Cancellations to services between Brighton and Bedford
Due to a number of incidents earlier today between Brighton and Bedford fewer trains are able to run on all lines.
Impact:
Train services running to and from these stations will be cancelled, delayed by up to 30 minutes or revised. Disruption is expected until 15:00 01/02.
Customer Advice:
Please allow extra time for your journey, and check journey planners before and throughout your journey.
Please also check information screens at stations and listen for staff announcements.
To assist you with your journey, your tickets will be valid on the following services:
> Southern and Gatwick Express services between London and Brighton.
> South Western Railway services between London Waterloo and Wimbledon.
> Southeastern Railway services between London and Sevenoaks/Rainham. (Please note this does not include HS1 services).
> London Tramlink between East Croydon and Wimbledon.
> London Underground via any reasonable route.
> London Buses via any reasonable route.
> DLR services via any reasonable route.
> METROBUS services between Redhill, Gatwick Airport, Three Bridges and Crawley.
Please note the following service alterations that will impact your journey:
> St Albans to Sutton services will operate hourly instead of half-hourly.
> Kentish Town to Orpington services will divert into and restart from London Victoria.
> Brighton to Cambridge services will divert into and restart from London Kings Cross.
> Bedford to Gatwick Airport services will operate at a reduced frequency.
> Passengers travelling from Earlswood and Salfords may be required to make an additional change to complete your journey.
How is this currently affecting the train service?
A reduced service is currently in operation until the fault with the signalling system can be resolved.
What incidents are currently affecting the train service?
Ongoing Incidents:
A fault with the signalling system has occurred in the St Pancras International area. In this particular situation the fault has been confirmed as a 'Track Circuit Failure'. This means the signalling system is unable to automatically verify if the next section of track past the affected signal is clear.
The rail network is designed so that if a signal stops working, trains will stop before they reach it. Whilst this issue is ongoing, train crew will stop at the affected signal and contact the signalling centre to confirm their location, which at this point the signaller will verbally authorise the driver to continue towards the next signal. This process adds time to every trains journey, which means services can experience short delays. This is occuring across two consequetive signals in between Farringdon and St Pancras International.
It has been discovered that this is the result of flooding within the tunnels that operate through Central London and specialist teams are currently onsite and are attempting to drain and pump away excess water to allow full testing and repair to be carried out to the signalling system. It was originally believed that melting snow and ice was the cause of the issue, however several leaks have been found in the tunnel walls so further assessments are ongoing to establish the exact cause of the water ingress. This will require short blockages to the line through this section of railway to allow the teams onsite to be able to make a comprehensive visual inspection and as a result, services may temporarily come to a stand whilst moving through this area.
Previous Incidents earlier today:
Earlier today, Network Rail notified us that multiple sets of points (moveable sections of track that allow trains to pass from one line to another) had failed in the St Albans area. These specific sets of points in particular are the ones used by trains to go into the sidings and turn around after they terminate at St Albans. As a result, services destined to terminate at St Albans were revised to turn around at West Hampstead.
Specialist engineers from Network Rail Signalling & Track teams attended site and were able to promptly identify the fault and enact repairs to enable services to run normally.
A train earlier today (The 0543 West Hampstead Thameslink to East Grinstead) sustained damaged to one of its windows and the glass had shattered. This unit subsequently was required to be taken out of service and proceed to depot so that a repair could be carried out.
As a combined result of these incidents, services have become congestion along our routes, causing delays to a number of services. Our Train Service Managers are now working hard to minimise the impact this incident will have to our services.
We thank you for your patience during this time and we apologise for any inconvenience this may cause to your journey today.
Last Updated :01/02/2019 12:15
