Sussex Bus
387star
Was there once a company called Sussex Bus later a Stagecoach brand running around Chichester or am I imagining it ?
Also didn't Stagecoach in the South Downs used to be branded coastline?
Nammer
1 May 2016
You are correct, there was an independent ‘Sussex Bus’ in and around Chichester, which was later purchased by Stagecoach. The livery was 3 red stripes ‘Stagecoach’ style. Also correct that Stagecoach depots at Portsmouth, Chichester and Worthing were Stagecoach - Coastline branded.
387star
Great thanks !! I remember the city legs brand as a kid
Do you know what bus model was used on the route 47 possibly also 48 during the 90s ? I remember a very noisy minibus that resulted in complaints and was then withdrawn
TheGrandWazoo
18 Feb 2013
As @Nammer says, Sussex Bus was an independent that Stagecoach bought out - some photos here on this blog http://sebusscene.blogspot.com/2013/01/welcome-back-sussex-bus.html
Stagecoach bought Southdown in 1989 and after a purchase and then forced divestment of the Portsmouth Citybus operations, they then elected to re-order the Southdown business. I think it was probably about 1992 when they split Southdown so Havant, Worthing and Chichester became Coastline whereas Lewes and Eastbourne became South Coast Buses; I think Hastings was also part of SCB but retained Hasting Buses as a fleetname.
Not certain why they did it; a number of firms did that sort of thing to reduce union power, and it made sense as the old Southdown business had essentially pulled out of Horsham and Haywards Heath and with Brighton being B&H/BBT territory, they were effectively two separate empires linked by just a few services that met in Brighton.
Beemax
10 Dec 2018
Seem to recall they ran a couple of Willowbrook re-bodied Bristol REs. Rare beasts..
Nammer
1 May 2016
If I recall correctly they operated a couple of CVE Omni minibuses with huge mounted destination screens on the roof at the front, could it have been one of those?
387star
Yes!! That's what I remember
They seemed modern enough and low down
387star
Also I notice for a short time not many years back stagecoach introduced some older looking double decker buses with very strange backs which had a recess ?
Also some shorter single drivers where the rubber window surrounds were often broken in the middle as if someone had bitten them allowing water in?
What's the best website for bus pictures and model types ?
GusB
Buses & Coaches
Elginshire
I'm not sure quite what you mean by "recess", but I'm guessing it may have been either a Leyland Atlantean or Fleetline, both of which had the engine in a separate "bustle". Could it have been a former Portsmouth Atlantean, perchance?
The link above takes you to an image of a Grampian Transport Atlantean, but they had the same bodies and this one shows the "recess" better.
387star
Not sure they were this old.
I remember the Volvo stagecoach single deckers well. Some had bench seats some had two by two seating. They were used on the route 60 which I think used to go as far as Guildford from Bognor but now stops at Midhurst. They were very comfortable but we're replaced later on in the noughties for a time by a shorter version with a big step up towards the back if the bus and a further step to sit over the rear wheels. The rubber window surrounds were often damaged . Sorry I can't be more specific.
387star
Edit... re the double decker I think it was a Leyland Titan with the cut out 'box' on the back
Nammer
1 May 2016
Probably the double decks you’re thinking of were the ex London Leyland Titans? As for the single deckers I can’t really think what they could be!
carlberry
19 Dec 2014
If you've got a registration number then Bus lists on the web will tell you what the model is. Wikipedia or Google will link to general information (Google something like bus manufacturers of the united kingdom for instance).
More generally Flickr is useful as you can search for something like 'sussex bus company' and find relevant photos (unfortunately because it's a fairly generic term you'll get loads of related stuff and the majority of pictures are recent (last 10 years) however you will find older ones such as : https://www.flickr.com/photos/michaelwadman/50235436896/
387star
Thanks I get confused because unlike trains there are often fi
Thanks I wonder what brought the Leyland double decker to Chichester even though it was a short time unless they were mostly training vehicles
It eems there is a clear distinction between body and chassis manufacturer for buses which confused me at first
The single deckers in Chichester had many steps up and more stepped areas at the back.
Nammer
1 May 2016
The only ones I can think of are the Volvo B10Ms, some had Alexander PS bodies, and possibly the ones you’re thinking of could be the Northern Counties Paladin ones?
33011
8 Sep 2008
I worked at Stagecoach at Chichester when Sussex Bus was taken over. I seem to recall three willowbrook bodied Leyland Leopards one or two Iveco minibuses two Omni's and two Leyland Nationals. I can't remember the exact amount of vehicles taken over but that's pretty close
I seem to remember the Stagecoach 3 red stripes Sussex Bus livery on the Northern Counties B10Ms. I think Sussex Bus also had some Plaxton bodied Dennis Javelins in that livery
387star
Yes the paladin looks spot on! Can you confirm these were in Chichester for a while ? They were pretty tatty although an upgrade on the disastrous minimises Stagecoach attempted to run on Sundays on the route 60 for a short time !!
Nammer
1 May 2016
Yes Chichester did have an allocation of the Volvo- Paladins. I also recall some were in Sussex Bus version of Stagecoach stripes.
387star
These were my favourite single deckers
Always found them very comfortable
The Paladins seemed to replace these for a while
GusB
Buses & Coaches
Elginshire
Could I remind everyone that any images posted should be accompanied by a caption describing the image. Please avoid posting screenshots such as the one above, but post the individual image. Finally, remember to ensure that you have permission to use someone else's work and credit the photographer. Thanks :D
