Stockport to the West Midlands
Discussion in 'Fares Advice & Policy' started by 185143, 24 Apr 2015.
Thread Status:
    185143 Established Member
    2,683
    3 Mar 2013
    Now that the Stockport to Rugeley via Birmingham loophole has been closed :(
    I am planning a West Midlands DayTripper tomorrow, what's the cheapest ticket to get to the DayTripper area? I was considering getting the Stockport-Rugeley ticket and going to BHM via the Chase line, but its seem to add a lot to the journey!
    Any advice? I don't mind dodgy tickets either:D
    Rail Forums
  3. crosscity
    crosscity Member
    225
    5 Dec 2011
    I can see your problem! To be able to use the half-decent Stafford-Birmingham line you will need to buy a Stockport-Stafford OPDR for £17.90 plus a Stafford-Wolves OPDR for £7.40. More restrictive is a £17.90 Stockport-Penkridge plus Penkridge-Wolves for £5.20.
    Cheapest is via Rugeley TV plus Rugeley TV-Bloxwich N OPDR for £3.40.
  4. 185143
    2,683
    3 Mar 2013
    if it makes any difference, I have a season ticket Manchester-Stockport which I will be using. The Penkridge split is ok.
  5. crosscity
    crosscity Member
    225
    5 Dec 2011
    If you are thinking of catching a fast to Wolverhampton that doesn't stop at Penkridge (or Stafford for that matter) by virtue of your season ticket, someone else may need to advise on whether that is within the T's & C's.
  6. 185143
    2,683
    3 Mar 2013
    it is valid with non stop splits.
  7. Smethwickian
    Smethwickian Member
    472
    9 Feb 2011
    Errr, Smethwick!
  8. crosscity
    crosscity Member
    225
    5 Dec 2011
    I wasn't aware of that and it's well worth knowing.
    I suspect the OP is more interested in getting to/from Birmingham as quickly as possible. Going via the Chase line is likely to take a significant part out of his/her WM day out.
  9. 185143
    2,683
    3 Mar 2013
    I probably will go via Rugeley-I've only done the Chase Line once, it was a saturday in December and two coaches-not fun! I need LM 170s anyway so its not too much of an issue.
  10. crosscity
    crosscity Member
    225
    5 Dec 2011
    I stand corrected! Enjoy your day out in the West Midlands.
  11. 185143
    2,683
    3 Mar 2013
    thank you! (Let's hope my habit of making everything go t*ts up stays in Manchester lol)
  12. LNW-GW Joint
    LNW-GW Joint Veteran Member
    10,988
    What about an OPDR Stockport-Crewe or Stoke and then a West Midlands Day Ranger?
Thread Status:
Share This Page
