The Jubilee Line train - 96TS
T
Tom
Guest
A 96TS took a trip on the Northern today.
The cabview is by M. Codrington & Chris Cobley.
Coxster
9 Jun 2005
I take it the relevant authors have given you permission to show off their work when it is still in the work in progress stages?
T
Tom
Guest
Damon, yes.
I am the one who is actually compiling the train up for its final release!
Coxster
9 Jun 2005
tubechallenger said:
Damon, yes.
The sounds, yes ;) Looks good though!
Coxster
9 Jun 2005
nutter said:
The old one was great but a tunnel view, VERY realistic. Can BVE get any better
I'm sure they'll find a way - they usually do! :D
nutter
13 Nov 2005
Albrighton, Nr. Wolves, Shrops
I have thought of a small way they could improve BVE. Have the headlights working on the night routes. I mean the signs showing up and maybe a little pool of faint light before the train. Not much but exept for that I think BVE is good enough for route training (especially Brum X-city south)
Dennis
8 Aug 2005
Trowbridge
It is possible to get a passable effect of working headlights although the 'beam' will be a spread out rather than properly focussed -
1.....set the directional light angle so it is pointing ahead at a very low angle. Make the directional light moderately bright and a bit yellow
2.....set the ambient light level to quite dark
3....use black (or slightly blue) fog to get the directional light to fade out over distance
4....rebuild all the objects so they catch the directional light properly (this may not be neessary depending on the exact angles the objects are at and how well built they are - I find the biggest problem is with ground)
I did have a play around with this on the Clarendon route but becuase of the way I built a lot of the grounds they come out stripey so I am not progressing this idea at the moment. It can look good though (might put a few screenies up somewhen to illustrate the effet).
Coxster
9 Jun 2005
If you could post some screenshots mate, it would be very much appriciated. I feel that your method could be adapted somehow to make some stunning night scenarios because objects (or their texture's atleast!) have to be edited to show up darker anyway.
Gavelex
9 Sep 2006
london
it looks like the screen showing the platform is on 2 different sides. is it meant to be like this?
devon_metro
11 Oct 2005
Indeed i think the author, whoever it is should give us an update
*did i just say that :mrgreen:*
The Snap
10 Jun 2005
An update you say? OK, seen as though Dan doesn't post here too often, I'll post some shos of the brand new LT1996 on the Jubilee Line, which is nearing completion.
Baker Street Junction
Arriving in Bond Street
Dark tunnels of the Extension
Arriving at London Bridge
That should do you for now. ;)
