Doleham.
tbtc
16 Dec 2008
Reston City Centre
I totally agree.
There are a lot of places that just don't justify their existence (would you lose sleep if Breich closed?). And a few stations that should be merged (like the Warrington/ Wigan examples that you give). The railway is a multi billion pound industry that carries millions of people each year, but that doesn't mean we should preserve all of it - demands change, so should stations.
If a station cannot justify any service off-peak, can we really justify its costs? In some cases yes (because there is such demand at rush hour - I've heard that decent numbers use the handful of Northern services at Manors in Newcastle for example), but some stations are only kept alive on a life support machine because nobody dares pull the plug.
Maybe we should have a "one for one" policy, where you can close a Breich/ Chathill if you are going to open a new station elsewhere in the UK?
SprinterMan
20 Sep 2010
Hertford
How d'you figure that?
Bit of an assumption I know, but if the ATW train that calls at all the stations on Anglesey has to do 2 less stations, it could stop at the 3 (much better used) stations on the mainland instead in roughly the same time. :P
tbtc
16 Dec 2008
Reston City Centre
These stations have been around for long enough to provide a link, but still insufficient people seem to use some of them.
We are in danger of the tail wagging the dog
Ivo
8 Jan 2010
Bath (or Southend)
There's a difference between the Far North scenario and those down south such as Holton Heath and Dilton Marsh. The Far North stations have little alternative for accessing the rest of the country; the road network is just as poor as the rail network (and in some cases almost possible to access). The southern examples don't have this problem. Was this not the reason why the Gunnislake route survived Beeching (and why it would not be an ideal candidate for this thread)?
Lampshade
3 Sep 2009
South London
Do we really need St Margarets (London)? It's so close to Twickenham they may as well just extend TWI's platforms.
Hmm. Part of me would prefer that they parylised with fear at the prospect of closing stations. Stops us going down a slippery slope <D
Actually - They have closed some stations fairly recently such as Dover Marine and Holborn Viaduct. Perhaps there just aren't enough savings to be gained from closing Doleham, for example.
