TT-ONR-NRN
Fair enough.
The old slammers didn't have configuration, TMS, GSM-R (it was CSR later on), passenger doors or coupler issues because they were all simple things, you had a buckeye, air pipes & MU jumper to deal with and a good shunter would have them down within 30 or 40 seconds of the BP being vented, MU jumper dropped and put back into the receptacle and be waiting for passengers to finish jumping on/off and the next driver to put his/her key on to do the split or attachment. A quick brake test and away.
I think it'd also be a good idea to get the Southampton Central stopper service to make an additional stop at Swaythling, as it is quite an upcoming suburb in the north of Southampton, and it is also the closest station to University of Southampton - definitely a good method of increasing footfall provided fares are reasonable and it is promoted well. Although several stations lose a direct service to/from London Waterloo for most of the day, I've managed to find 2 reasonable paths within a one hour slot to try get the So'ton stopper to go up to Brockenhurst calling at Totton and Ashurst (New Forest). It'd only require one extra train which I believe will be a 450 that will be used most of the day on this service (in addition to 450s on the Pompey-Weymouth) service.
Either a train can depart Southampton at around 16 past and arrive at Brockenhurst for 35 past, returning to London at 02 past (stopping at Southampton for 19 past, departing 22 past) OR sit at Southampton as does the current Poole stopping service until about 32 past and not arrive at Brockenhurst until 53 past. Return times to London would still be the same.
Good idea, Swaythling and St Denys need more of a metro-style service i.e at least 2 an hour. St Denys is getting this which is good, _and_ getting a stop on the additional Portsmouth - just wish they'd done this when I lived in the St Denys area from 2010-16. Whatever else you think of it, this timetable is a big step up for St Denys and I'd bring in Swaythling too.
Totton's also big enough for 2 an hour as long as it's even interval.
Yeah Totton and St. Deny's are upcoming suburbs at Southampton expands. I've managed to get the trains about 30 minutes apart in one of the paths identified, which would should be a selling point. However in the other path it's about 15 minutes behind the Pompey service then a 45 minutes gap afterwards. However the selling point was that the train would connect better at Brockenhurst, 7 minutes for those going on the semi-fast Poole service and about 7 or 8 minutes for the Lymington branch. Dilemma, dilemma. What would you go for, because I can't make my mind up? I prefer the 15:45 ratio thing as it brings more benefits, and northbound in either situation luckily it is about 30 minutes apart.Good idea, Swaythling and St Denys need more of a metro-style service i.e at least 2 an hour. St Denys is getting this which is good, _and_ getting a stop on the additional Portsmouth - just wish they'd done this when I lived in the St Denys area from 2010-16. Whatever else you think of it, this timetable is a big step up for St Denys and I'd bring in Swaythling too.
St Denys always did, the Romsey Rocket & Portsmouth stopper, 1 tph on each route (2 tph), Swaything or Bomb Alley as it used to be known is a menace.
Also if the Weymouth train went non-stop London Waterloo to Winchester during the off-peaks, removing the only intermediate stop at Woking, that way there was enough time to implement an all stations service south of Poole (except Holton Heath) - would this be welcomed? To compensate, the Poole semi-fast service would stop at Woking instead that way there is no loss in the 'proposed train frequencies'. Note that the calling pattern would be Waterloo, Winchester, Southampton Airport, Central, Brockenhurst, Poole, Hamworthy, Wareham, Wool, Moreton, Dorchester South, Upwey and Weymouth. It would add about 2-3 minutes on top of what was proposed in the running time, but it's better that smaller stations aren't losing out rather than trying to save 3 minutes surely?
Thoughts?
Any reason why SW trains is the only operator being discussed for timetables in 2018?
Cross Country?? Virgin?? East Midlands??
The current set up is that the 2 fast trains xx00 and xx30 off Southampton have similar times to Waterloo. One normally calls at Woking and the other at Basingstoke.Would there be a capacity issue in having both Woking and Basingstoke passengers on the same service? At present aren't they divided between the two (Woking on the fast trains, Basingstoke on the slower trains)?
I've never thought of it like that, but thank you for pointing that out. I have in the past travelled on a service that has called at both Woking and Basingstoke during the off peaks and it seemed to do fine, provided there was no disruption and that the frequency was at least half-hourly. Noting that all Weymouth trains are to be 10-cars between Waterloo and Bournemouth according to management, would this still be an issue?The current set up is that the 2 fast trains xx00 and xx30 off Southampton have similar times to Waterloo. One normally calls at Woking and the other at Basingstoke.
But isn't the idea that the future Poole train and future single Weymouth train provide the 2 tph fast service at Winchester, Parkway and Southampton (and potentially Brockenhurst and Bournemouth)? I think they should have similar 'fast' calling patterns between Southampton and Waterloo, so one service takes Woking and the other Basingstoke as now. (Not fussed which way round.) That way they can both have times half an hour apart at Southampton Central and Winchester, (and also of course in the down direction).
Then the 'new' Waterloo - Southampton service opposite the Portsmouth via Eastleigh provides the 2 tph semifast.
I think you are right to point out that there could be a misbalance in capacity required if the calls are not shared out evenly.
This thread was started specifically to discuss the public consultation (going on now) to do with the new SW franchisee (SWR) bringing in a completely revised timetable in Dec 2018. That's why it only considers SWR...
That's precisely my concern for the Portsmouth line timetable, there's no margin for error or failure, with no looping of the stopping service and the end result is that the fast arrives just 3 minutes behind the stopping service and they are assuming that it will be fault free all the time.
Someone needs to to give them a reality check, as the performance on the direct has been nothing short of abysmal over the last few years and it has become so bad that they have given us forms to carry for certain sections of the line.
That's as maybe. However any mooted timetable from SWR should demonstrate how it interacts with other TOCs' services at key interchange points such as Guildford, Basingstoke and Salisbury. There are a lot of passengers whose regular journeys involve SWR and an interchange to another TOC.
All the timetable questions can be answered by simply looking at the proposed timetables. They are very thorough. Nobody knows about stock yet. The Poole service being the current Weymouth train cut back, rather than the current Poole service, will presumably be largely operated by 444s. Portsmouth via Basingstoke services will probably remain a mix, but nobody really knows for sure yet.Are 450s going to remain on the Poole services (I hope not) and what will happen to the Hedge End service? Will it start at Waterloo still or Eastleigh? Or Basingstoke? Will it remain a mix of 444 and 450?
Depends if it is only Weymouth trains that will all be 10 car, or Weymouth line trains, including the Poole. If Weymouths are all 10, but Pooles aren't, then there'd be a problem. My view would be make them all 10 car to Bournemouth, and balance the main intermediate calls 50/50.
(Ignoring any slight misbalance by having a Clapham Junction call in one of them.)
I’d imagine more 444s would run the tangos with the 442s displacing them off the direct. Will be interesting to see what the slows on the Portsmouth direct run as though. A single 450 is too small, a single 444 is tooposhwasteful and should be used on other routes, and 8.450 is probably over kill....
You might run into power supply issues with 10 car services beyond Poole, plus another 5 in the Poole area, plus a 4 car on the PMH-WEY service, it's more likely that things will continue as now with a 10 car going to Bournemouth and dividing or combining there as appropriate.
Only 3 of the 12 Haslemere starting/terminating services on a weekday are formed 8-450.I wouldn’t say posh, but it is a waste of a 444 on a Haslemere terminator. Not as much as the Alton 444s though - I live in Farnham and love having them on the route but admit it is wasting them on there. A single 444 would be fine on a Southsea semi though.
8 450 is the usual for Haslemere terminators so it would be fine for Southsea semis too
Also talk of more 10 cars as far as Bournemouth on the Weymouth/Poole trains though which would also use more 444s, so they could be displaced from the Portsmouth Direct to that route.I’d imagine more 444s would run the tangos with the 442s displacing them off the direct. Will be interesting to see what the slows on the Portsmouth direct run as though. A single 450 is too small, a single 444 is too posh and should be used on other routes, and 8.450 is probably over kill....
I don't recall trains being booked to couple at Poole at all - unless it has been done in an emergency?Wouldn't there also be issues with coupling units in the platforms at Poole due to the radius of the curve?
