SWR Strike Timetables
Goldfish62
14 Feb 2010
I'm just starting this thread now as SWR have stated that they're going to publish their strike timetables tomorrow (Wednesday 15th).
Any advance info of course welcome!
HamworthyGoods
15 Jan 2019
Waterloo - Basingstoke / Southampton and Waterloo - Windsor is pretty much what I’ve heard.
Brooklands
20 May 2021
Byfleet
infobleep
27 Feb 2011
Interestingly no service to Earlsfield. So does this mean they are using the fast line for all services?
Good news on the non-strike days in between for Guildford to Clapham Junction passengers. We are getting 2 trains an hour. Yes, it will start later and finish earlier but it's a bonus.
I had hoped to travel on a strike day but as Guildford isn't being served, I will have to travel on a non-strike day instead. I will try and make use of the additional fast services from Clapham Junction though.
Shame they couldn't extend the Woking stoppers to Guildford, as they do on Sunday's but the signallers or lack of them, will be the limiting factor here.
I'm surprised Windsor is getting a service. Is that line a freight route or justcpooukar with passengers?
Chingy
24 Jan 2020
Frome
I'm suprised Windsor is getting a service. Is that line a freight route or justcpooukar with passengers?
Definitely not a core freight route, so I doubt freight would have been the reasoning behind it. Core freight route on the SW trains network is the Southampton to Basingstoke corridor.
infobleep
27 Feb 2011
I thought this was the case, so maybe it's passenger numbers.
HamworthyGoods
15 Jan 2019
It’s to provide a service on the Windsor side to Feltham / Staines and Windsor is an easy place to terminate the service.
Guildford signal box will not be opening
Goldfish62
14 Feb 2010
In previous disputes it's been Ascot that's prioritised.
This time Richmond - Whitton and Virginia Water - Bracknell have migrated to Basingstoke ROC. Barnes to Windsor via Hounslow is Feltham box throughout.
infobleep
27 Feb 2011
If the Portsmouth Direct signalling works had been completed, would that have meant train services to Guildford or anywhere else on the Portsmouth Direct line or staff likely be a limiting factor in the Basingstoke signalling centre?
Of course travelling patterns have changed since covid and it may be that some lines are now less well uses than others.
DanNCL
17 Jul 2017
County Durham
Keeping Windsor open instead of Ascot does of course conveniently allow the Royal Train to operate if so desired...
HamworthyGoods
15 Jan 2019
As there were are no changes planned to the operation of Guildford box in the Pompey Direct resignalling there would be no change.
infobleep
27 Feb 2011
Ok. The BBC article I read gave me the impression is was going over to Basingstoke but I guess if it's a panel devoted to the line, then it needs someone to work it.
HamworthyGoods
15 Jan 2019
Goldfish62
14 Feb 2010
The section between Clapham Junction and Virginia Water and onto the Chertsey line is certainly a fairly busy freight route.
Orac
2 May 2020
Fleet
Can anyone explain please why SWR are essentially running a Sunday service on the non-strike days. The outer suburban (Waterloo to Woking, Alton and Basingstoke) has about a third of the number of services into and out of Waterloo compared to a normal weekday. It's actually worse than on the strike days apart from the early finish on those days.
Dibbo4025
21 Mar 2018
It's an off the shelf timetable with a naturally late start so much easier to adjust to work with the railway only being available from half 7 - there's no capacity to rewrite the entire morning weekday timetable to allow for this with even the Sunday service requiring significant amounts of work
Plus the lower service levels provides redundancy for any residual disruption to hopefully provide a reliable service
TEW
16 May 2008
There's likely to be less trains available for traffic too as there will be staff who should have been working at depots who would have been on strike overnight.
infobleep
27 Feb 2011
South Western Railway seem to be running a weekday timetable this Thursday, with modifications, such as no trains prior to 7:30 - although there is a rail replacement bus running Guildford to Wimbledon before 4 am - I assume due to planned engineering work.
However, Southern branded services are running to a Sunday timetable. Will there be conflicts in places like Havant and Epsom?
Goldfish62
14 Feb 2010
South Western Railway seem to be running a weekday timetable this Thursday, with modifications, such as no trains prior to 7:30 - although there is a rail replacement bus running - I assume due to planned engineering work.
I noticed that as well. Last time it was a Sunday timetable the next day.
infobleep
27 Feb 2011
I remember asking, during the Guards strikes, why couldn't SWR run a Sunday timetable. The answer was it would clash with Southern branded trains in places like Havant.
That may not be the case here though.
Alex365Dash
2 Jul 2019
Brighton
And lo and behold...
1S12 08:30 Brighton to Portsmouth Harbour - departs Havant 09:51, arrives Fratton 10:02 (stopping at Bedhampton & Hilsea)
1P19 08:30 London Waterloo to Portsmouth Harbour - departs Havant 09:51½, arrives Fratton 09:59½ (non-stop)
30907
Although they would have started previous night before the strike commenced, and completed their shift.
It is not really clear why any units which didn’t move on strike days, would not be available if they were done night before. The timetable tends to repeat every 24 hours so the only trains which might be unavailable are the small percentage used during the strike.
HamworthyGoods
15 Jan 2019
Generally each train needs to be “prepared” for traffic every 24 hours.
infobleep
27 Feb 2011
This is why I'm surprised SWR are running a week-day timetable. In contrast, Great Western Railway won't be running any trains to Gatwick Airport. No doubt the reason being the trains need to be prepared I'm not disputing this but it makes SWRs week-day timetable surprising that is all.
I'm quite happy they aren't running a Sunday timetable as I may well wish you travel on the New Line Guildford and in Sundays it's 1 train an hour.
Goldfish62
14 Feb 2010
Are weekday service levels that different from Sundays on most lines at the moment anyway, especially once you remove everything before 0730? Certainly Reading and Windsor have virtually identical service levels all week.
infobleep
27 Feb 2011
Yes. Haslemere to London is 3 trains an hour instead of 2 off-peak. In the peak, it is 4 an hour. Guildford to London via Cobham is 2 an hour instead of 1.
Then you have the peak extras, which seem to be running as it's a week-day timetable. Of course, it starts after 7:30 am, save the rail replacement bus running before 4 am from Guildford.
There will be other differences I'm not aware of but definitely more services. Of course, if one wanted to go from Guildford to Clapham Junction, it's better on a Sunday but that's due to the timetable rather than the number of trains running.
When one considers what GWR are doing, with some services not running and with Govia Thameslink Railway running a Sunday timetable, it's surprising. It is very good that they feel able to so this though
GWR is advising people to only travel on Thursday if absolutely necessary. In contrast, SWR says nothing of the sort. Just that services will be disrupted and busier than usual.
