The last thing to electrify should be where?
Gathursty
31 May 2011
Wigan
To balance against the threads which ask about the next thing to get juice.
I'd prefer the Cornish Branches, in particular Looe, to avoid any overheads for as long as possible. Gantries would spoil the setting. Third rail would be fine however.
Iskra
11 Jun 2014
West Riding
Got to be Inverness- Kyle/Thurso.
Both for scenic and cost reasons.
I'd also be a bit disappointed if they did the S&C.
Rapidash
3 Sep 2013
Torbaydos, Devon
Stourbridge?
I'd imagine there's a few North East and Anglia lines that probably will never see a spark in the next millennia. When your stations have more sheep than passengers, I doubt it's worth it.
Wire the lot, IMO. It would be so much better if the UK could reduce, or nearly eliminate its dependency on oil entirely. Electric railways, electric buses and electric trams all round, and a massive building programme of modern nuclear power stations, would be my ideal. Works for the Swiss!
We could always wire branches using more attractive tram-style catenary if the standard type look too ugly. Indeed, for many standalone branches like the Cornish ones, operating using Metrolink-style high floor LRVs might be a good idea.
I'm aware cost will slow such a programme down, but the only answer to me to "what should we wire last" is "what is least cost-effective to wire". I wouldn't say to be overly precious about it.
pemma
23 Jan 2009
Knutsford
At the moment the long term rolling stock strategy presumes some rural lines will never be electrified. Presumably that's due to the very high cost of overhead electrics meaning other options (including EMUs with batteries) will provide better value for money.
Battery EMUs may indeed be a good option on some branches. But I certainly think national policy should be towards stopping wasting a precious commodity like oil by setting fire to it, and reducing heavily our dependence on the politically unstable countries that produce most of it.
JamesRowden
31 Aug 2011
Ilfracombe
I think that the introduction of battery EMUs is a form of electrification.
I expect that the last routes to be electrified have not been built yet. ;)
59CosG95
18 Aug 2013
Between Peterborough & Bedlington
If the OLE could be designed to minimise visual impact/with aesthetics in mind (i.e. Corten masts, as used in Denmark (see 2nd image)), it is still a better option than 3rd Rail, as its proximity to the sea and the estuary would make the juice rail more vulnerable to attack. If it took off as a viable source of power, batteries would be perfect for the branch, recharging at Liskeard and Looe.
As above, more scenically minded OLE could work really well, for both of these routes. An example is this one just outside Prague (see 1st image).
Iskra
11 Jun 2014
West Riding
I think both of those are quite ugly.
I did realise after I posted that the Swiss and Italians seem to do ok with electrification through nice areas so it isn't an insurmountable problem. Single lines always seem to come out looking ok from electrification, it's the big gantries necessary for double track that seem to ruin it as in the pictures above. I actually think our current electrified mainlines look better than the two examples you've given.
59CosG95
18 Aug 2013
Whoops...
But, as you say, for single lines, such as the Cornish Branches and the FNL, OLE wouldn't be much of a problem.
Some of the designs seen on here would do really well on scenic routes, such as the S&C... http://www.ribacompetitions.com/ols/entries.html
JamesRowden
31 Aug 2011
Ilfracombe
But then you could say the same about the Voyagers even though they use diesel to produce electricity.
Energy is inserted into Battery trains in the form of electricity and can be done so while the train is in service. Energy is inserted into Voyagers using a fuel pump at a depot.
pemma
23 Jan 2009
Knutsford
Energy is inserted into Battery trains in the form of electricity. Energy is inserted into Voyagers using a fuel pump.
But it's possible the electricity inserted in to battery trains has been created by an oil power station which, in that case, would mean the difference between a Voyager and a battery powered train is where the oil is converted to electricity.
cool110
12 Dec 2014
Preston
So we should put nuclear reactors on board trains, then we'll know that no oil is being burnt.
Mojo
7 Aug 2005
The UK's last oil power station shut down nearly two months ago.
QueensCurve
22 Dec 2014
Perhaps we should cross that bridge when we come to it.
While I would love to wire the lot a la Suisse, their decision in 1913 reflected their need from a national security perspective to be independent of imported fuel and the abundance of home-grown HEP.
In Britain we are unlikely to reach a point where the infrastructure costs can be justified for lightly trafficked lines.
Personally, I think that the wires only enhance the appearance of a line and their intrusion in Switzerland does little to detract from the scenery.
A bit of a red herring since the significance of electrification is that you avoid the need to carry around the fuel or the energy converters.
JamesRowden
31 Aug 2011
Ilfracombe
The potential benefits of battery trains match exactly those weight saving benefits that you have attributed to electrification, plus electrification can also raise energy efficiency.
Some energy is simply converted OHLE/3rdR->Train->Battery->Train->Load rather than only OHLE/3rdR->Train->Load.
Battery trains won't save as much per train, but they also don't require as much 3rd rail and/or wiring. It is simply a lower performance but with cheaper capital costs version of electrification.
Trog
30 Oct 2009
In Retirement.
The Weymouth Quay branch might be quite amusing at 25Kv.
Health and Safety would probably rule out third rail as being a tripping hazard.
SpacePhoenix
18 Mar 2014
3rd rail would be ruled out on it being foul of the roadway, some of the branch runs in the middle of the road
I personally think it would be a very good thing for our national security if we were to become fully independent of Middle Eastern and American oil.
Stourbridge Town branch anyone?
If you wired the main lines through Junction you might as well wire it, it would cost very little. Windermere is being done on that basis. Short single track branches with no junctions are easy and relatively cheap to wire.
superalbs
3 Jul 2014
Exeter
What stock would then be used? Are there even any 1 car EMUs?
Any scope for extending the platform and running through services to Brum using a 319, 350, 323 or similar?
But what is certainly the case is that there is no particular shortage of EMUs, so using a bog-standard ex-Sarfeast 4-car EMU like a 319 would be no more a waste than using the same to St Albans.
