SWR Repaints and Refurbishments
Discussion in 'Traction & Rolling Stock' started by superalbs, 16 Aug 2017.
  1. K.o.R
    K.o.R Member
    467
    6 Dec 2017
    Thanks guys, I will give that a go. Might explain why I've burned through my mobile data so quickly this month...
  2. SWRtrain_fan
    SWRtrain_fan Member
    365
    18 Dec 2018
    Waterloo-Reading Line
    159015 went up to Loughborough yesterday for exterior refurbishment.
  3. Dougal2345
    Dougal2345 Member
    346
    29 Oct 2009
    I'm finding wi-fi on the 444s and 450s increasingly unreliable - it actually works only about 50% of the time for me.
    Either there's no wi-fi signal at all, or there's a signal but my 'phone can't obtain an IP address (the most common problem), or I log in only to be taken to the 'register' screen - and attempting to re-register, just get sent back to the register screen...
  4. DelW
    DelW Member
    1,046
    15 Jan 2015
    Does it also put a Merchant Navy on the front for you? :)
    More seriously, I've more or less given up trying to log in to wi-fi on 450s. My phone shows as connected, but I can't get to a login screen. For months now I've just used my own data, though that doesn't work everywhere along the Direct either.
  5. WVL14
    WVL14 Member
    171
    23 Jan 2011
    Stoke-on-Trent
    444022 (unit 22) was released from Eastleigh 12-6-19.
    444009 (unit 23) went to Eastleigh 13-6-19.
    Also on site are:
    450002 (unit 48) arr 10-6-19
    450078 (unit 49) arr 12-6-19
    450543 was released from Eastleigh this afternoon. This unit still carries the number 543 but will become 043 in due course.
    The 10 car 442 diagram introduced last Monday has not allowed for any increase in units going for refurbishment at present.
    Until further Class 442 units are in traffic, the programme remains one 444 and two 450s.
    159015 (unit 16) travelled from Salisbury to Loughborough 12-6-19, joining 159017 (unit 15) which has been on site since 13-5-19.
    Hope this helps.
  6. SWRtrain_fan
    SWRtrain_fan Member
    365
    18 Dec 2018
    Thanks very much for the refurb updates.
  7. SWRtrain_fan
    SWRtrain_fan Member
    365
    18 Dec 2018
  8. Dougal2345
    Dougal2345 Member
    346
    29 Oct 2009
    I'm not sure they've all got it - I seem to have seen the old-style log in page very recently.
    Don't want to be too negative, but I'd've preferred lots of train information on the front page - most importantly showing whether the train I'm on is running late and so on - rather than lots of links to TV programmes...
    But most of all, I'd like to be able to connect to the wifi and internet reliably in the first place :)
  9. TEW
    TEW Established Member
    5,200
    16 May 2008
    Been on 450543 this evening, seating layout the same as other refurbished 450s but the bins in the vestibules that were removed when they became 450/5s have not been replaced.
  10. RealTrains07
    RealTrains07 On Moderation
    1,409
    28 Feb 2019
    Whats happening to the 450/5s??
  11. RealTrains07
    1,409
    28 Feb 2019
    Is this just interior at the moment then?
  12. TEW
    5,200
    16 May 2008
    They are being refurbished as per the other 450s but are being refitted with the seats removed when they first became 450/5s.
  13. RealTrains07
    1,409
    28 Feb 2019
    Oh are these the historic ones that got first class removed??
  14. SWRtrain_fan
    SWRtrain_fan Member
    365
    18 Dec 2018
    Yes they are.
  15. RealTrains07
    1,409
    28 Feb 2019
    So part of the refurb is putting back first class and changing the numbers, okay.
    Arnt there already units numbered 450/0 ?
  16. SWRtrain_fan
    SWRtrain_fan Member
    365
    18 Dec 2018
    No, in 2008, SWT decided to take 28 of the 450s and convert them to High Capacity interiors; this involved removing first class, removing some seats and extra handrails provided. Therefore they were renumbered 450/5s.
    But later on, in anticipation of the 458s, they all had first class reinstated, however they still retain their 4505XX numbers because they still have extra handrails and fewer seats.
    As part of the Desiro refurbishment now, 450/5s will be converted back to 450/0 interiors; extra handrails will be removed and extra seats reinstated.
  17. 387star
    387star On Moderation
    5,802
    They need to repaint the wall at a Clapham pub as it's swt colours
  18. Train Boy
    Train Boy Member
    175
    28 May 2012
    Dorset
    In fairness, First now have the rights to that livery... just add the plain white SWR logo. :lol:
  19. K.o.R
    K.o.R Member
    467
    6 Dec 2017
    Well, I tried the suggestions regarding the wi-fi. Using the URL kinda-sorta worked. There is definitely nothing whatsoever on either of the new landing pages to allow selection of wi-fi; the only controls are the "Continue" buttons.
    But then half of the Portsmouth Direct line is this mysterious cellular dead zone, so it doesn't work even when you can get connected.
    (Seriously, I get zero bars in Liphook, and never more than 2-3 between Havant and Woking ever.)
  20. pompeyfan
    pompeyfan Established Member
    2,903
    24 Jan 2012
    Anything north of Finchdean towards Buriton and you’re out of luck until you appear the other side of the tunnel.
    The rest of it is hit and miss, but I find areas such as Weybridge to be just as bad.
  21. nuts & bolts
    nuts & bolts Member
    244
    24 Jan 2015
    B & H
    This is similar approaching Farnborough Main on the down line, no signal for approx 2 to 3 miles, then as you enter the station the signal from zero to four bars is imminent.
  22. pompeyfan
    2,903
    24 Jan 2012
    I’ve never had issues between Pirbright and Farnborough, in fact I’ve had data there before as we were running slow and I managed to check the signalling maps to see some sort of Pullman special was in front of us.
  23. K.o.R
    K.o.R Member
    467
    6 Dec 2017
    444040 (the SWR-reliveried one) is currently sporting a "D-DAY STORY" nameplate.
  24. moley
    moley Member
    200
    12 Jun 2011
    It was named at Portsmouth Harbour on the morning of the D Day 75 commemorations and is currently sat at Fratton.
  25. SWRtrain_fan
    SWRtrain_fan Member
    365
    18 Dec 2018
    SWR Desiro Refurbishment
    NB: SWR Desiro refurbishment is currently being done at a slower rate due to class 442 delay
    Partly refurbished 450s:
    003, 007, 011, 014, 026, 027, 028, 030, 035, 036, 040, 074, 076, 086, 087, 093, 099, 109, 110, and 124 (20 units)
    Fully refurbished 444s:
    003, 005, 006, 007, 008, 009, 010, 013, 015, 019, 020, 022, 025, 027*, 029, 033, 034, 035, 038, 039, 040, 041, 042, 044 and 045(24 units completed)(53% complete)
    Fully refurbished 450s:
    001, 002, 005, 006, 008, 010, 012, 013, 015, 016, 018, 019, 020, 024, 025, 031, 032, 033, 037, 038, 041, 543, 073, 075, 078, 079, 080, 081, 082, 083, 084, 085, 091, 092*, 094, 095, 097, 100, 102, 103, 105, 106, 111, 112, 113, 114, 115, 117, 119, 121, 122, 123, 125 and 126(53 units completed)(42% complete)
    *currently being done
    Let me know if any more trains have been refurbished and I will edit this post regularly
  26. WVL14
    WVL14 Member
    171
    23 Jan 2011
    Stoke-on-Trent
    Currently undergoing work at Eastleigh are:
    444009 (unit 23) arr 13-6-19
    450013 (unit 50) arr 15-6-19
    450006 (unit 51) arr 18-6-19
  27. SWRtrain_fan
    SWRtrain_fan Member
    365
    18 Dec 2018
    deleted
  28. SWRtrain_fan
    SWRtrain_fan Member
    365
    18 Dec 2018
    You said 450013 was done then but it's being done again?
  29. 387gwr
    387gwr Member
    22
    6 Jan 2019
    outskirts of london or leeds
    It is really rare to find any trains with the new livery.:(
    I once saw a class 158 strippy colour.
  30. swt_passenger
    swt_passenger Veteran Member
    21,795
    But not unexpected, given that it’s known that none of the existing EMUs are planned to be done yet.
Share This Page
