What an absolute mess, I will never understand why the cretins that do this feel the need to, it looks horrendous. Hopefully they get caught and a suitable punishment dished out.
GTR generally do not now hold trains (or stop additionally) for comfort breaks. Although SWR is also a busy network, GTR are simply dealing with equal network constraints in a different way - it can be impractical to delay services heading towards the East Croydon/West Croydon/TL Core corridors if there is a staffed station where people can use the facilities.
I believe the gangways are actually locked out of use due to inherent flaws with the internal “second-man’s side” gangway door mechanisms - a design which Bombardier had about a decade to get feedback on (via repeated feedback from Electrostar crews) and then correct, but they didn’t.
On services expected to run without a rostered second member of crew, which applies to the vast majority of 387s at some point during their journeys, there isn’t anybody to check the doors are safe and secure during transit. So the main cab door (the other one, which is rather more robust) is locked at each end of the corridor connection.
There is barely any extra time taken to set up the gangway doors in the corridor connection positions - about 20 seconds on 387s, especially because one of the steps for securing the doors is actually removed on the newer variants of Electrostars!
Not always. There were originally a select few which did operate via London Bridge.
Yes I must admit I've noticed a lot more of both lately, mainly seems to be confined to 313s and 365s though..... perhaps there's a theme of what Hornsey are prioritising (i.e not what's leaving!)...Punishments are derisory and every day I am seeing more graffiti inside and out, plus more etching.
700 in hove yard. Don't know the number
Now that is truly shocking. And of course the train would not be able to run in service in that condition so would lead to cancellations and huge inconvenience, in addition to cleaning costs.
We do seem to be seeing more and more of this around the south east. The SE metro fleet is now regularly very badly graffitied.
I wonder what’s caused the recent rise in attacks?
I'm not sure if half term has much to do with it, though it is half term this week which does see a rise in incidents on the railway. However, this is pretty professional high scale graffiti, so probably a bit more organized. Maybe new trains are seen as a challenge.
Says a lot about the security at the depots worse affected. The vermin involved could have just as easily been a terrorist attaching a device.The unit in Hove Yard is not stabled for service - so this particular incident has not led to a cancellation.
There have been units in service with reasonably significant graffiti which have been in Brighton Down Yard overnight. With 700s, you can't short form to leave the damaged unit behind.
Not 700126 by any chance? Forgot it was half term...
700s also on test on the Eastbourne route today (and yesterday). There's already a 700/1 berthed in Eastbourne Sidings, but I'm not sure why they'd be doing driver training on this particular route...are there any plans for TL to widen their wings to this route?
Agreed!I saw that when taking the scenic route to Brighton (via Ashford) because of engineering work. 700s seem to be all over!
That would free up 3x377s, but, at the same time, would put even more pressure upon the NHS with an increase in back problems!Rumours they are yes. Could be the Eastbourne to London Bridge peak services....
the more Thameslink take over, the less OBS's are required
Could it not just be swapping the unit from EBN? They need running every X amount of days out of traffic.700s also on test on the Eastbourne route today (and yesterday). There's already a 700/1 berthed in Eastbourne Sidings, but I'm not sure why they'd be doing driver training on this particular route...are there any plans for TL to widen their wings to this route?
Graffitis are also starting to appear on the SE network as well.Punishments are derisory and every day I am seeing more graffiti inside and out, plus more etching.
(...) GTR to actually empty the tanks and make sure the toilets are available for use.
No - there was just one unit (a 700/0, I believe) running back a forth between Three Bridges Depot and Eastbourne - without touching the sidings - throughout yesterday and today (ending at Three Bridges).
