SWR Tap2Go now valid in London
lkpridgeon
Verified Rep - FastJP
30 Jan 2019
Micheldever Station / Saxilby
I believe it was already working in London before however they just weren't advising anyone to use it due to it being untested.
I've been changed for a Waterloo to Micheldever back in October because of a dodgy guess the system made when I did a same station exit.
Jan Mayen
30 Sep 2020
Sussex
I have a Southern smart card with Keygo on it. I wonder if there is any chance these two companies could link their systems together so users don't have to have multiple smart cards.
TEW
16 May 2008
In theory it should be quite good within London if you are just using SWR services, as it will charge you Oyster PAYG fares and apply Oyster caps, but will also charge NR fares if they are cheaper.
lkpridgeon
30 Jan 2019
I very much doubt any further development will be done on the SWR side of things for a while. I was informed earlier today when offloading my laundry list of bugs that the team setup to handle smartcards was recently disbanded.
py_megapixel
5 Nov 2018
Northern England
I wouldn't hold your breath.
Surely in a sensible connected world it would require barely anything to do, beyond possibly a software update if the machines are still checking whether it's "their" card - they're both ITSO cards are they not?
That's not to say I think it will happen. It probably won't...getting the two companies to cooperate is probably easier said than done, however.
mattdickinson
14 Nov 2010
Uxbridge
Both cards are currently accepted at the Clapham Junction and Wimbledon gatelines, so this can't be the issue.
py_megapixel
5 Nov 2018
Northern England
The issue isn't gatelines, rather ticket machines.
For example, I remember hearing (though don't quote me on this) that at one point Stagecoach Bus ticket machines would refuse to put anything onto cards which were not issued by either Stagecoach or the local PTE, even though from a technical standpoint, any ITSO card was entirely compatible. If SWR or SR's systems are doing the same, then there is a problem.
matt_world2004
5 Nov 2014
Would the pay as you go work on other greater London services. I know if you have an itso travelcard loaded onto a toc smart card they work on the tube.
It used to be you had to manually present your paper counterpart ticket to the driver on buses but I think they updated the software to accept toc smart cards too
infobleep
27 Feb 2011
When you say disbanded, do you mean made redundant or just moved around within the organisation?
Hadders
27 Apr 2011
Just to clarify is this Tap to Go only available on SWR services?
If so it really isn't much use, someone travelling from, say, Twickenham to Victoria (changing at Clapham Junction) couldn't use it.
Wallsendmag
11 Dec 2014
Wallsend or somewhere in GB
I think it includes TfL but I'm not sure about other TOCs, apart from being certain it doesn't include LNER services.
Hadders
27 Apr 2011
It really should be available on all TOCs where Oyster is accepted. I bet it won't be which will just cause more complication and confusion.
mattdickinson
14 Nov 2010
Uxbridge
Tap2Go is only valid on SWR services. Keygo is valid on GTR services, and a few GWR services. Neither is valid on any TfL services/
Hadders
27 Apr 2011
Sounds like a right mess to be honest. Fine if travelling to Waterloo but useless if going anywhere else. A paper travelcard would almost certainly be better value but I suspect the publicity won't mention this....
matt_world2004
5 Nov 2014
TOC smart tickets work on tfl/other London TOC services when they have a travelcard loaded onto them.Dont know about pay as you go.
infobleep
27 Feb 2011
Out of interest, what happens if someone taps in at Clapham Junction on an SWR tap2go and takes a train to Victoria and tried to exit there?
Hadders
27 Apr 2011
A Penalty Fare and a thread on this forum I’d have thought!
lkpridgeon
30 Jan 2019
It most likely would register an unknown tap/tap out assuming Victoria isn't in the database. So £25 bill or an autocomplete to your most frequent origin/destination station. There's also a high chance the barriers wouldn't open, so wave through by gateline staff with confused looks on their faces.
There's also the odd chance it may even work, however personally I wouldn't chance it if you don't have a ticket you can fallback on.
infobleep
27 Feb 2011
Interestingly the Clapham Junction gate lines would need to support both, hence why I started the journey there.
I can well believe a busy station waving you through.
Perhaps I should have chosen Battersea Park, which isn't so big in terms of footfall or with a KeyGo, Queesntown Road (Battersea). Both of course starting their journey at Clapham Junction to reach the places.
DorkingMain
25 Aug 2020
London, UK
The issue (as I understand it) is that a smartcard can't distinguish what route / train you've used, and this causes problems for the purposes of ORCATS where tickets are sold as "Southern only" etc.
infobleep
27 Feb 2011
So how does it work for single TOCs where mutiple routes exist at different prices to get between stations? For example Guildford to Motspur Park is more expensive via Clapham Junction than travelling direct.
mattdickinson
14 Nov 2010
Uxbridge
According to the T&Cs , "We will charge you the cheapest fare based upon the taps you have made on your journey and the journey length to best guess the route you took"
infobleep
27 Feb 2011
See now
I guess if you can make an unofficial connection at Clapham Junction, for a train to Motspur Park, you night get charged the cheaper fare.
I might try it sometime. Doesn't bother me which fare I get charged, as long as I hold a valid ticket when travelling
Actually scrap that. Discounts aren't valid on it, so I won't be trying it out as I won't hey a third off if I do.
