Stockport - Manchester Problem - 10-03-2016
Haydn1971
11 Dec 2012
Sheffield
Lots of services stuck in Stockport this morning - anyone know what the problem is ?
thenorthern
27 May 2013
I am on the 06:16 ex Euston train and we have just passed Cheadle Hulme at 0829. Train manager says there are 7 trains in front of us and delays are around 30 min.
It's quite a bad morning to be honest for trains into Manchester.
PHILIPE
14 Nov 2011
Caerphilly
My first port of call is always NRE Website:-
Incident created
10/03/2016 07:45
Last updated
10/03/2016 09:24
Route affected
DownloadMapof route afected
All routes through Stockport
Train operator affected
Arriva Trains Wales; CrossCountry; East Midlands Trains; First TransPennine Express; Northern Rail; Virgin Trains;
Description
A broken down train at Levenshulme is causing delays of up to 30 minutes to trains between Stockport and Manchester Piccadilly. This is expected to continue until 10:15.
Some services may not call at Stockport.
You can follow this incident using the hashtag #Levenshulme
We want to make information better – tell us how! Fill out this online Disruption Survey
If your journey has been delayed by up to 30 minutes or more, then you could be entitled to compensation
To check your journey, please use the National Rail Enquiries real-time Journey Planner
northwichcat
23 Jan 2009
Northwich
Is it a common issue with Pacers operating in multiple failing? I was on a 142+150 a few weeks ago which got stopped at a red signal at Skelton Junction and when the signal went green the driver attempted to move off but the set kept rolling backwards.
Loop & Link
22 Feb 2015
It was 142003/150110 which had struck an object (understood to be an animal) causing a loss of air and dislodging something on the underframe.
thenorthern
27 May 2013
The fact that it was the fast line was a big issue as it meant that the local trains were still calling at Heaton Chapel and Leverhulme while the intercity trains had to run slowly behind them.
northwichcat
23 Jan 2009
Northwich
XC and EMT do run services on the slows normally so late running stoppers can cause long distance services to be held up even when the fast is open.
No use made of the Styal route as far as I can see on RTT.
You'd have thought the VT Wilmslow train and ATW Cardiff services could have gone that way.
PS I tell a lie, a couple of VT/AW trains were diverted via Styal, around 0830.
craigybagel
25 Oct 2012
The first AW service affected, (0435 from Cardiff) is one of the few that has a Shrewsbury driver, and they don't sign Styal. The following service an hour later, with a Crewe driver, went via Styal.
ag51ruk
29 Oct 2014
The 0756 Northern service from Crewe (which I was on) followed by the 0811 Virgin train from Crewe both went that way
Bungle965
Buses & Coaches
2 Jul 2014
Calder Valley
I'm pretty sure I saw on Twitter that XC were diverting via presumably the styal line, did that actually happen in practise I wonder?
Sam
The other diversion option would be services from Sheffield running via Romiley, but I don't think this option was used.
And, in extremis, diesel units running from Stockport to Victoria via Ashton Moss.
Loop & Link
22 Feb 2015
The problem is drivers sign the route via Ashton Moss but very very few Man Vic conductors sign the road. Buxton/Picc definitely don't.
10 Mar 2015
Bit much, but upon calling control I was informed that my PBO-IPS service was being delayed by a badger being hit st Stockport, try explaining that one to people!!
craigybagel
25 Oct 2012
Going to be delay minutes nationwide for that one! I wonder who picks up the bill?
northwichcat
23 Jan 2009
Northwich
Someone at Northern is probably reading the small print of insurance policy wording to see if the train being damaged by a badger is excluded.
Probably easier than explaining that the chassis fell off the Pacer.
Philip Phlopp
31 May 2015
Code:
As a badger is (a lot) bigger than a pheasant, I should think it's a Network Rail risk! ;)
4.4 of the Delay Attribution Guide applies, but as a badger isn't a bird, it goes through the flow chart in a different direction.
thenorthern
27 May 2013
Its been a bad week for Virgin Trains on the Manchester trains apparently with trees, cracked windows and badgers.
Saying that though I have driven into Manchester a couple of times this week and the M6 seems to be 10x worse.
northwichcat
23 Jan 2009
Northwich
Major roadworks around M6 J19 and M56 J7-8 at present due to construction of new A556 link road.
thenorthern
27 May 2013
Where abouts was it that the badger was as Levenshulme is on an embankment so it must be quite a brave badger.
There were several accidents as well.
Welshman
11 Mar 2010
Its good to know there are still badgers around Levenshulme, albeit now one less.
Do you think they'll have to badger their insurance company to pay-out?
