whoosh
- Joined
- 3 Sep 2008
- Messages
- 1,370
The issues surrounding 717s are over signal sighting. The driver sits further back from the windscreen and the view to the right isn't good at all. Approximately 20 metres (One car length) needs to be given to sight a right handed signal (which is most of the signals on the NCL). This places many stopping markers back and results in SDO for five cars.
I'm guessing the issue at Brookman's Park is on the Down Slow (which is a six car platform). The current stopping point is right up against the signal, which is on the left (717s have a worse view to the left as well - a narrower tunnel-like view compared to 313s). However, stopping further back could also cause problems as the signal is obscured on approach by a deftly placed overhead wire mast which completely obscures it!
On a 313 the driver can lean forward to see the signal before departure, or look out of their side drop down window at the current stopping point. On 717 a driver can't see the signal by leaning forwards as the view out of the windscreen is much narrower, and the drop down window is in the cab door which is slightly behind the driver - so no good.
