Suggested clock face timetable Leeds - Settle - Carlisle plus summer extras
adrock1976
10 Dec 2013
Following on from the Cross Country to operate Leeds-Glasgow via Settle services using HSTs? thread, I did initially attempt to see how it would work, both with XC and also a possibility of extending some London St Pancras - Sheffield to Carlisle at least. Although it would work northbound, there was no way to make it work southbound, and having had a go at attempting to extend the London - Nottingham trains using the existing Northern path, I could only get it as far as Leeds without a lengthy layover of over 30 minutes, which although would be as good as robust, it would have blocked a platform for too long at Leeds (plus also introducing another diesel train in a train shed type station).
Having read "The Case for Integrated Transport on the Leeds - Settle - Carlisle Line Corridor" (attached below), there was a reference to having a clockface timetable, which it would be easier to integrate the bus services with and creating interchange hubs at Settle, Kirkby Stephen, and Appleby.
I switched focus to having a go at a Taktplan, being as the departures in both directions seem totally random and not easy to remember, plus there also not being an even frequency too (same applies for the Lancaster/Morecambe services). My start point was looking at the Leeds end for northbound departures, which are broadly at either xx18 and xx48 give or take a minute or two either way, and southbound from Skipton are broadly at xx29 and xx59 maybe with a minute or two variation either way. This section has to fit in with the existing electric Airedale and Wharfdale services from Leeds and Bradford Forster Square - Ilkley and Skipton, which those routes also involve some single track sections. Also, I looked at the Carlisle end and the existing London Euston - Glasgow Central via the ex Trent Valley Railway is as good as clock face in both directions, therefore would be able to see if those would work both arriving from Leeds and departing southbound.
As the timings progressed along, it became apparent that the northbound departures from Leeds would be at xx48 on odd hours, with the opposite half hour path left vacant to at least Skipton. The even hours xx48 is for the Lancaster/Morecambe, which overall, provides a frequency of every 60 minutes between Leeds and Hellifield.
I have also shown connections for journeys from Manchester, Salford Crescent, Bolton, Preston, Blackburn, and Clitheroe for illustrative purposes, and connections onwards to Dumfries, Motherwell, Glasgow Central, Haymarket, and Edinburgh Waverley and vice versa. I anticipated extending the Clitheroe trains to Hellifield (ideally with the track into the Leeds/London bay platform reinstated) every 2 hours so as to connect into and out of the Carlisle train. However, this would mean a portion uncoupling/coupling at Clitheroe (or Blackburn), and unsure about whether it would foul the level crossing at Bromley Cross or not. An alternative would be to extend all the Clitheroe trains to Hellifield every 60 minutes (would also connect into/out of the Lancaster/Morecambe as well as the Carlisle), as it would mean no coupling/uncoupling, and would require 2 additional trains and diagrams.
I have also overlaid additional workings for July and August (could also be June - September or May - October, or any duration - I am using the main two summer months as a base) which would run every 4 hours Blackpool - Carlisle via Blackburn, and every 4 hours Skipton - Carlisle i.e. broadly running in the hour from the all year round regular service. These would have First Class accommodation and dining facilities, with reservations being essential. See the spreadsheet attached below.
  • The Case for Integrated Transport on the Leeds-Settle-Carlisle Line Corr....pdf
  • S&C clockface.xlsx
I presume this requires the same number of units as now (ignoring the dining trains)?
Without a detailed check, I suspect you have lost Barrow connections at Carnforth (which have only recently become tolerable!) - apologies if that's an oversimplification. I presume the times at Lancaster also work?
Most seriously, you have lost the long-standing Carlisle/Ribblehead morning commuter train into Leeds - that needs to run off-pattern, but that can be resolved easily.
In addition, your 0948 ex Leeds will almost certainly overload on any reasonably good day, so an 0918 duplicate would be essential (at present the trains are 90min apart in the morning "leisure peak"). Not impossible to slot it in, with an afternoon balancing trip into Leeds at 1608 (or ideally 1808).
adrock1976
10 Dec 2013
Excluding the dining trains, it should still require the same number of units as there are still 8 trips to and from each of Carlisle and Lancaster/Morecambe.
I must admit I forgot about Barrow, but having had a quick look for times at Carnforth, the Barrow line is not totally clock face as there are departures at xx11, xx12, xx14, and xx23 (mainly the former Class 37 ex Preston/Lancaster - Carlisle trains it seems). There may be scope to revise the Barrow timetable depending upon the Castlefield Corridor and what exactly happens with the consultation. Furthermore, there may be scope to increase the frequency to 2tph with one of those trains (to/from Lancaster*) omitting the request stops. This would provide reasonable connections at Carnforth into and out of the Leeds trains, as that is the shortest route from Barrow to Skipton, Bradford, and Leeds.
Looking at the December 2019 version of Table 42, I can see that the present 07:14 Ribbehead - Leeds can run as present to Hellifield and couple to the ex Lancaster, or depart 6 minutes later so as to run in the present 08:05 southbound path from Skipton.
I deliberately left the xx18 from Leeds and the xx29 south from Skipton vacant so as to allow any additional workings for any relief trains or charters.
*Maybe have all of the Barrow trains starting/terminating at Lancaster (or Preston)? How many passengers from the Furness area travel to Manchester Airport to jet off to St Moritz or Juan-le-Pan on a daily basis? Perhaps @Bletchleyite could comment regarding Leeds - Barrow connections at Carnforth as well as dining trains on the S&C?
My general view tends towards going hourly clockface on the Barrows starting at Preston (for better Manchester connections) and an hourly Windermere EMU once wired.
i wouldn't say connections to the Bentham Line are that important for long distance travel as unless going to Lancaster itself there is always another sensible option.
I do think decent First Class on scenic lines is money for old rope but dining might be a bit much unless commercially viable.
