Steam loco tyres - why are they only made in SA?
alexl92
12 Oct 2014
This isn’t one of those ‘If its not British its rubbish’ posts; I’m just genuinely curious...
In the UK we can manufacture a complete steam locomotive from scratch with the exception of one aspect (to my knowledge) - the tyres, which have to be produced in South Africa.
Is there a reason that this can’t be done in the UK (or anywhere else - Germany at DB Meiningen for example)? Is it a certain type of material that only SA has the capability to produce?
Thanks!
DelW
15 Jan 2015
At a guess, I'd suggest that (i) the machinery needed is substantial and therefore expensive, and (ii) that the worldwide market for new steam loco tyres is fairly small. So it's cheaper to obtain them from a works which has the capability, than to set up in competition with it.
Commercial steam operations lasted quite late in South Africa, which could be a factor. Since industrial steam survived longer in China than anywhere else, might there be a lesser-known works there that can make them as well?
paul1609
28 Jan 2006
Wittersham Kent
Id suggest asking your question on the other preserved railway forum. Mike Hart of LSL, WHR, K&ESR etc is a railway wheel magnet but I dont think hes a member on here.
alexl92
12 Oct 2014
Which forum would that be? Nat Pres?
Master Cutler
23 Jan 2021
Mansfield
I agree with DelW.
My guess would be that South Africa, following their late departure from steam traction, has the only remaining forging dies and presses large enough. As a product, Steam loco tyres are not in enough demand to justify setting up a new business.
SECR263
6 Jun 2018
This video shows how seamless rolled rings are made. The principle I assume will the same for railway tyres. You can source loco tyres in Germany, Belgium and South Africa. I assume that the SA firm quotes more competitively for say an order of 6 for an engine. European firms may be interested in more bigger orders. I think all these firms can make up to 4.5m seamless rings. The SA firm if the correct one is called Naledi Ringrollers. Their www site has pics of steel tyres.
geoffk
4 Aug 2010
South Devon Railway Engineering Ltd. orders tyres from South Africa, as seen recently on TV, and no other sources were mentioned so I assume the firm in SA offers best value. We saw how a driving wheel tyre was fitted using heat shrink techniques, a skilled process which requires specialist equipment. I recall it was a 6 ft diameter wheel so I assume from a GWR Hall, or perhaps an LMS Black Five from another railway. ["Steam Train Britain" on the Yesterday Channel, 1st February].
paul1609
28 Jan 2006
Wittersham Kent
Thanks!
Ive asked Mike Hart he says there are currently two firms supplying steam locomotive tyres in the UK his (from European Sources) and the South African one.
Mikes companies website is here: https://www.railwaywheelset.co.uk/index.html
alexl92
12 Oct 2014
Thanks everyone, much appreciated for the informative answers :D
Flying Phil
18 Apr 2016
I thought there was also a Brazilian manufacturer of railway wheel tyres - but they may not go up to the larger diameters for most steam locomotives.
