TfW Class 67+Mk4 sets: trip planning/experiences, diagram updates etc
Jez
22 Jan 2011
Neath
Whilst at Cardiff earlier I saw a unit was covering for the 1253 CDF-MAN. It seems every day recently a unit has covered 1 diagram. Is it expected to see a return to 5 diagrams being covered from Monday?
sd0733
7 Nov 2012
Afternoon
What is the plan for tomorrow please ?
Thank you
Dave
Tomorrow Should be:
67020+HD01 1V33 1W61 1V62
67008+HD02 1W13 1V39 1W96
67010+HD03 ECS Crewe ETD to Crewe ATC for heavy exam
67014+HD04 1V91 1W57 1V46 1W65
67015+HD05 Repair/Minor exam at Crewe
67017+HD06 1V31 1W55 1V42 1W63
67025+HD07 1W59 (From Crewe) 1V50
Tuesday should have HD01/02/04/06/07 in service, 04 then stops for tyre turning so Wednesday and Thursday are planned for HD01/02/05/06/07 in service then HD04 should be back from Friday giving 6 available with 1 spare rake on Friday.
Welshguy1048
6 Apr 2023
Prestatyn
Tomorrow Should be:
@sd0733
Thank you
Dave
Topological
20 Feb 2023
Swansea
W11 will be yes.
I saw that and realised that even in these lower commuting times it was risky to try 1W11. Gone for the quieter 1W12. 1W11 was a 2-car in the end, so was a good choice to let that one go.
Less good news that 1W13 also seems to be a unit this morning.
Jez
22 Jan 2011
Neath
Looks like 1W12 was turned back at Wilmslow? 30 minutes late so at least you should get delay repay.
sd0733
7 Nov 2012
Due to HD02s issues at Canton, 67025+HD07 will now run empty to Chester to work Chester to Holyhead on 1W96.
This will put sets in the right place for tomorrow, there's no confirmation that HD02 will be ready for the morning, it's planned to work 1W13 but if it's not ready in the morning will go on 1W96 instead.
37052 xb mr
6 Dec 2023
Stockport
Cheers
mikestone1952
12 Feb 2011
If RTT IS correct 158831 worked 1W11, I think the first non-197 substititution for a while, and 1V37 to Salop where 197020 replaced it.
1W59 197020 from Cardiff, attaching 197122 off the Chester at Crewe, by eyeball, replaced by 197010 according to RTT.
For some weird reason RTT has the ECS from Crewe to take over 1W96 as a dmu at 40 mph, although its actual times don't really reflect that.
Jez
22 Jan 2011
Neath
Yes a 158 worked the first Cardiff to Manchester. It looks like it later went on Birmingham-Cambrian services which is why it was swapped. I think its the first time a 158 has worked to Manchester in a while.
Topological
20 Feb 2023
Swansea
Yes, thankfully the Avanti was slightly late and took it over the 30 minutes (is it wrong to say thankfully when it went over the threshold for more refund).
Was late due to an ambulance being called to the Holyhead train that runs in front of 1W12. We sat at Craven Arms.
Sounds like tomorrow is looking better.
mikestone1952
12 Feb 2011
1W96 shows in RTT as 197 coupled to the mk.5s - as it happens weather and a signal fault mean the Cardiff - Chester bit is reported 104 late.
The restart seems to have been initially 1Z96, then changed to 1T96 but no-one seems to have told Chester as it has Chester South Jcn and Flint times on the original schedule.
37052 xb mr
6 Dec 2023
Stockport
RTT shows the unit to Chester
Then the 67 & set forward,
The 67 & set left Chester on time in 1W96 path.
The unit hasn’t made Chester yet,
2 hours late.
Jacob Porrett
28 Jan 2022
Telford
Today at at Crewe depot (12/5/25):
67022 light engine
67015 connected to HD05
67025 connected to HD07 which then left on 5W96 to Chester to replace the 197 on 1W96 as mentioned above.
sd0733
7 Nov 2012
BillStampy
6 Jan 2024
Llanharan
I don't want to speak too soon as I did the last time I said this, 1V50 is still showing as going to Swansea next week. Maybe the new timetable change will revive it, maybe not... hopefully!
