So you want to ignore some services and then question the frequencies of that station get?
I can't decide if you deliberately misinterpret and twist things to suit your own agenda or if you keep genuinely misunderstandings things which are perfectly clear.
The issue in question is how passenger flows and train movements might interact at *core* stations, in particular how it will work when passengers are waiting on a *core* platform to board a train whilst other earlier trains arrive and depart from the self-same *core* platform. So there's absolutely no relevance to King's Cross departures - they won't be serving *core* platforms.
Today doesn't equal tomorrow. That said the timetable is still not 100% with some changes still being made that will affect GN service so talking about timings isn't possible at the moment.
Right. So any assurances you give about how things will work are meaningless. Whereas we can look to today as a guide to how things may work in the future, on a railway which northwards from Copenhagen Junction will be barely changed from today.
Depending on where you are travelling from Moorgate may be an option. Considering modelling is showing reduce Moorgate usage as Farringdon becomes an alternative for some IIRC and Moorgate's uplift in service means your views are ignoring a way for some passengers to access Finsbury Park and GN/TL services from there.
Moorgate is only really an option for a small handful of outer stations - Potters Bar, Hatfield and Welwyn Garden City, perhaps Stevenage if you're willing to heavily sacrifice journey time for a direct journey. In the grand scheme of things this is negligible. Perhaps there may be a shift which might reduce today's heavy overcrowding on Moorgate services (although the worst overcrowding is from the Hertford line), but you're talking about a drop in the ocean compared to the wider proposed TLP network.
They would be able to tell. You can do that now with apps/websites and its only going to spread further. Anyone with a mobile can now see live running data for Thameslink from Luton to Brighton, so there is the ability to see the data. And yes I believe that commuters will access this. And that's without any official changes to the apps, or anyone coming u with a new app that deals with this very issue. Its all possible.
Either you've misunderstood (yet again), or you're talking utter rubbish. My point was that the services in question have a comparatively greater risk of delay *on route*, *after the passenger boards them*. No app can reliably predict this!
not sure your point over no seats is all that valid anyway.
So you're suggesting it's not "all that valid" that there will sometimes be trains serving core stations where the number of intending passengers exceeds the seating capability? Get real.
So basically your fellow rude commuters
This comment is rather revealing about your attitude to passengers.
More and longer trains means people are spread out better and door ways that accommodate three not two people at once means I believe your views are completely unfounded. That said tests were done with real people (mix of commuters and non) and found the expected dwell times are within reality. Don't forget the 700s are designed to see 70% of its max capacity change at every station within the expected dwell times.
All the above is hope. The proposed Thameslink throughput has not been tested to the level that it will be expected to perform, day in day out.
But I maintain that the Tube is a good example here as it's working to the same principles on a smaller scale (so shorter period between destinations can it's all scaled down too). Look at the SSL lines or even the Northern with multiple difference destinations from the same platforms. And they work with higher frequencies too.
Regarding the Northern Line:
In the southbound direction the entire City branch service is timetabled to run to Morden, so completely irrelevant to Thameslink. On the less-busy Charing Cross branch one train in four runs to Morden, the remainder terminate short at Kennington. So not a multi-branch setup.
In the northbound direction there are just two main branches, Edgware or High Barnet, with a very small handful of short workings to Golders Green or Finchley Central, plus a small proportion of trains to Mill Hill East (which still serve the entire central area plus over half of the High Barnet branch). So just 2 main flows, not the 5+ that core stations will see.
Nonetheless, since you think this is a good indicator of how Thameslink may turn out in reality .. perhaps you might wish to pay a visit to somewhere like Bank northbound at 18:00 on a weekday. Barely any trains get in and out within the timetabled dwell time (some go *way* over), and at times the driver has difficulty getting the doors closed and fully carrying out the 'safety check' before moving off due to passengers on the platform. Quite a bit of pushing and shoving between competing passenger flows. All in all hardly a good passenger experience.
The same happens at other busy platforms, such as London Bridge, Moorgate, King's Cross, Euston. The number of doorway positions on an 8-car class 700 will actually be less than a Northern Line 95 stock, and a 12-car class 700 will only have one more. LU has acknowledged that it will be very hard to further uplift the Northern Line without changes to the service pattern, likely further segregation, although this too is not necessarily viable due to entrenched passenger flows.
On the subject of the 'safety check' before moving off, if you pay a visit to the southern end of the Northern Line you'll find a range of trial measures in place aimed at influencing passenger behaviour following a dragging incident that was very close to being fatal, a significant underlying cause of which was passengers clustering around doorway positions on a crowded platform. Whilst some of these measures have had some impact, generally they have not been successful.
So far from plain sailing on the Northern Line, despite being a far less ambitious arrangement than Thameslink Programme.
