Television technical query
Peter Mugridge
8 Apr 2010
Epsom
I wonder if anyone on here has knowledge of the technicalities of modern TVs?
We have a Sony Bravia and the TV guide menu on it is one where you can select an upcoming program and press a button to select it, and when it starts the TV automatically turns over to it.
Or it did.
That worked very well, up until January 1st from when it has simply said "this data event is invalid" and it just won't set a turnover; we now have to manually change channels every time we want a different one.
Any ideas why?
Is it possible that my wife - an inverterate random button pusher when she has a remote in her hand - could have somehow disabled the function?
Or, given that it was January 1st when it stopped working... please don't tell me that some of these TVs were only programmed to work that function up until the end of 2020...?!
Mcr Warrior
8 Jan 2009
Have experienced the same issue on an otherwise perfectly serviceable Sony TV.
General consensus is that it's a Sony software issue (built in obsolescence?)
Trackman
28 Feb 2013
Lewisham
Is there a software update available (I assume it has internet connectivity), or even a reset to defaults option?
Mcr Warrior
8 Jan 2009
Apparently not yet. Plenty of folk moaning about this on the Sony Community forums. Might have to collectively mither Sony's Customer Support and shame them into action.
Peter Mugridge
8 Apr 2010
Epsom
It's not a smart TV... this one is a few years old.
Well, at least I now know it's not just ours, then...
Bevan Price
22 Apr 2010
Not had a similar problem with my Sony Bravia.
Possibly silly questions, but have you tried a channel retune? Freeview keeps "fiddling" with channel settings, and may have done something that upset your TV. Alternatively, could the batteries in the remote be getting a bit "flat". In the past, I have noticed that my remote does not work some of the functions when one or more of the batteries are low on charge.
A0wen
19 Jan 2008
Won't be batteries - because that's merely sending the command to the TV, which is clearly happening.
Might be worth retuning the set (do a factory reset) as it may be the EPG (Electronic programme guide) has been changed as part of a retune.
Also in the settings there is usually one about choosing which EPG to use, check to see if it's on the standard Freeview one - a while back some sets (not Sony) used the Guideplus EPG which was discontinued and the sets stopped displaying anything until it was switched to the Freeview EPG.
Mcr Warrior
8 Jan 2009
As mentioned upthread, this is almost certainly a firmware issue affecting certain older (10 years +) Sony TVs.
