Stations with mandatory assisted dispatch
Boski
6 Jul 2018
Any list knocking around of stations that are mandatory dispatch either set by dft or otherwise and wether they are likely to change?
PupCuff
27 Feb 2020
"Assisted dispatch", for the benefit of anyone unfamiliar, refers to cases where platform staff are part of the dispatch process, whether the trains themselves are operated with a conductor or DCO, and whether the ready to start signal is given either by RA, green flag or bell/buzzer.
It gets somewhat complicated as, aside from major stations where RA dispatch is mandated, some TOCs may require assisted dispatch at a given location whilst others will be quite happy to get themselves gone. Other stations, such as many on the WCML, require use of the RA indicator for Pendolinos but not other traction.
At some locations, individual platforms may require assisted dispatch whilst you can quite happily go off your own back from others.
I wouldn’t expect there to be a list, but as a starter for ten, Manchester Piccadilly, Manchester Victoria and Birmingham New Street are all assisted dispatch with RA mandatory.
skyhigh
14 Sep 2014
Yeah it gets pretty complicated. For example LNER require a dispatcher at Shipley and Skipton, but Northern don't. You've got Sheffield where EMR have dispatchers, a few Northern services use dispatchers (as far as I'm aware) and some some don't. Then you have places like Leeds where all passenger services require dispatchers along with ECS trains during the day but overnight they self dispatch.
Efini92
14 Dec 2016
Pendos further complicate the matter by using buzzer at Preston southbound 1,2,3,5&6, northbound 1,2,4,5,&6, Wigan north western and Warrington bank quay
skyhigh
14 Sep 2014
Interesting, do LNER also require one at Keighley?
Can't say I'm 100% sure on that (same with Harrogate or Horsforth). I know they don't require one at Bradford Forster Square though.
For what it's worth ticket office staff act as the dispatchers.
Undiscovered
28 Jan 2013
Shrewsbury, all platforms apart from the bays are assisted dispatch.
Bays you can go Right Time without a dispatcher, if none available.
30907
...which has a full-length straight platform. Curvature is an issue elsewhere.
800001
24 Oct 2015
LNER get despatched by Northern staff at Harrogate.
If for what ever reason there is no despatch staff, LNER have to use another TM to assist, otherwise the service can’t use Harrogate and will then terminate/start at Leeds.
SCDR_WMR
17 Dec 2017
On LNWR you have Lime St, Runcorn, Crewe, Stafford, Stoke, Wolverhampton, New st (RA), Rugby, Watford Junction (10 only), Euston (RA).
Also dispatched at Nuneaton, but self dispatch in nobody on platform.
However, only Lime St, New St and Euston are true mandatory as the others you can permission to self dispatch from control (never had it myself though).
Then there's Milton Keynes, mandatory for Avanti but self dispatch for LNWR!
On WMR only Worcester Forgate is mandatory on platform 1 due to signal placement for Snow Hill lines. New St and Wolverhampton as mentioned above. Can't remember any others on other route's
thesjd
9 May 2015
Crewe requires at least two dispatchers for all Avanti Pendolinos and Caledonian Sleeper services. One dispatcher for all the others. No self-dispatch under any circumstance.
PupCuff
27 Feb 2020
CrossCountry can self dispatch from Crewe, as much as it upsets the station staff when they do.
DanNCL
17 Jul 2017
County Durham
LNER, XC and TPE all require dispatchers at Newcastle. TPE provide their own dispatchers whilst XC use LNER’s. Northern self dispatch. Not sure what Lumo do.
At Darlington it appears to be just LNER and XC using dispatchers, with TPE using self dispatch.
800001
24 Oct 2015
I believe Lumo self despatch.
PupCuff
27 Feb 2020
It does upset me to be fair ;)
No shortage of Crewe staff over the years arriving in Stoke or Stafford having got on an XC to do an assist without letting the guard know; but on the plus side, there's generally a brew ready in the galley for when it happens!
Parallel
9 Dec 2013
There is a lot of dispatch on the GWR network where the IETs operate, and it seems stations that do have dispatch staff, tend to dispatch all stock/operators i.e at Westbury, Castle Cary, Bath Spa etc. At the smaller stations, the ticket office staff usually double up as dispatch staff.
TEW
16 May 2008
So "Bat and Flag" and "CD/RA" ?
There are some stations where dispatch is by the guard and the ready to start signal is given using the bell/ buzzer and dispatch assistance from platform staff is mandatory too.
SCDR_WMR
17 Dec 2017
Apologies, forgot to add Crewe to the 2nd part of my list . Have been tempted to on 3 whilst waiting for the usually late running Pendo....
If it didn't involve platform staff, its just normal dispatch.....and that's mandatory at every station unless DCO or RA
TEW
16 May 2008
There are stations where platform staff will assist with dispatch when available, but they are not mandatory though.
HamworthyGoods
15 Jan 2019
I believe the following stations require mandatory dispatch for full length trains on SWR:
Basingstoke
Bournemouth
Brockenhurst
Godalming
Portsmouth & Southsea (Plat 1 & 2 Only)
Portsmouth Harbour
Southampton Central
Surbiton
Vauxhall
Waterloo
TEW
16 May 2008
Basingstoke
Bournemouth
Brockenhurst
Godalming
Portsmouth Harbour
Southampton Central
Surbiton
Vauxhall
Waterloo
Vauxhall and Surbiton are not mandatory dispatch. Godalming is only on platform 1, and only for more than 8 coaches.
