Thames Valley changes 07/09
Discussion in 'Allocations, Diagrams & Timetables' started by cactustwirly, 24 Aug 2015.
Thread Status:
  1. cactustwirly
    cactustwirly Established Member
    5,310
    10 Apr 2013
    From the new timetables I gather that the Thames Valley local services & Newbury services will be declassified and worked by 165s, North Downs services terminating at Redhill will also be declassified 165s. The rest, including Oxford fasts and Bedwyns will be 166s with first and standard classes.
    This is probably preparation for the cascade to the west.
    Rail Forums
  3. Rich McLean
    Rich McLean Established Member
    1,567
    6 Feb 2012
    Correct, however there will be times when a 165 will be on a Oxford Fast, and a 166 on a stopper due to unit displacement during disruption or for diagram balancing purposes
  4. Deepgreen
    Deepgreen Established Member
    4,403
    12 Jun 2013
    Betchworth, Surrey
    So when are FGW going to tell us, the passengers, about this imminent worsening of our service?! What happens to those with first class seasons when the trains no longer include first class accommodation?
  5. swt_passenger
    swt_passenger Veteran Member
    21,797
    The new timetable will cease to show [1] at the head of the column for affected trains, I expect station timetable posters will also be altered.
    There is apparently going to be a refund scheme if fares are withdrawn. If you can still optionally travel first on a fast service I assume the fares will remain in place.
  6. Deepgreen
    4,403
    12 Jun 2013
    Betchworth, Surrey
    Not really what I would call helpful information - simply amending the detail on the timetables rather than advising us via, say, posters/in-train notices. No option for a fast train from Betchworth.
  7. berneyarms
    berneyarms Established Member
    1,986
    26 Nov 2013
  8. swt_passenger
    21,797
    A poster in another forum has said that first class season ticket holders are being contacted directly about their future options.
  9. infobleep
    infobleep Established Member
    9,358
    27 Feb 2011
    Could they keep first class as on Sundays trains stopping at Betchworth going to Gatwick Airport?
  10. Deepgreen
    4,403
    12 Jun 2013
    Betchworth, Surrey
  11. infobleep
    9,358
    27 Feb 2011
    On the Woking to Waterloo stopping services, the odd one which starts before Woking, some have first class on them in the peak. May be that will happen on NDL so that first class revenue can remain.
  12. Deepgreen
    4,403
    12 Jun 2013
    Betchworth, Surrey
    Well, if they have formally removed first from the stoppers (as denoted in the timetables - assuming they correct the two errors) then they will not be able to enforce first on those trains that are advertised as standard only even if they happen to provide a 166 instead a 165.
  13. infobleep
    9,358
    27 Feb 2011
    May be they have only formally removed first from most of the stoppers but not all.
  14. Deepgreen
    4,403
    12 Jun 2013
    Betchworth, Surrey
    The 7 September FGW timetable shows all weekday stoppers as having no 1st, except the last trains of the day each way, which run to/from Gatwick. The timetable also shows the 1743 and 1843 stopping departures from Redhill as having 1st, but this must be an error as the incoming trains to form these two do not have 1st. So, not only have FGW failed to publicise the change effectively, they've published wrong information!
  15. infobleep
    9,358
    27 Feb 2011
    I take your point. Given that first class is available once a day Monday to Friday, could they keep the first class fares but also offer a refund for those who no longer want a first class season ticket.
  16. 181
    181 Member
    274
    12 Feb 2013
    Does anyone know whether there are any significant changes to the actual times of the trains? Or is it just first class provision that's changing?
    If there are changes to times, they haven't been well publicised. The fact that the printed NRT makes no mention of a September timetable change is (sadly) not surprising, but I would have expected some publicity at stations (I didn't notice anything at the 6 stations on affected routes that I've used in the past fortnight) and on the FGW website (there doesn't seem to be anything until you click through to the page of pdf links, and the link to that is 'Timetable from 17 May 2015', with nothing about September).
  17. berneyarms
    1,986
    26 Nov 2013
    No changes to times on local services - just first class being removed.
  18. 181
    181 Member
    274
    12 Feb 2013
    Thankyou, that's useful to know. I wonder why FGW felt the need to put two sets of pdfs on their website -- it would have been easier for them, and more useful to the public, if they'd just used footnotes to indicate the removal of first class in September.
  19. Deepgreen
    4,403
    12 Jun 2013
    Betchworth, Surrey
    First day of the withdrawal of first class from the Reading to Redhill trains today (the stoppers), and my train had... first class! 165114 operated the 1113 departure from Betchworth and I assume it will have operated all day on the line.
  20. cactustwirly
    5,310
    10 Apr 2013
    Its likely it will be like the botched 166 declassfication
  21. JonathanH
    JonathanH Established Member
    3,697
    Well, at least with 165s, they can't declassify first class one end, allow it to become vandalised, send the units off to Wolverton and then have first class swapped to the end which was initially declassified.
  22. Bishopstone
    Bishopstone Member
    1,056
    24 Jun 2010
    Seaford
    Have the catering trolleys appeared on the Reading-Gatwicks today, or is that for later implementation?
  23. infobleep
    9,358
    27 Feb 2011
    The 09.13 Guildford to Gatwick Airport certainly had one this morning so yes. The 19.13 Gatwick Airport to Guildford didn't so that must be one that isn't due to have such a thing.
    I'm surprised they have returned given they got rid of them in the first place.
    Govia Thameslink run services also don't have them any more so I was expecting a trend of get rid of and don't bring back.
  24. Bishopstone
    Bishopstone Member
    1,056
    24 Jun 2010
    Seaford
    I wonder whether the trolleys are the same as those used until July on Southern/GatEx, and indeed whether some of the Rail Gourmet staff have moved over to the North Downs.
  25. infobleep
    9,358
    27 Feb 2011
    They looked similar. Reminded me of South West Trains trolleys but I didn't look at it too closely.
  26. Deepgreen
    4,403
    12 Jun 2013
    Betchworth, Surrey
    Another stopper - the 0919 from Betchworth - was a 166 today - so first class again! I heard announcements about catering trollies on the Gatwick route - can't imagine how they'll get those up and down the train crowded with luggag, kids, bikes etc!
  27. jimm
    jimm Established Member
    5,007
    6 Apr 2012
    Well they've managed for more than 20 years to Oxford and on the Cotswold Line.
  28. infobleep
    9,358
    27 Feb 2011
    They use to have them.
    Also the 18.30 Waterloo to Portsmouth Harbour service has a trolley. It simply stays in the middle of the train in one of the vestibules and people go to it if they wish to do so.
    I don't know how popular it is vers those which move down the train but South West Trains haven't got rid of if so it must do OK or that or it's in their franchise agreement and it doesn't matter whether it's profitable it must exist.
  29. swt_passenger
    21,797
    There is no catering requirement at all in the SWT franchise agreement, it is entirely a commercial option.
  30. infobleep
    9,358
    27 Feb 2011
    That's interesting. Then they must be making money from it, which means not being able to move down a train isn't always a barrier to having catering on a train.
  31. hassaanhc
    hassaanhc Established Member
    2,190
    5 Jan 2014
    Southall
    When I used the 1759 from Bournemouth as far as Woking on Tuesday 18 August (during the £20 offer), the trolley stopped every 2-3 rows of seats for someone to buy something. Must have made quite a bit of money!
Thread Status:
Share This Page
