bluegoblin7
The 4-TC can operate in push-pull mode (it did so when it was last at Swanage IIRC) but it is not fitted with any equipment to permit this on the national network (or LUL, for that matter).
One of the locos does support Southern region multiple working, meaning it could be driven from the 4TC unit (which has a driving cab at each end for just this situation). However, a member of staff told me that the top-and-tail is a Network Rail requirement. I wonder if this is because the 4TC unit isn't equipped with the suitable (eg) TPWS equipment? Has it worked on the national network as a driving vehicle at any time recently?
I've never seen it work off the LU railtours TBF
Thanks. I'll go with that. Apart from a bit windy it was nice to ride in the 4TC with a Cl.33 spluttering away at the front, on the return to Wareham this afternoon. Happy memories.11m 4ch
Level crossings
We are continuing our programme of closing level crossings,
and making alterations at others.
In the year ahead: We will make improvements at Ashtead
level crossing and close Buriton level crossing.
By 2019: Additional crossings will be closed, including
Wareham, Waterloo Road and Feltham West. We will also
make safety improvements at White Hart Lane.
Passenger benefits: Improved safety for level crossing users.
The bay? You mean the sidings? Or are there (sensible IMHO!) plans to bring the bay platform at Wareham back into use as well?https://www.networkrail.co.uk/our-r...railway-upgrade-plan-update-2017-2018-wessex/
The level crossing at Wareham will be closing by 2019:
(from the pdf that can be viewed from the above page)
Once the level crossing is closed and Swanage can use the bay, would that allow for both earlier and later trains than what is currently being run in the trial?
The bay platform. The level crossing is what's in effect stopping them from using the bay platform atm, as they're not allowed to use the crossover they need to use to access the bay platform whilst the level crossing is open
There is no bay platform at Wareham.
I visited last weekend. It is clear that Wareham station once had 4 platforms, 2 through up platforms, the existing through down platform & a bay on the down side, now part of the car park. The down bay would be the one to restore, as trains to & from the Swanage line could run on the bi directional down line from Worgret junction without interfering with main line trains on the up line.
Restoring the down side bay,despite it having a platform face, would cost trillions using Network Rail's orange cast of thousands. However if the rules were changed to allow third parties, like the Swanage railway, to put back the bay it could be done for a non comic sum to allow a very practical long term solution. But it depends on passive provision already made by NR for signaling the bay. Has that been done ?
What are you on about? The level crossing is on the far side of Wareham station. If they were reinstating the bay (which I've not heard about), accessing it wouldn't have anything at all to do with the level crossing.The bay platform. The level crossing is what's in effect stopping them from using the bay platform atm, as they're not allowed to use the crossover they need to use to access the bay platform whilst the level crossing is open
The use of locomotives shouldn't really matter long-term since they're hoping to have the DMU ready by the end of the summer...This needs some further explanation from somebody who knows the area (not me).
It's clear from a combination of Google Maps and Quail that there was a bay on the up side, connected to the up main at the down end of the station. There is an existing trailing crossover further west which would enable trains from the Swanage Branch approaching on the bi-di section of the down main to access the bay. All makes sense. There is a foot crossing (and a footbridge) at the up end of the station, with another trailing crossover beyond it. So presumably the current problem is that a locomotive run-round is not allowed because it would pass over the foot crossing twice - hence the need for top and tailing. The local council has a plan to build ramps up to the footbridge to eliminate the foot crossing - hence the thread. However that doesn't seem to be anything to do with the bay - in fact if the bay could be reinstated (at a cost of umpteen million) it would be great for DMUs and push-pull operation but wouldn't help the current operation at all.
Maybe someone from the current operation could confirm my guesswork (or not)!
Passive provision for the bay was included as part of the re-signalling program. Reinstatement of bay is a future goal.
The replacement wheel-sets and bearings have finally arrived at Eastleigh.
How long will it probably take to install them?
At this rate, the 37 and the 4TC will be back next year
