The demise of bus stop timetables
miklcct
2 May 2021
Cricklewood
Most bus stops for Yellow Buses in Bournemouth haven't been updated with the September network changes including the express route 3x starting from this week, except at the new temporary stops at Lansdowne which were only set up after the network change.
Deerfold
26 Nov 2009
It was not only the frequency of changes but the sheer quantity (almost every route of every operator) being changed at once, and then multiple times thereafter, completely swamped the staff member in my county, and that of the local operators, both of whom are only just resourced for the 'normal' level of work. Couple that with the closure of office buildings making simple printing of the displays an issue. Electronic displays, from multiple suppliers, are still often hampered by legacy back office systems, requiring uploading and often manipulation of data to get them to work. Some smaller operators are unable to provide the information electronically at all, not necessarily having the expertise available. All of this requires more staff time, sometimes this is shared with the same staff member(s) doing the roadside displays.
That makes perfect sense.
However what happened in West Yorkshire was last spring and summer when timetables were changing frequently at short notice, roadside timetables were unchanged.
Our timetables were removed the weekend that my buses returned to pre-Covid times at the end of August. They've changed infrequently since then, but not been replaced.
Andyh82
19 May 2014
There is a big benefit to hindsight there.
I’m not sure back at the start of the first lockdown anyone had any idea what was going to happen with timetables, and whether it was worth blanking them out, or leaving them as they’ll be back to normal soon, or indeed if the staff were available to do such a task, or even if it was worthwhile or technically possible.
krus_aragon
10 Jun 2009
North Wales
There is a big benefit on hindsight there
Conwy council had replaced roadside timetables with an explanatory notice by the summer of 2020, at the very latest. I suspect it was a fair while sooner (but I'm working from memory here).
johncrossley
30 Mar 2021
A lot of the problem outside London is that many bus companies kept tinkering with the timetables. TfL was largely back to normal service by last summer (albeit with school duplicates/extras). Some nearby countries seemed to switch to Saturday or Sunday service for a while, which meant that you could simply announce that instead of creating brand new timetables from scratch but even then they seemed to be back to regular times before long. Obviously when some bus times are coordinated, either with other bus times or train times, then there is less temptation to keep messing with the timetables. Frequent timetable changes is often given as a reason for the decline in bus usage outside London since 1986.
RT4038
22 Feb 2014
When the taxpayer is taking the risk on revenue then it is easy to run timetables no longer in tune with market conditions. When the taxpayer is not then the temptation to change to improve the financial position is quite compelling.
johncrossley
30 Mar 2021
But operators have enjoyed the Covid-19 support grant, meaning that operators can maintain service levels without fear of losing money.
8 Mar 2018
Those notices are still in place. Although Llandudno Junction Tesco stop seemed to have times.
TUC
11 Nov 2010
In West Yorkshire Metro's case, our local bus stop doesn't even have contact information or links on it. They really aren't making it easy.
(image shows photograph of West Yorkshire Metro bus stop)
AndrewE
9 Nov 2015
I was in Edinburgh a week ago and asked about the availability of a printed network map, to be told that Covid changes were so great that they weren't doing one currently. Which ignored the facts that a) it is still available online (but rather difficult to read if you print it yourself) and b) I don't think the network/routes have changed anyway!
The on-line times for all the routes I used seemed to tally with the old pre-covid timetables in the house anyway!
Deerfold
26 Nov 2009
They already knew the timetables were returning to normal. They've then changed as normal for another year and have not returned.
When the timetables were changing frequently for 5 months they didn't remove them.
TheGrandWazoo
18 Feb 2013
The issue is that many of the PTEs and councils stopped doing it because of the speed of changes and that predates the introduction of the support scheme, given that it wasn't actually introduced until August 2020 albeit with some backdating. Whilst many services did return to the pre Covid levels, the problem was that you many more changes in terms of social distancing, schools requirements and then many other challenges such as staff isolating.
ps you may have forgotten that pre-1986, in the halcyon days of relative stability to route networks etc, passenger figures fell year on year and that London's passenger figures have been falling since 2014
Deerfold
26 Nov 2009
The ones at my local stops are just visible in the right light. The vital information did fade very quickly.
Andyh82
19 May 2014
My services have certainly not been the same for 12 months, I think First have tweaked the timings or the frequencies of the running times a dozen times since the start of the first lockdown, and many of those seem to have been with a few days notice. Plus my stop is also served by Arriva, and they’ve changed a few times as well, and often on different dates.
johncrossley
30 Mar 2021
Compare the latest London bus passengers figures against 2000, 1990 or 1980. Do the same outside London.
I created this graph from
https://assets.publishing.service.g...loads/attachment_data/file/929560/bus0103.ods
You can see the fall in bus usage in the PTE areas was halted in the early 80s and passenger numbers stabilised, but after 1986 there was a dramatic fall.
TheGrandWazoo
18 Feb 2013
You don't think the end of massively subsidised fares in places like South Yorkshire might have had an effect? Even your graph shows that in the halcyon days of stability, London dropped by a third. However, this is really drifting off topic.
Andyh82
19 May 2014
You forget how strictly the first lockdown was observed. Everything was frozen in time and not changed until the Summer not just bus timetables. A poster saying ‘Book now for Easter Sunday’ outside the local pub gradually getting more and more faded. Remember so many jobs that could have continued didn’t continue during those weeks. Stuff was pared right back.
RT4038
22 Feb 2014
I was referring to your comment 'Frequent timetable changes is often given as a reason for the decline in bus usage outside London since 1986'.
During the Covid period bus operators couldn't maintain service levels due to staff shielding, sickness, bus cleaning regimes etc.
Llandudno
25 Dec 2014
Might be a tad more useful if Conwy County Council had updated the timetable cases in and around Llandudno Junction station area rather than at a supermarket!
Typhoon
2 Nov 2017
Kent
Local timetables changed two weeks ago. I can't speak for everywhere but certain some local bus stops (and these are not the main stops) have updated paper timetables in the cases at stops. I don't think it was immediate, but two weeks is not bad. Stagecoach East Kent.
(Not perfect, they took over a route from an independent at the start of August. The independent is still showing as operating the route - the times haven't changed so maybe not a priority.)
Deerfold
26 Nov 2009
That may be true of your services, but it's not true of the majority in the Keighley area. Oddly, areas of Leeds that still see frequent changes do seem to now have their timetables back.
I didn't forget that. It just seemed odd to remove the timetables just as things were settling down when, as you say, it hadn't been a priority when they were changing frequently. And they've now largely stayed settled down for a year.
43055
8 Mar 2018
Anywhere would be useful. Especially as the 5/X5 was changed recently and I can't find any PDF of the timetable on the arriva website!
James H
25 Jun 2014
On the Yellow Buses website, when they announced the service changes they included an apology that bus stop timetables might not be changed as quickly as usual this time, because the timetable change coincided with the Bournemouth Air Festival.
TUC
11 Nov 2010
In what way is that a reason for being late changing the timetables?
RT4038
22 Feb 2014
Presumably the staff member who would normally change the timetables was otherwise engaged on Air Festival duties in some way or another?
Llandudno
25 Dec 2014
Yes, the Arriva website, the gift that keeps on giving…!
The new 5/5D/X5 timetables can ge found on the Gwynedd County Council website.
I hope you don’t need to travel on a Sunday evening, as all the buses have been withdrawn!
Typhoon
2 Nov 2017
Kent
5-5C-5D-X5-Llandudno-to-Caernarfon-from-12-Sep-2021.pdf (from the Arriva website, showing as 5/5C/5D/X5 Llandudno to Caernarfon - link did not work for me so have attached below)
(Probably posted yesterday, after all you wouldn't want to plan a journey, would you?)
Maybe someone from Arriva saw your post? If they are lurking today, you might want to chat with Gwynedd and sort the following out:
Unfortunately, they are not the same. Arriva shows last departures on a Sunday on route 5 as : 1959, 2035, 2120, 2220
Gwynedd shows the 1959 as the last.
Gwynedd's timetable dated 5/09. Arriva's dated 12/09!
This is the worst of all worlds. I wonder why people don't use public transport?
  • 5-5C-5D-X5-Llandudno-to-Caernarfon-from-12-Sep-2021.pdf
